  • Kết quả 1 đến 1 của 1
    Chủ đề: Autonics
      Mặc định Autonics
      Autonics
      Qui ước quan trọng :
      - Sản phẩm thiết bị tự động AUTONICS có phát hành bảng giá duy nhất trên toàn lãnh thổ Việt Nam.
      - Chiết khấu bán hàng :
      Hãy liên hệ với chúng tôi theo các hình thức sau:
      Trực tiếp tại địa chỉ Công ty TNHH Thiết Bị Điện SONG HUỲNH
      Gọi điện thoại (84-8) 22165982 - 22165981
      Gửi Fax (84-8) 62577926
      Gửi Email sales@thebidienphongvu.com
      Xem Website www.thietbidienphongvu.com
      Địa chỉ liên lạc 926/36 Nguyễn Kiệm, phường 3, quận Gò Vấp
      Hoặc có thể vào www.thietbidienphongvu.com để nhận bảng giá chính thức
      COUNTER
      Primarily used in production lines and automation facilities, counter controls and measures length and production volume in connection with various sensors
      COUNTER/TIMER
      This unit has two function of a timer and a counter, it measures and displays length and production volume to connect various sensors.
      TIMERS
      Control time-dependent operation of various industrial facilities and equipment and is used widely in many industrial plants.
      TEMP.CONTROLLERS
      As a device to control temperature, temperature controller is widely used in injection molding machine, electric furnace and automatic soldering iron.
      RATE METER&PANEL METERS
      Panel meter measures the volatility of voltage and current in industrial devices. It displays and controls the voltage, current, watt, frequency and analog alteration of sensor.
      DISPLAY UNIT
      Depending on input data, display unit can display about 60 different kinds (digit, alphabet, symbol) of characters.
      SWITCHING POWER SUPPLIES
      This product is to heat of cool a heater, a electronic furnace etc. and also to control the power supplied to heater, Electronic furnace, Motor in order to control the revolution of motor, etc.
      SENSORS
      Photo Sensor : Using light, photo sensor detects the presence of object .
      Proximity Sensor : Using semiconductor, proximity switch detects the presence of objects without contact.
      SENSOR CONTROLLERS
      Sensor controller receives input from the sensor, transforms it into various forms of logic representation, and output it to relay.
      ENCODERS
      Rotary encoder is the sensor, which transforms mechanical movement into electrical signal. It is widely used as a position sensor in an industrial machine, elevator, and robot.
      STEPPING MOTORS
      Used to control position, speed and angle in proportion to the input pulse signal. It controls delicate step angles without a feed back signal.
      MOTION CONTROLLERS
      PMC Series is the controller, which operates and controls step & servo system. Especially it is used in the field of semi-conduct, LCD and FA.
      LASER MARKING SYSTEM
      The CO2 marking system has advantages of fast marking speed, high resolution, and compact size. And the YAG LASER ALD Series has a feature of distinguished high accuracy and efficient power consumption.
      INDICATING LIGHTS
      This unit (Bulb / LED type) giving a signal is used for achieving a goal of production per hour as workers to follow normal working process in production line and for manager to realize processing error immediately.
      Trợ giúp nhanh
      Giới thiệu chúng tôi
      Hướng dẫn mua hàng
      Thanh toán, vận chuyển
      Thông tin liên lạc
      Sửa lần cuối bởi ThietbidienPV; 22-11-2010 lúc 16:54.
    1. Cần bán - Cảm biến tiệm cận Autonics (cảm biến từ Autonics)
      Bởi bon_tabi_dhhp trong diễn đàn Thiết bị điện khác - Chưa phân loại
      Bài cuối: 28-09-2018, 13:47
    2. Cần bán - Cảm biến Autonics
      Bởi Mr Nguyen trong diễn đàn Biến tần, PLC, LOGO, thiết bị điều khiển
      Bài cuối: 21-10-2014, 12:00
    3. Cần bán - Khuyến mại Autonics
      Bởi atetruongnguyen trong diễn đàn Biến tần, PLC, LOGO, thiết bị điều khiển
      Bài cuối: 06-12-2013, 14:01
    4. Cần bán - Biến tần ABB ,Khởi động mềm ABB, biến tần LS, Autonics giá tốt chiết khấu cao
      Bài cuối: 28-10-2013, 14:19
    5. Cần bán - Đồng hồ 24H của Autonics
      Bởi dienhathe trong diễn đàn Thiết bị đóng cắt và đo lường điện
      Bài cuối: 11-10-2013, 13:54
