    Kết quả 1 đến 10 của 44
      Pagoda
      Được cảm ơn 287 lần, trong 57 bài
      Mặc định Các kí hiệu trong bản vẽ thiết kế nhà máy nhiệt điện (ABBRIVIATIONS)
      Hi hi, Em có kí bãng này gởi tới mói ngời, các kí hiệu được dùng trong thiết kế nhà máy nhiệt điện. Các bác xem xem còn thếu thì bổ xung ha.
      ABBRIVIATIONS DESCRIPTION
      A/M Automatic/Manual
      AAAC All Aluminum Alloy Conductor
      AAC All Aluminum Conductor
      ACAR Aluminum Conductor Alloy Reinforced
      ACB Air Circuit Breaker
      ACSR Aluminum Conductor Steel Reinforced
      AFC Approved For Construction
      AFD Approved For Design
      AHU Air Handling Unit
      ANSI American National Standards Institute
      APFR Automatic Power Factor Regulator
      AR Auto Reclose (Relay)
      ASAP As Soon As Possible
      ATS Automatic Transfer Switch
      AUX Auxiliary
      AVR Automatic Voltage Regulator
      AWA Aluminum Wire Armoured (Cable)
      AWG American Wire Gauge
      BB Bus Bar (Protection)
      BCT Bushing Current Transformer
      BFP Boiler Feed-water Pump
      BHP Brake Horse Power
      BIL Basic Impulse Level
      BKR Breaker
      B/L Bill of Lading
      BM(BOM) Bill of Material
      BOO Build Own Operate
      BOP Balance Of Plant
      BOT Build Own Transfer
      BS British Standards (institute)
      BSDG Black Start Diesel Generator
      C&F Cost & Freight
      CAR Construction All Risk (Insurance)
      CBF Circuit Breaker Fail (Protection)
      CBM CuBic Meter (M³)
      CCPD Coupling Capacitor Potential Device
      CCPP Combined Cycle Power Plant
      CCW Counter Clock Wise
      CED Chiep Executive Director
      CEO Chiep Executive Officer
      CFO Chiep Financial Officer
      CFR Cost,and Freight
      CHU Chiller Handling Unit
      C/I Commercial Invoice
      CIF Cost Insurance and Freight
      CIP Carriage and Insurance Paid To
      CLR Current Limiting Reactor
      CM Construction Management
      C/O Certificate of Origin
      COS Cut Out Switch
      CPT Carriage Paid To
      CS Control Switch
      CT Current Transformer
      CTT Current Transformer Test Terminal
      CUB Cubicle
      CVT Capacitive Voltage Transformer
      CU Copper conductor
      CW Clock Wise
      C/W Certificate of Weight
      CWP Cooling Water Pump (Circulating Water Pump)
      DAF Delivered At Frontier
      D/G Diesel Generator
      DCS Distributed Control System
      DEF Delivered Ex Ship
      DIFB Biased Differential (Relay)
      DIFF. Differenfial (Relay)
      DO Diesel Oil
      DOL Direct On Line (Motor starting)
      DS Disconnecting Switch
      DTR Digital Transient Recorder
      EF Earth Fault (Relay)
      EFF. Efficiency
      E/L Export License
      ELCB Earth Leakage Circuit Breaker
      ELR Earth Leakage Relay
      EM Engineering Manager / Earth Mast
      EMS Energy Management System
      EOCR Electronic Over Current Relay
      EPC Engineering Procurenment Construction
      ES Earthing Switch
      ESD Emergency Shut Down
      ETA Estimated Time of Arrival
      ETD Estimated Time of Departure
      EX Excitor
      EXW Ex Works
      FAS Free Alongside Ship
      FAT Factory (or Field or Final) Acceptance Test
      FCA Free Carrier
      FD Forced Draft ↔ ID(Induced Draft)
      FDR Feeder
      FL Fluorescent Light (Lamp)
      FOB Free On Board
      FOR Forced Outage Rate / Free On Rail
      FRLS Flame Retardent(or Fire Resistant) Low Smoked
      FSA Fuel Supply Agreement
      FSD Fire Shut Down
      GCB Gas Circuit Breaker
      GEN Generator
      GIS Gas Insulated Switchgear
      GIS Geographic Information System
      GPS Global Positioning System
      GPT Grounding Potential Transformer
      GT(G) Gas Turbine (Generator)
      GTY Gantry
      HFO Heavy Fuel Oil
      HPS High Pressure Sodium
      HRSG Heat Recovery Steam Generator
      HVAC Heating, Ventilation & Air Conditioning
      I/C Inspection Certiviate
      ICT Interposing CT
      ID Induced Draft ↔ FD(Induced Draft)
      IDMT Inverse Definite Minimum Time
      IEC International Electrotechnical Commission
      IEEE Institute of Electrical and Electronics Engineers
      IFA Issued For Approval
      IFC Issued For Construction
      IFD Issued For Design
      IOM Inter Office Memorandum
      I/P Inusrance Policy
      IPB Isolated Phase Busduct
      IPP Independant Power Producer
      ISF Instrument Safety Factor
      ITB Invitation To Bid
      ITP Inspection (and) Test Plan
      JB(J/B) Junction Box
      JCS The Japanese Cable Manufacturer's Association Standard
      JEC Standard of the Japanese Electrotechnical Committee
      JEM The Standard of Japan Electrical Manufacturer's Association
      JIS Japanese Industrial Standards
      L.O. Lube Oil
      L/C Letter of Credit
      L/I Letter of Intent
      LA Linghtning Arrester
      LC Load Center
      LCD Liquid Crystal Display
      LCP Local Control Panel
      LCS Local Control Station
      LE / LE Lead Engineer / Loss of Excitation (Relay)
      LED Light Emitting Diode
      LFO Light Fuel Oil
      LOR Lock Out Relay
      LRC Load Ratio Controller
      LT Line Trap
      LTG Lighting
      M/H Man Hour
      M/M Man Month
      MC Magnetic Contactor
      MCB Miniature Circuit Breaker
      MCC Motor Control Center
      MCCB/M.O. Molded Case Circuit Breaker(Magnetic Only)
      MDF Main Distribution Frame
      MF Maintenance Free / Multiplying Factor
      MK Marshalling Kiosk
      MMI Man-Machine Interface
      MOF Metering Outfit
      MOM Minutes Of Meeting
      MOU Memorandom Of Understanding
      MOV Motor Operating Valve
      MPR Motor Projection Relay / Monthly Progress Report
      MTBF Mean Time Between Failure
      MTO Material Take Off
      MVR Manual Voltage Regulator
      NEC National Electrical Code
      NEMA National Electrical Manufacturer's Association
      NGR(NER) Neutral Grounding Resister(Neutral Earthing Resister)
      NGT(NGTR) Neutral Grounding Transformer
      NLTC No Load Tap Changer
      NPS Negative Phase Sequence (Relay)
      NSPB Non Segregate Phase Busduct
      NVD Neutral Voltage Displacement
      O&M Operation & Maintenance
      OCB / MOCB Oil Circuit Breaker / Minmum Oil Circuit Breaker
      OCR Over Current Relay
      OJT On the Job Training
      OLTC On Load Tap Changer
      ONAN/ONAF Oil Nature Air Nature / Oil Nature Air Forced
      OV Over Voltage (Relay)
      P&ID Piping and Instrument Diagram
      P.U Pressurization Unit / Per Unit
      P/O Purchase Order
      PABX Private Automatic Branch Exchanger
      PB Push Button
      PC Procurement Coordinator
      PCB Poly Chlorinated Bi-phenyl / Printed Circuit Board
      PCS Pieces
      PD Project Director
      PE Project Engineer
      PFD Process Flow Diagram
      PI Post Insulator
      PJT Project
      P/L Packing List
      PLC Programmable Logic Controller
      PLCC Power Line Carrier Communication
      PM Project Manager
      PMT Project Management Team
      PN Plant North
      PNL Panel
      PPA Power Purchase Agreement
      PQ Pre-Qualification
      PS Purchase Specification
      PSS Power System Stabilizer
      PT Potential Transformer
      PTT Potential Transformer Test Terminal
      PVC Poly Vinyl Chloride
      R/L Remote/Local
      RCP Remote Control Panel
      REF Restriced Earth Fault (Relay)
      RFQ(RFP) Request For Quotation (Proposal)
      RIV Radio Inflenced Voltage
      RM. Ringgit Malaysia
      Rp. Rupiah
      RP Reverse Power (Relay)
      RPM Revolution Per Minute
      Rs. Rupees
      RTD Resistance Temperature Detector
      RTU Remote Terminal Unit
      RY Relay
      S.C Static Condenser
      S.R Series Reactor
      S/S Substation
      SA Surge Arrester
      SBEF StandBy Earth Fault (Relay)
      SCADA Supervisory Control And Data Acquisition
      SCR Silicon Controlled Rectifier / Short Circuit Ratio
      SCS Substation Control System
      SER Sequence Event Recorder
      SIL Surge Impedance Loading
      SLD Single Line Diagram
      SLS Synchronizing Switch
      SPB Segregated Phase Busduct
      SPST Single Pole Single Throw
      SS Selector Switch or Syncro Switch
      SSTD Solid State Trip Device
      ST(G) Steam Turbine (Generator)
      STP Sewage Treatment Plant
      SW Switch
      SWA (Galavinized) Steel Wire Armoured (Cable)
      SWGR SWITCHGEAR
      SWYD SWITCHYARD
      SYN Synchronizing
      T/L Transmission Line
      TB Terminal Board
      TBE, TBA Technical Bid Evaluation (Analysis)
      TBN Turbine
      TCS Trip Circuit Supervision (Relay)
      TCU Tele Counting Unit
      TE Electrical reset Trip (Relay)
      TEFC Totally Enclosed Fan Cooled
      TEWAC Totally Enclosed Water (to) Air Cooled
      TLP Transformer Local Panel
      TPN Triple Pole Neutral
      TR Transformer
      TRV Transient Recovery Voltage
      UPS Uninterruptable Power Supply
      UV Under Voltage (Relay)
      VCB Vacuum Circuit Breaker
      VCS Vacuum Combination Starter
      VRO Voltage Restrained Overcurrent (Relay)
      VSAT Very Small Aperture Terminal
      VT Voltage Transformer
      WHRH Waste Heat Recovery Boiler
      XLPE Cross Linked Poly Ethylene (Insulation)
      Y2K Year 2000 (millenium bug)
      ZCT Zero-phase Current Transformer
      Have fun
      có dịch tiếng việt từng cái không ?
      Pagoda
      à, thía thì tối em dịch roài up tiếp, đây là bản gốc đấy bác ơi
      Ôi thôi, thế nà song
    4. The Following 2 Users Say Thank You to Hoankiemhanoi For This Useful Post:
      Được cảm ơn 104 lần, trong 56 bài
      Nếu ai làm bên ngành điện thì 90% các từ trên gặp thường xuyên
      CHUỘT CHẠY CÙNG SÀO MỚI VÀO CAO THẾ
      Mặc định Ðề: Các kí hiệu trong bản vẽ thiết kế nhà máy nhiệt điện (ABBRIVIATIONS)
      cái này ít ai ngồi dịch rồi gửi cho bạn lắm.
      tốt nhất là tự dịch đi nha.
    7. Những thành viên đã cảm ơn trandinhtrungdp vì bài viết hữu ích:
      thanh hóa_thanh hóa
      Được cảm ơn 115 lần, trong 68 bài
      bộ mọi người không dùng gúc gồ dịch à.tuy dịch hơi thô nhưng mình học rùi đọc sẽ hiểu thui mà..................
    9. Những thành viên đã cảm ơn độc_bước vì bài viết hữu ích:
    10. #7
      Được cảm ơn 17 lần, trong 12 bài
      oài.vdict.vn nha
    11. #8
      Được cảm ơn 7 lần, trong 2 bài
      A / M tự động / bằng tay
      Tất cả các hợp kim nhôm AAAC dẫn
      AAC Tất cả dẫn nhôm
      ACAR nhôm hợp kim cốt dẫn
      Nhôm ACSR dẫn cốt thép
      AFC chấp thuận cho xây dựng
      AFD chấp thuận cho thiết kế
      Xử lý không khí AHU
      ANSI Viện Tiêu chuẩn quốc gia Mỹ
      APFR tự động điều chỉnh hệ số điện
      ASAP càng sớm càng tốt
      ATS chuyển mạch tự động
      AUX phụ
      Ổn áp tự động AVR
      AWA dây nhôm bọc thép (cáp)
      Wire Gauge AWG Mỹ
      BB Bus Bar (bảo vệ)
      BCT ống lót biến hiện nay
      BFP lò hơi bơm nước Feed
      Cấp độ cơ bản BIL Impulse
      BKR Breaker
      B / L Bill of Lading
      BM (BOM) Bill of Material
      BOO Xây dựng riêng của doanh
      BOP dư của Nhà máy
      Xây dựng chuyển giao BOT riêng
      Tiêu chuẩn Anh BS (Viện)
      BSDG đen bắt đầu phát điện Diesel
      Chi phí vận tải C & F &
      CAR Xây dựng Tất cả các rủi ro (Bảo hiểm)
      CBF Circuit Breaker Fail (bảo vệ)
      CBM mét khối (M ³)
      Tụ nối CCPD tiềm năng thiết bị
      CCPP Nhà máy điện chu trình hỗn hợp
      Số lượt truy cập bên trái đồng hồ Wise
      CED Chiep Giám đốc điều hành
      Giám đốc điều hành Chiep đốc điều hành
      Giám đốc tài chính Chiep tài chính
      CFR Chi phí, và vận tải
      Xử lý CHU Chiller Đơn vị
      C / tôi Hoá đơn thương mại
      CIF Chi phí bảo hiểm và vận tải
      CIP vận chuyển và bảo hiểm trả Để
      Hạn chế hiện hành lò phản ứng CLR
      CM Quản lý xây dựng
      C / O chứng nhận xuất xứ
      COS Cut Out Switch
      CPT Cước trả Để
      CS tắc điều khiển
      CT hiện tại biến áp
      CTT biến hiện tại Test Terminal
      CUB tủ
      CVT điện dung biến áp
      CU ruột đồng
      CW Clock Wise
      C / W Trọng lượng Giấy chứng nhận
      Máy bơm nước làm mát CWP (Lưu hành bơm nước)
      DAF Giao tại biên giới
      D / G Diesel Generator
      DCS kiểm soát hệ thống phân
      DIFB thành kiến sai (Relay)
      DO Diesel Oil
      DOL trực tiếp On Line (Motor bắt đầu)
      DS dao Switch
      DTR ghi âm kỹ thuật số thoáng qua
      EFF. Hiệu quả
      E / L Giấy phép xuất khẩu
      ELR Earth rò Relay
      EM Kỹ thuật quản lý / Earth Mast
      Hệ thống quản lý năng lượng EMS
      Relay điện tử EOCR hơn hiện tại
      Cơ Procurenment EPC xây dựng
      ES Chuyển tiếp đất
      ESD khẩn cấp Shut Down
      ETA Dự kiến Thời gian đến
      ETD Ước Thời gian đi
      EX Excitor
      EXW Ex Works
      FAS Giao dọc mạn tàu
      Nhà máy FAT (hoặc trường hoặc Final) nghiệm thu
      FCA Free Carrier
      Buộc FD Dự thảo ↔ ID (cảm ứng Dự thảo)
      FDR Feeder
      FL huỳnh quang ánh sáng (đèn)
      FOB Free On Board
      CHO giá Cúp Buộc / Miễn phí Ngày Rail
      FRLS Flame Retardent (hoặc Fire Resistant) thấp hun khói
      FSA Hiệp định Cung cấp nhiên liệu
      FSD Fire Shut Down
      GCB khí Circuit Breaker
      GEN Generator
      GIS khí cách điện Switchgear
      Hệ thống thông tin địa lý GIS
      Hệ thống định vị toàn cầu GPS
      GPT đất biến tiềm năng
      GT (G) Tua bin (phát điện)
      Cổng GTY
      Nhiên liệu dầu nặng HFO
      HPS cao áp Sodium
      Hơi thu hồi nhiệt HRSG Generator
      HVAC thống sưởi ấm, thông gió và điều hòa nhiệt độ
      I / C thanh tra Certiviate
      ICT Interposing CT
      ID cảm ứng ↔ Dự thảo FD (cảm ứng Dự thảo)
      IDMT Inverse từ xác định tối thiểu Thời gian
      Uỷ ban điện quốc tế IEC
      IEEE Viện Kỹ sư Điện và Điện tử
      IFA cấp Đối với phê duyệt
      IFC cấp cho xây dựng
      IFD cấp cho thiết kế
      Văn phòng IOM Inter Bản ghi nhớ
      I / P Inusrance Chính sách
      Tin Isolated Busduct giai đoạn
      IPP sản xuất điện độc lập
      Cụ ISF an toàn Factor
      ITB Lời mời Để giá
      ITP kiểm tra (và) Test Plan
      JB (J / B) Box Junction
      JCS Nhà sản xuất cáp Hiệp hội Tiêu chuẩn của Nhật Bản
      JEC tiêu chuẩn của Uỷ ban Kỹ thuật Điện tử Nhật Bản
      JEM Các tiêu chuẩn của Hiệp hội các Nhà sản xuất điện của Nhật Bản
      Tiêu chuẩn Công nghiệp Nhật Bản JIS
      Dầu nhớt LO
      L / C Thư tín dụng
      L / I Thư của Ý
      LA Linghtning sét
      LC Tâm tải
      LCP địa phương Control Panel
      LE / LE chì Kỹ sư / lỗ của (Relay) kích thích
      LFO Light nhiên liệu dầu
      LOR Lock Out Relay
      Trung tâm Học liệu tải Ratio Controller
      LT Line Trap
      LTG Lighting
      M / H Man Giờ
      M / M Man Tháng
      Trung tâm điều khiển động cơ MCC
      MCCB / MO Circuit Breaker Molded Case (từ Chỉ)
      Khung phân phối chính MDF
      MF bảo trì miễn phí / Nhân Factor
      Bộ Tài chính Metering Outfit
      Biên bản họp của MOM
      Trong biên bản ghi nhớ MOU Hiểu
      MOV Motor Valve điều hành
      MPR Motor chiếu Relay / Báo cáo tiến độ hàng tháng
      MTO liệu Take Off
      Hướng dẫn điều chỉnh điện áp MVR
      NEC Mã điện quốc gia
      NEMA quốc gia của Hiệp hội Nhà sản xuất điện
      NGR (NER) trung tính nối đất Resister (trung tính tiếp đất Resister)
      NGT (NGTR) trung tính nối đất biến áp
      NLTC Không Load Tap Changer
      NPS Phủ giai đoạn trình tự (Relay)
      Tách Busduct NSPB không pha
      NVD trung hòa điện áp Displacement
      O & M Vận hành & Bảo trì
      OCB / MOCB dầu Circuit Breaker / Minmum dầu Circuit Breaker
      OCR Hơn Relay hiện tại
      Tạo trên Trên đào tạo việc làm
      OLTC Ngày Load Tap Changer
      ONAN / ONAF dầu khí thiên nhiên Thiên nhiên / Dầu khí cưỡng bức thiên nhiên
      OV hơn điện áp (Relay)
      P & ID và Sơ đồ đường ống Instrument
      PU áp Đơn vị / mỗi đơn vị
      P / O Mua hàng
      Tổng đài nhánh tự động riêng trao đổi
      PB Push Button
      Mua sắm máy tính điều phối
      Nhiều PCB Clo Bi-phenyl / tấm mạch in
      PCS Pieces
      PD Giám đốc dự án
      PE Kỹ sư dự án
      Sơ đồ khối quy trình PFD
      PI Post cách điện
      PJT dự án
      P / L Danh sách đóng gói
      Bộ điều khiển lập trình Logic PLC
      PLCC Power Line Thông tin nhà cung cấp
      PM Quản lý dự án
      PMT Đội Quản lý dự án
      PN thực vật phía Bắc
      PNL Panel
      Hiệp định mua điện PPA
      PQ Pre-Văn bằng
      Mua PS Đặc
      PSS Hệ thống điện ổn định
      PT biến tiềm năng
      PTT biến tiềm năng Terminal Test
      R / L từ xa / Địa phương
      RFQ (RFP) Yêu cầu Đối với bảng báo giá (Đề xuất)
      RIV Radio Inflenced áp
      Rp. Rupiah
      RPM Cách mạng Per Minute
      Rs. Rupi
      Nhiệt độ kháng RTD Detector
      Đơn vị đầu cuối từ xa RTU
      RY Relay
      SC tĩnh Condenser
      Lò phản ứng SR Series
      S / S Substation
      SA Chống sét
      SBEF Standby Earth Fault (Relay)
      SCADA giám sát điều khiển và thu nhận dữ liệu
      SCR chỉnh lưu điều khiển Silicon / ngắn mạch Tỷ lệ
      Hệ thống điều khiển trạm SCS
      SER chuỗi sự kiện ghi
      SIL Surge Trở kháng Loading
      SLS Đồng bộ Switch
      SPB cô lập Busduct giai đoạn
      SPST đơn cực đơn Throw
      SS Chọn Switch hoặc Switch đồng bộ
      SSTD Solid State thiết bị Trip
      ST (G) Turbine hơi nước (phát điện)
      STP Nhà máy xử lý nước thải
      SW Switch
      SWA (Galavinized) Dây thép bọc thép (cáp)
      SWGR dao
      SWYD SWITCHYARD
      SYN Đồng bộ hóa
      T / L truyền Line
      TB Ban Terminal
      TBE, TBA kỹ thuật đánh giá thầu (Phân tích)
      TBN Turbine
      TCS Trip mạch giám sát (Relay)
      TCU Tele Đếm Đơn vị
      TE điện đặt lại chuyến đi (Relay)
      Hoàn toàn TEFC kèm theo Fan làm mát bằng
      Hoàn toàn TEWAC kèm theo nước (để) làm mát bằng không khí
      TLP biến địa phương Panel
      TPN Triple cực trung tính
      TR biến
      TRV thoáng qua phục hồi điện áp
      UPS Uninterruptable nguồn
      Dưới áp UV (Relay)
      VCB Ngắt mạch chân không
      VCS hút chân không kết hợp Starter
      Bị Cấm VRO áp quá dòng (Relay)
      VSAT Rất nhỏ Aperture Terminal
      VT biến áp
      WHRH Thu hồi nhiệt thải lò hơi
      XLPE Cross Liên Kết Ethylene Poly (cách điện)
      Y2K năm 2000 (thiên niên kỷ lỗi)
      ZCT Zero-giai đoạn hiện tại biến áp
      Hãy vui vẻ
      Để tôi dịch cho
    12. The Following 6 Users Say Thank You to bjnhongkong For This Useful Post:
    13. #9
      Cung trăng
      Hehe, dùng máy dịch thì sai 1 ly đi một dặm pác ơi. Tốt nhất là tự dịch.
      Thí dụ:
      Pác dịch là
      Trong khi phải dịch là
      AAAC: dây dẫn toàn bộ hợp kim nhôm.
    14. The Following 4 Users Say Thank You to quocthai For This Useful Post:
    15. #10
      thằng BJNHONGKONG chắc nó bên hồng kông rồi,,nó dịch sai hết nghe nó chắc, bán vợ trả nợ có ngày...
    1. Trợ giúp - PT100 đo nhiệt độ trong MBA dầu: bạn nào biết chỉnh hiển thị nhiệt độ thì chia sẻ cho mình.
      Bài cuối: 23-04-2014, 11:38
    2. Trả lời: 9
      Bài cuối: 16-04-2011, 09:43
    3. Tìm kiếm các nguồn năng lượng khác trong thiên nhiên để sản xuất ra điện.
      Bởi nguyenlongdp trong diễn đàn HỆ THỐNG NĂNG LƯỢNG MỚI
      Trả lời: 9
      Bài cuối: 17-10-2010, 15:07
