  • Kết quả 1 đến 5 của 5
      Được cảm ơn 11 lần, trong 2 bài
      Post Em đang làm tiểu luân anh văn- a,e nào dịch giúp em với.
      Most sensors are electrical or electronic, although other types exist. A sensor is a type of transducer. Sensors are either indicating (e.g. a mercury thermometer or electrical meter) or are paired with an indicator (perhaps indirectly through an analog to digital converter, a computer and a display) so that the value sensed becomes human readable. Aside from other applications, sensors are heavily used in, industry and robotics.
      A contactor is an electrical device used for controlling power flow. A contactor is activated by a control input which is a lower voltage / current than that which the contactor is switching. Contactors come in many forms with varying capacities and features.
      Inverters are used in a wide range of applications, from small power supplies for a computer to large industrial applications to transport bulk power. An inverter can have one or two switched-mode power supplies (SMPS). Simple inverters consist of an oscillator driving a transistor that is used to interrupt the incoming direct current to create a square wave. This is then fed through a transformer to produce the required output voltage. Advanced inverters have started using more advanced forms of transistors or similar devices such as thyristors.
      An encoder is a device used to encode a signal (such as a bit-stream) or data into a form that is acceptable for transmission or storage. This is usually done by means of a programmed algorithm, especially if any part is digital, while most analogue encoding is done with analog circuitry.
      Fluid power is the technology that deals with the generation, control, and transmission of pressurized fluids. As the term fluid refers both to gases and liquids fluid power is also subdivided into the categories of hydraulics and pneumatics. The differences being that with hydraulics the medium used is a liquid (ie mineral oil or water) and for pneumatics, it is a gas (ie air or another inert gas).
      Mặc định Ðề: Em đang làm tiểu luân anh văn- a,e nào dịch giúp em với.
      Mạng internet đáng lẽ là một công cụ tốt để cho sinh viên học tập thì lại làm cho họ lười đi. Mấy dòng con con này không dịch được thì làm cả cái "tiểu luận Anh văn" làm gì cho tốn giấy?
      Hầu hết các cảm biến đều là cảm biến điện hoặc điện tử, bên cạnh đó cũng tồn tại một số loại khác. Cảm biến là một loại bộ chuyển đổi. Các cảm biến hoặc là chỉ thị (VD như nhiệt kế thủy ngân hay điện kế) hoặc là kết hợp với một bộ chỉ thị (có lẽ gián tiếp thông qua một bộ biến đổi tương tự - số (ADC), một máy tính và một bộ hiển thị) để con người có thể đọc được các giá trị mà cảm biến đo được. Ngoài những ứng dụng khác, cảm biến được sử dụng nhiều trong công nghiệp và robot.
      Công tắc tơ (sao mình ghét cái từ này thế!) là một loại thiết bị điện được dùng để điều khiển dòng năng lượng (điện). Công tắc tơ được kích hoạt bởi tín hiệu điều khiển, tín hiệu đó là điện áp / dòng điện tháp hơn dòng và áp mà công tắc tơ đóng cắt. Công tắc tơ có nhiều loại với nhiều khả năng và đặc tính khác nhau.
      Bộ nghịch lưu được sử dụng rộng rãi, từ các nguồn công suất nhỏ cho máy tính đến các ứng dụng công nghiệp để chuyển đổi công suất lớn. Một bộ nghịch lưu có thể có 1 hoặc 2 bộ nguồn xung. Các bộ nghịch lưu đơn giản bao gồm một bộ dao động để điều khiển một tran-zi-to mà được sử dụng để ngắt dòng một chiều tạo thành dạng sóng vuông. Sau đó nó được cấp cho một biến áp để tạo ra điện áp đầu ra theo yêu cầu. Các bộ nghịch lưu tiên tiến sử dụng các loại tran-zi-to tiên tiến hoặc các linh kiện tương tự như ty-rit-to.
      Encoder (bộ mã hóa) là một thiết bị được dùng để mã hóa 1 tín hiệu (như là một dãy bit) hoặc các dữ liệu thành một loại tín hiệu mà có thể truyền đi hoặc lưu trữ được. Điều này thường được thực hiện chính bằng các thuật toán được lập trình, nhất là khi có bất cứ phần nào của tín hiệu là dạng số, trong khi đó phần lớn việc mã hóa tương tự được thực hiện bằng các mạch tương tự.
      Kỹ thuật thủy khí là công nghệ hướng tới việc giải quyết vấn đề phát, điều khiển và truyền dẫn các dòng chất lưu được nén áp lực. Thuật ngữ "chất lưu" được dùng cho cả ga và các chất lỏng, kỹ thuật thủy khí cũng được chia thành thủy lực và khí nén. Sự khác nhau là ở chỗ trong thủy lực thì sử dụng các chất lỏng (dầu hoặc nước) còn trong khí nén thì sử dụng ga (không khí hoặc các loại khí trơ).
    3. The Following 2 Users Say Thank You to baohuy_pla For This Useful Post:
      Được cảm ơn 568 lần, trong 268 bài
      hiii và đặ biệt là có bác baohuy_pla nên càng làm cho các em nó lười thêm. hiiiiii
      (em nói jởn bác đừng có chém em nhá)
      ^^. dịch tiep đi bác
      hoan hô tinh thần bác baohuy
    1. Trợ giúp - Mạng điện văn phòng bị chập chờn
      Bởi duonghuyhoang trong diễn đàn HỎI & ĐÁP VỀ ĐIỆN
      Bài cuối: 06-03-2022, 18:10
    2. KHO ĐỒ ÁN luận văn mẫu..thực tiễn
      Bởi mrhao.ceo trong diễn đàn ĐỒ ÁN - LUẬN VĂN TỐT NGHIỆP
      Trả lời: 17
      Bài cuối: 02-12-2016, 20:03
