Kết quả 1 đến 3 của 3
25-04-2018, 13:38 #1
Optimum process control with 250 SCALA
This modern SCADA system 250 SCALA provides all functions for operation, monitoring and control of the entire technological process available.Its scalability enables use in all automation levels - starting with the press control station to central waiting. Optimized ergonomic control and display concepts always guarantee quick and reliable overview of the process to be controlled.
The product line extends from the touch panel of the turbine controller or machine control station via the singular single-user system,further redundant compact versions to distributed more hierarchical client / server configurations. Microsoft Windows and UNIX (SunSolaris) are available as server operating systems, each desired system performance is achieved.
250 SCALA - Applications
Turbine governor / gate control
• With a typical data volume of 500 process signals located 250 SCALA found here in its smallest expression - a compact touch panel.
• Beginning at 6 "to 17".
• The general absence of rotating components enables use in harsh ambient conditions.
Control panel
• Here are 6 "to 19" touch panels in use, also preferably without rotating parts.
• The control and display functions for the turbine controller or press control station are integrated.
• An online transient allows the display of the history of all analog and digital values of the last hours in the waveform.
• This is without any additional engineering expenses incident analyzes with up to 1 msec resolution possible.
Power plant management
The scalability of SCALA 250 begins here at DIN rail PCs (no rotating parts) or standard PCs with 1-2 screens and extends to large power plant control rooms with any number of workstations. The integrated engineering concept with its central parameter management online allows automatic distribution of process parameters and system images to the connected control stations.
The innovative human-machine interface enables new operating concepts for efficient power plant guide:
• multi-window, multi screen
• context menus
• clear forms
• multiple selection
• drag and drop
In addition to the common, commercial SCADA standards, a variety of higher-value functions is available, such as:
• Topological coloring and interlocking of the switchgear and own consumption video Surveillance
• Remote alarm via SMS
• Monitoring of network infrastructure
• Remote monitoring and diagnostics
Redundant power plant computer:
Without engineering effort can be performed redundantly by simply duplicating the computer hardware, the existing 250 SCALA system. With increased security requirements, a local distribution of the redundant computer is possible.
Dispatch center
• Due to the delay-free process high message rates, 250 SCALA is also particularly suitable for use in central waiting. In a data volume of 200,000 process signals up to 3,000 frames / second can be processed as a continuous load.
The control of video walls and database interfaces and web services are here for granted.
• Specific concepts allow both the use of a central server and the communication with a plurality of self-sufficient power station server.
World image representation and Navigator enable the clear management of power plant chains. The power station and cascade optimization is an integral part of the control system.
Bạn nào hứng thú tìm hiểu thêm có thể liên hệ mình nhé,
Cảm ơn,-------------------------------------------------------------------------------- Xem bài viết cùng chuyên mục:
- giới thiệu về SCADA
- Archestra symbol trong Intouch Wonderware
- Một số thắc mắc wincc.
- Các kỹ sư thiết kế/tích hợp thường sử dụng phần mềm Scada nào?
- Một số tài liệu và công văn về SCADA
- DataBase Wincc
- Scada Mitsubishi
- Cách lấy dữ liệu bằng Keepserver sử dụng giao thức Modbus
- cùng tìm hiểu về WINCC-SCADA-DCS
- xin phần mềm PLC mithubishi:
- AC800F-Project
- Kết nối Inverter với Autobase Scada
- Kết nối PC với PLC
- SCADA trong HTĐ Việt Nam
- Intouch Project
06-01-2019, 14:17 #2
06-10-2019, 17:25 #3
Re: Optimum process control with 250 SCALA
Bạn cho mình xin sđt hoặc gọi mình 0768398886 mình cần tìm hiểu
01268398886
Thảo luận - Sao không có Topic về Process Instruments nhỉỉ
Bởi hungbka trong diễn đàn Các vấn đề ĐK chưa phân loạiTrả lời: 2Bài cuối: 07-03-2022, 02:41 -
tín hiệu truyền về tủ control của đầu báo khói
Bởi phuckhoadien123 trong diễn đàn Hệ thống báo cháy - PCCCTrả lời: 24Bài cuối: 03-01-2022, 04:35 -
Bởi phuckhoadien123 trong diễn đàn Vi xử lý - Vi điều khiểnTrả lời: 1Bài cuối: 20-05-2011, 12:09 -
Acc control
Bởi hoang110852002 trong diễn đàn CUNG CẤP ĐIỆNTrả lời: 0Bài cuối: 20-05-2011, 11:43
