Kết quả 1 đến 3 của 3
19-02-2011, 11:33 #1
ai giúp e với/e đã nhờ ông Gu dịch hộ nhưng ông dịch chuối quá hic
girl.say đang gặp vấn đề với những từ chuyên ngành điện. mong sự giúp đỡ của mọi người. sẽ cảm ơn và hậu tạ. (e đã nhờ ông Gu dịch hộ nhưng ông dịch chuối quá hic)
CONDUCTORS, INSULATORS AND SEMICONDUCTORS
1.movement of free electrons
2.positive end
3.electric current
4.conductor
5.insulator
6.semiconductor
7.non- metal
8.liquid conductor
9.release electron
10.metallic oxides
11.thermistores
12.resistance
13.temperature-sensing devices
If we connect a battery across a body, there is a movement of free electrons towards the positive end. This movement of electrons is an electric current. All materials can be classified into three groups according to how readily they permit an electric current to flow. These are: conductors, insulators and semiconductors.
In the first category are substances which provide an easy path for an electric current. All metals are conductors; however, some metals do not conduct well.
Manganin, for example, is a poor conductor. Copper is a good conductor, therefore it is widely used for cables. A non-metal which conducts well is carbon. Salt water is an example of a liquid conductor.
A material which does no easily release electrons is called an insulator. Rubber, nylon, porcelain and air are all insulators. There are no perfect insulators. All insulators will allow some low of electrons; however, this can usually be ignored because the flow they permit is so small.
Semiconductors are midway between conductors and insulators. Under certain conditions they allow a current to flow easily but under others they behave as insulators. Germanium and silicon are semiconductors. Mixtures of certain metallic oxides also act as semiconductors. These are known as thermistores. The resistance of thermistor falls rapidly as their temperature rises. They are therefore used in temperature-sensing devices.-------------------------------------------------------------------------------- Xem bài viết cùng chuyên mục:
- Mỗi ngày 10 từ TA chuyên ngành điện theo CHỦ ĐỀ
- Luyện tập dịch tiếng Anh chuyên ngành.
- Tập hợp: Thuật ngữ chuyên ngành
- Diary in English of member webdien.com
- Vừa Học Vừa Chơi Với Tiếng Anh Mỗi Ngày
- [B]Download từ điển chuyên ngành Prodic 2007 miễn phí![/B]
- Chia sẻ: Kinh Nghiệm học Tiếng Anh chuyên ngành
- Cấp chính xác của thiết bị đo đếm điện năng
- Sưu tầm: Các Kinh Nghiệm và Phương Pháp học TIẾNG ANH được đúc kết
- Cho hỏi AFFL và FFL trong bản vẽ khác nhau ntn?
- Sách tiếng anh chuyên nghành điện ?
- Trunking
- Thuật ngữ trong ngành điện!
- Một số từ vựng tiếng Anh chuyên nghành
- Những từ tiếng Anh kinh khủng nhất
19-02-2011, 13:42 #2
Ðề: ai giúp e với
chất dẫn điện, chất cách điện và chất bán dẫn.
1.movement of free electrons- sự chuyển động của các electron tự do.
2.positive end- cực duơng
3.electric current - dòng điện
4.conductor - dây dẫn, chất dẫn điện
5.insulator - chất cách điện
6.semiconductor- chất bán dẫn
7.non- metal - phi kim
8.liquid conductor - chất lỏng dẫn điện
9.release electron
10.metallic oxides - oxit kim loại
11.thermistor - nhiệt điện trở
12.resistance - điện trở
13.temperature-sensing devices - thiết bị cảm biến nhiệt độ.
nếu chúng ta nối một ắc quy (pin) qua một vật (dẫn điện) sẽ có sự chuyển động của các electron về phía cực dương. Tất cả các chất có thể được phân thành ba nhóm tùy thuộc vào cách chúng cho dòng điện đi qua : chất dẫn điện, chất cách điện, chất bán dẫn.
nhóm đầu tiên là những chất cho dòng điện đi qua dễ dàng. Tất cả kim loại đều dẫn điện. Tuy nhiên có một số kim loại dẫn điện kém. Măng gan( Mn) là một chất dẫn điện kém. Đồng đỏ là chất dẫn điện tốt vì vậy được sử dụng rộng rãi trong cáp điện. Các-bon (C) là một phi kim dẫn điện tốt. Nước muối là một chất lỏng dẫn điện.
A material which does no easily release electrons is called an insulator. Rubber, nylon, porcelain and air are all insulators. There are no perfect insulators. All insulators will allow some low(flow) of electrons; however, this can usually be ignored because the flow they permit is so small.
Một chất mà không giải phóng electron một cách dễ dàng được gọi là chất cách điện. Cao su. nylon, sứ là chất cách điện. Các chất cách điện không hoàn toàn. Tất cả các chất cách điện sẽ cho phép một lượng nhỏ các electron đi qua,tuy nhiên điều này thường bị bỏ qua bởi vì lưu lượng cho phép này quá nhỏ.
Chất bán dẫn nằm ở giữa chất dẫn điện và cách điện. Với điều kiện nào đó chúng cho dòng điện đi qua một cách dễ dàng nhưng trong điều kiện khác chúng lại như là chất cách điện. Germani và silic là những chất bán dẫn. Sự pha trộn của các oxit kim loại nào đó cũng tạo lên các chất bán dẫn. Chúng được biết đến như là những nhiệt điện trở. Điện trở của nhiệt điện trở giảm xuống khi nhiệt độ của chúng tăng lên. Vì vậy chúng được sử dụng trong các thiết bị cảm biến nhiệt độ.
The Following 2 Users Say Thank You to tsunami8x For This Useful Post:
19-02-2011, 14:19 #3
Ðề: ai giúp e với
Nếu chúng ta nối một vật vào nguồn điện, sẽ có một dòng Electron tự do dịch chuyển từ cực âm qua cực dương. Sự di chuyển này được gọi là dòng điện. Tất cả các chất này được phân thành 3 nhóm chúng cho phép dòng điện đi qua. đó là: dẫn điện, không dẫn điện và chất bán dẫn.
Trong mục này một số chất dẽ dàng cho dòng điện chạy qua: Tất cả kim loại đều dẫn điện, tuy nhiên một số kim loại dẫn điện kém, ví dụ: Manganin là một chất dẫn điện yếu. Đồng là một chất dẫn điện tốt nên nó được dùng làm cáp điện, phi kim cũng dẫn điện đó là carbon, chất lỏng dẫn điện: nước muối.
Những chất mà sự giải phóng E yếu thì được gọi là chất cách điện. Cao su, nylon, sứ là những chất cách điện. Nó không hoàn toàn cách điện. những chất này vẫn cho dòng e qua nhưng không đáng kể nên được coi như chất chất cách điện.
Bán dẫn là chất vừa dẫn điện vừa là chất cách điện. Ở điều kiện này chúng là chất dẫn điện nhưng ở điều kiện khác chúng lại là chất cách điện. Germanium và sillic là những chất bán dẫn. Trộn hai oxide kim loại này ta được chất bán dẫn. Nó được gọi là nhiệt điện trở. Nhiệt độ càng tăng thì điện trở càng giảm. Cho nên chúng được dùng làm thiết bị đo nhiệt độ.
HEHE
Trợ giúp - chuông báo hiệu: bạn hãy vẽ 1 mạch gồm 1 công tắc điều khiển cho 6 chuông
Bởi xuanhoc trong diễn đàn Thiết bị điện gia dụngTrả lời: 16Bài cuối: 12-08-2013, 22:37 -
Thảo luận - So sánh ưu và nhược điểm giữa chuẩn rs232 và chuẩn usb 2.0
Bởi quockhanhvt1991 trong diễn đàn Vi xử lý - Vi điều khiểnTrả lời: 0Bài cuối: 03-12-2012, 17:14
