Phase-to-ground voltage transformers may be destroyed by the increased voltage of the non- faulted phases after 8 hours.
ai có thể dịch dùm hok, dịch mà thấy hok hợp nghĩa
Xem bảng in
One of the most fundamental concepts in ac power transmission is “stability ”.It is the property of the power system that enables its operation in the intended mode where the power flows through the entire network and the power angles have their magnitudes with in specified limits maintaining synchronism between the synchronous machines as well as when the system voltage and current do not exceed the rated values
Cho e hỏi đoạn chữ đỏ dịch chính xác ntn. Vẫn loay hoay chỗ này ^^
dịch cho em đoạn này với.em dịch ra thấy khó hiểu quá
Speed: Speed rating, at the upper limit, is determined by the speed at which mechanical damage is done to the machine. The lower speed rating is based on the limit for field current (as speed increases, a higher field current is necessary to produce the same voltage).
There are four internal losses that contribute to lower efficiency of a DC generator :
Copper losses
Eddy-current losses
Hysteresis losses
Mechanical losses
ACE ơi dịch jup mình câu này với "Reactive power sharing in ship energy systems with shaft generators".
shaft generator là máy phát gì nhỉ???
em đọc mãi đoạn này mà không hiểu
"In the special case where one generator, say generator 2, is significantly larger than the other one (acting thus as an infinite bus), its f-P characteristic is almost horizontal (Fig3). Moreover, this slack generator defines the operating frequency covering any active load fluctuations.
The other generator with non-zero frequency droop works at the frequency set by the slack generator. In the case that none of the plant generators are of horizontal f-P characteristic, one is rather arbitrarily selected to play the slack role."
bác nào dịch giúp em với.
không bác nào giúp em với?
"Tốc độ: tốc độ định mức, tại ngưỡng trên, được xác định bởi tốc độ sao cho tại đó không xảy ra hư hỏng cơ khí đối với động cơ. Tốc độ thấp hơn dựa trên giới hạn của dòng điện trường (khi tốc độ tăng lên, cần dòng điện trường lớn hơn để tạo ra điện áp tương đương).
Có 4 loại tổn thất nội ảnh hưởng tới hiệu suất của máy phát điện DC:
- Tổn thất đồng.
- Tổn thất do dòng xoáy.
- Tổn thất do hiện tượng từ trễ.
- Tổn thất cơ."
