  • Kết quả 1 đến 2 của 2
      Mặc định Relay quá dòng và chạm đất idmtl rea200
      Combine IDMTL Overcurrent and Earth Fault (MH) - REA200
      The MH REA200 is designed as a universal, digital microprocessor-based protective relay, integrating both the overcurrent and earth fault protection schemes for definite and inverse time characteristics within one compact unit.
      Featuring a first-of-its kind, OLED Display (Organic Light Emitting Diode), the REA200 provides unparalleled clarity and crisp sharpness, alongside the enhanced functions such as communication interfaces, diagnostics features such as fault data recording with time/date stamp.
      Features
      • OLED display for superior readability
      • Redesigned menu navigation for intuitive operation
      • Dual source 85-265V AC/DC for auxiliary supply
      • Streamlined 46mm depth with bezel cover
      • Added security against nuisance trip handling
      • Manual test button for relay operation checking
      • No requirement for axially power supply for fault indication
      • Safeguard against automatic reset before fault rectification
      • Curve selection in accordance with ANSI, IAC, IEC, 1.3/10
      o Normally Inverse (NI)
      o Very Inverse (VI)
      o Extremely Inverse (EI)
      o Short Time Inverse (STI)
      o Moderate Inverse (MI)
      • Trip value recording (4-memory)
      • Integrated surge arrester against transient overvoltage
      • High set mode incorporated for instantaneous protection
      • Tamper-proof design for setting protection
      • Serial interface RS485 for Modbus RTU communication (optional)
      Liên hệ:
      MUN HEAN VIỆT NAM
      Địa chỉ : 68 Nguyễn Quý Đức, Phường An Phú, Quận 2, Tp. Hồ Chí Minh
      Hotline : 028 6281 0817- 028 6281 0815- Email : munheanvn@munhean.com.vn
      246/6 Nguyễn Tiểu La, P.8, Q.10
      Mặc định Servo Panasonic
      Bộ Servo Panasonic giá tốt
      LH 0907 449 732
    1. Trợ giúp - Cần mua plc s7-1200 cpu 1211c ac/dc/relay hoặc cpu 1212c ac/dc/relay
      Bởi truonggts trong diễn đàn PLC
      Bài cuối: 09-09-2017, 20:46
    2. Trợ giúp - Điều khiển luân phiên bơm bằng relay, contactor và timer, mỗi bơm có bộ timer+relay kiểm tra có nước ?
      Trả lời: 11
      Bài cuối: 11-08-2016, 12:28
    3. Thảo luận - Xin hỏi về Interposing relay và Intermediate relay
      Bởi pinmoi trong diễn đàn HỎI & ĐÁP VỀ ĐIỆN
      Bài cuối: 24-04-2016, 10:26
    4. Thảo luận - Lắp mạch điện 1 relay, 1 bóng đèn
      Bởi Quocnguyen2110 trong diễn đàn HỎI & ĐÁP VỀ ĐIỆN
      Bài cuối: 05-05-2015, 21:34
    5. protective relay:overcurrent relay,earth fault relay
      Bài cuối: 12-10-2010, 11:14
