    Kết quả 1 đến 10 của 13
      Red face Ai giỏi điện tử giúp đỡ với !
      MỚI VÀO NGHỀ MONG ANH EM CHỈ GIÁO !
      Parts List:
      All resistors are carbon, 1/4 watt, 5% tolerance, unless otherwise indicated.
      R1 = 500 ohm
      C1 = 0.1uF (100nF), ceramic
      U1 = LM350T
      R2 = 3K
      C2 = 1uF/40 volt
      U2 = LM301A
      R3 = 820 ohm
      C3 = 1000pF (1nF), ceramic
      S1 = Pushbutton switch (normally-open)
      R4 = 15 ohm
      C4 = 0.1uF, ceramic (see text)
      R5 = 230 ohm
      R6 = 15K
      D1 = 1N457 (or equiv.)
      Led1 = Red, 5mm, ultra-bright
      R7 = 0.2 ohm, 5W, WW
      Q1 = 2N2905, PNP, TO-39 case
      This high-performance circuit first quickly starts (and holds) the charge at 2 amp, but as the voltage rises the current will consequently decrease.
      When the current falls below 150mA, the charger automatically switches to a lower 'Float' voltage to prevent overcharging.
      At the point that a full charge is reached, Q1 will bias and the LED will light.
      The LM301A is a 8-pin OpAmp. Transistor Q1 is a PNP, Silicon, AF-Out type with a TO-39 metal case and can be substituted for a NTE or ECG129. Diode D1, a Si, GP Det. type, can be substituted with a NTE177 or ECG177. The LM350 (U1) needs to be cooled.
      The input voltage should equal or about 18volts.
      R1's function is to bleed some of the input voltage to the output and vice-versa. A 1N4002 or similar diode can be used also.
      R2 and R5 are actually metal-film type resistors. To get the 3K for R2 use two 1K5 (1500 ohm) resistors in series. For R5 use two 470 ohm resistors in parallel. Or whatever combination to get to these values. For R1, 500 ohm, you can use two 1K in parallel or 470 + 33 ohms in series.
      R7, the 0.2 ohm resistor, is a 5 watt wire-wound type. Do not use the standard carbon type.
      C4: This (optional) 0.1uF (100nF) Ceramic capacitor needs to be mounted over the power lines and as close to the LM301 (U2) as possible. It will filter off any possible residue hf ripple, which otherwise may prevent this op-amp from working properly. Use only if you have problems with the LM301 not switching off.
      S1 is a subminiature pushbutton switch, normally open. I received a couple emails in regards to this switch. I thought the diagram was pretty clear. It shows an 'open' switch with the arrow indicating a 'momentary' connection when pushed. Nothing out of the ordinary here folks and a standard symbol for electronics...
      When the start switch is pushed, the output of the charger goes to 14.5 V. As the batttery approaches full charge, the charging current decreases and the output voltage is reduced form 14.5V to about 12.5V, terminating the charging process. Transistor Q1 then lights the led as a visual indication of a full charge.
      Note: This circuit will both work for Gel cell and regular L.A. batteries, and is from an application note found in the National Linear 1 Databook as part of their regulator spec datasheets (#400041, Rev.1, Page 1-147).
    3. Những thành viên đã cảm ơn nhockid vì bài viết hữu ích:
      Red face
      Cái này thì em biết nhưng dịch từ tiếng anh sang tiếng việt không xác nghia lắm thấy sao sao đó. Anh có thể giải thích bằng tiếng việt dùm em luôn nha !
      thanks !
      Con LM 350 là IC ổn áp có U ch=1,2V. Kết hợp với R2, R4 và R5 hình thành một mạch ổn áp có:
      U ra = Uch (R2+R4+R5)/(R4+R5) = 1,2*3245/245 = 15.8V.
      Thực ra vì còn có dòng điều khiển của 335 chảy trong R2, nên điện áp không hoàn toàn là 15,8 mà chỉ còn 14,5V.
      Điện trở R7 để lấy tín hiệu dòng điện nạp ắc quy. Điện áp rơi trên R7 sẽ là
      Ur7 = I nạp * 0,2 Ω.
      Điện trở R4 sẽ tạo điện áp khoảng
      Ur4 = 1,2V *R4/(R4+R5) = 73 mV.
      IC 301A sẽ so sánh điện áp giữa Ur7 và Ur4. Khi bình còn đói, Ur7> Ur4, đầu ra (chân 6 sẽ cao, D1 bị phân cực ngược, 301 sẽ không tham gia gì vào mạch, và mạch làm việc như bình thường.
      Khi bình ắc quy đã đầy, điện áp tăng lên làm cho dòng giảm đi. Nếu Ur7 thấp hơn Ur4, tức 0,2I nạp < 0,07V ứng với I nạp < 150 mA, mạch so sánh 301 sẽ chuyển mạch, đầu ra chân 6 sẽ xuống thấp.
      Khi đầu ra chân 6 xuống thấp, nó sẽ nối R6 (15K) song song với R2 làm cho điện áp của 351 giảm xuống còn khoảng 12,5V, mạch ngưng nạp, chỉ còn nạp qua điện trở R1 (500 Ω). Đồng thời, Transistor Q1 sẽ dẫn, đèn LED sáng lên báo hiệu.
      Nút bấm nối chân 1 xuống điện áp âm, để làm cho chân 6 của 301 lên cao trở lại, khi anh muốn nạp lại. Nếu không bấm nút này thì chỉ khi điện áp bình giảm xuống thấp hơn 12,5V mạch mới tự động chuyển trở lại trạng thái nạp.
    6. The Following 6 Users Say Thank You to cô Nhóc For This Useful Post:
      Cho mình hỏi thêm tí nữa nha! Hiện nay trên thị trường LM350T với LM301A khá hiếm mình tìm mấy tiệm rồi mà không có, định thay mấy con đồng dạng với nó đây. Có ai làm mạch này thay con đồng dạng khác LM350T với LM301A mà mạch vẫn chạy bình thường không, xin cho ý kiến nha các bạn.
      Thân !
      Anh Xài con 7805 kết hợp với MJ2955 để thay con LM 350. Thiết kế lại mạch R2 và R6 là có một mạch tương đương, nhưng toàn linh kiện dễ tìm.
    9. The Following 4 Users Say Thank You to cô Nhóc For This Useful Post:
    10. #7
      Smile
      Cô Nhóc ơi ! cho hỏi tí nữa nhá .
      - Mình thay mấy con đồng dạng LM350t = LM317, LM301A=LM741 Nhóc thấy có ổn không dzậy.
      - Nhóc vẽ cho mình sơ đồ mà xài mấy con như Nhóc nói luôn hey !
      Thanks N nhìu !
    11. Những thành viên đã cảm ơn danh1909 vì bài viết hữu ích:
    12. #8
      Trích dẫn Gửi bởi danh1909 Xem bài viết
      Thanks N nhìu !
      LM 350 thay bằng 317 cũng OK với điều kiện anh xem lại dòng chịu đựng của nó. Nếu dòng chịu đựng không được đủ thì phải kết hợp với transistor cong suất. mà nếu thế thì xài 7805 dễ kiếm hơn, và rẻ hơn.
      LM 301 thay bằng 741, rất nhiều trường hợp khác thì OK, nhưng trường hợp này có vẻ như không được. Điện áp đầu vào của 741 có độ swing ít hơn 311, trong khi trong mạch này, điện áp vào cách điện áp nguồn rất ít. Chân số 2 va chân số 3 chỉ thấp hơn chân số 7 vài chục mV. Nhóc sợ con 741 hoạt động không tốt.
      Nếu anh muốn thay 311 bằng 741, thì nguồn dương (chân số 7) không nên cấp bằng điện áp 12V, mà nên cấp bằng điện áp 18 V. Có lẽ sẽ hoạt động tốt.
      Về hình vẽ: bi giờ Nhóc đang lười, chưa vẽ được. Hẹn anh Nhóc sẽ vẽ và gởi lên sau.
    13. The Following 2 Users Say Thank You to cô Nhóc For This Useful Post:
    14. #9
      Nhóc giỏi quá ta! Mình đan làm bài báo cáo mà bị kẹt tứ tung Nhóc thông cảm nha !
    15. #10
      Nhóc ơi cho hỏi nữa hen,hi....... sao con D1 mắc kỳ vậy, nếu mắc vậy thì mình thấy chân 6 con LM301A có ảnh huởng gì đâu vì mắc ngược làm sao dẫn, đây là loại D gì đây ta ?
