Kết quả 1 đến 10 của 31
Chủ đề: Một số tiêu chuẩn IEC cần biết
17-03-2010, 14:08 #1
Tổng hợp các tiêu chuẩn IEC
File 3 : File Name: www.softarchive.net.IEC 62271-308 High-voltage switchgear and controlgear - Guide to Asymetrical shoet circuit breaki.pdf
Description: uploaded with File Uploader (z-o-o-m.110mb.com)
File Size: 1.80 MB
Download Link: http://uploading.com/files/KV1ZJDSC/...rchive.net.IEC 62271-308 High-voltage switchgear and controlgear - Guide to Asymetrical shoet circuit breaki.pdf.html
File 4 : File Name: www.softarchive.net.IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear.pdf
File Size: 1.21 MB
Download Link: http://uploading.com/files/TJU3DAKW/...rchive.net.IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear.pdf.html
File 5 : File Name: www.softarchive.net.IEC 62271-105 High-voltage switchgear and controlgear - Alternating-current Switch Fuse Combinati.pdf
File Size: 3.65 MB
Download Link: http://uploading.com/files/1WTEHRJX/...rchive.net.IEC 62271-105 High-voltage switchgear and controlgear - Alternating-current Switch Fuse Combinati.pdf.html
File 6 : File Name: www.softarchive.net.IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-.pdf
File Size: 7.85 MB
Download Link: http://uploading.com/files/MVFFI3U0/...rchive.net.IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-.pdf.html
File 7 : File Name: www.softarchive.net.IEC 62271-102 High-voltage switchgear and controlgear - High-voltage alternating-current Disconne.pdf
File Size: 3.88 MB
Download Link: http://uploading.com/files/H0X0LRXN/...rchive.net.IEC 62271-102 High-voltage switchgear and controlgear - High-voltage alternating-current Disconne.pdf.html
tvdhp is online nowView user's profileSend private message
tvdhp
Grown Up Punk
Grown Up Punk
PostPosted: Fri May 15, 2009 2:22 pm Reply with quoteEdit/Delete this post Report postBack to top
File 8 : File Name: www.softarchive.net.IEC 62086-1 Electrical apparatus for explosive gas atmospheres - Electrical resistance trace he.pdf
File Size: 384 KB
Download Link: http://uploading.com/files/FJS5U34J/...rchive.net.IEC 62086-1 Electrical apparatus for explosive gas atmospheres - Electrical resistance trace he.pdf.html
File 9 : File Name: www.softarchive.net.IEC 61832 Analyser systems - Guide to technical enquiry & Bid Evaluation.pdf
File Size: 503 KB
Download Link: http://uploading.com/files/HSXN25AZ/...rchive.net.IEC 61832 Analyser systems - Guide to technical enquiry & Bid Evaluation.pdf.html
File 10 : File Name: www.softarchive.net.IEC 61831 On-line analyser systems - Guide to design and installation.pdf
File Size: 755 KB
Download Link: http://uploading.com/files/9FOCUNUM/...rchive.net.IEC 61831 On-line analyser systems - Guide to design and installation.pdf.html
File 11 : File Name: www.softarchive.net.IEC 61537 Cable tray systems and cable ladder systems.pdf
File Size: 847 KB
Download Link: http://uploading.com/files/P04S2TB4/...rchive.net.IEC 61537 Cable tray systems and cable ladder systems.pdf.html
File 12 : File Name: www.softarchive.net.IEC 61511 Part-3 Guidance for the determination of safety integrity levels - informative.pdf
File Size: 0.87 MB
Download Link: http://uploading.com/files/45QWFW36/...rchive.net.IEC 61511 Part-3 Guidance for the determination of safety integrity levels - informative.pdf.html
File 13 : File Name: www.softarchive.net.IEC 61508 Part 7 Overview of Techniques & Measures.pdf
File Size: 3.86 MB
Download Link: http://uploading.com/files/FG5KPVA2/...rchive.net.IEC 61508 Part 7 Overview of Techniques & Measures.pdf.html
File 14 : File Name: www.softarchive.net.IEC 61511 Part-1 Framework, definitions, system, hardware and software requirements.pdf
File Size: 1.63 MB
Download Link: http://uploading.com/files/8059AYU2/...rchive.net.IEC 61511 Part-1 Framework, definitions, system, hardware and software requirements.pdf.html
File 15 : File Name: www.softarchive.net.IEC 61508 Part 6 - Guidelines on the application of parts 2 and 3.pdf
File Size: 871 KB
Download Link: http://uploading.com/files/T8RMPLLN/...rchive.net.IEC 61508 Part 6 - Guidelines on the application of parts 2 and 3.pdf.html
File 16 : File Name: www.softarchive.net.IEC 61508 Part 5 Addenda.pdf
File Size: 7.35 KB
Download Link: http://uploading.com/files/AYTOC5K6/...rchive.net.IEC 61508 Part 5 Addenda.pdf.html
File 17 : File Name: www.softarchive.net.IEC 61508 Part 4 - Definitions and Abbreviations.pdf
File Size: 2.31 MB
Download Link: http://uploading.com/files/ZM28Y0TZ/...rchive.net.IEC 61508 Part 4 - Definitions and Abbreviations.pdf.html
File 18 : File Name: www.softarchive.net.IEC 61508 Part 4 Addenda.pdf
File Size: 14 KB
Download Link: http://uploading.com/files/5OO84WX3/...rchive.net.IEC 61508 Part 4 Addenda.pdf.html
File 19 : File Name: www.softarchive.net.IEC 61158-2 Physical layer specification and service definition.pdf
File Size: 13.90 MB
Download Link: http://uploading.com/files/JW1GAOSJ/...rchive.net.IEC 61158-2 Physical layer specification and service definition.pdf.html
File 20 : File Name: www.softarchive.net.IEC 61508 Part 3 Addenda.pdf
File Size: 6.94 KB
Download Link: http://uploading.com/files/D6COYBH1/...rchive.net.IEC 61508 Part 3 Addenda.pdf.html
Em sưu tầm được trên net, các bác down về mà xài nha
- Quy chuẩn quan trọng nhất đối với dân điện!!
- []HOT] Tiêu chuẩn đo điện trở cách điện thiết bị
- các TCVN trong ngành điện
- [HOT] bộ IEC standards
- Một số tiêu chuẩn IEC cần biết
- Tiêu chuẩn đo điện trở cách điện, hệ số hấp thụ, Hệ số phân cực
- Ký hiệu các pha là gì?
- Các tiêu chuẩn thiết kế điện anh em cần chú ý
- Tiêu chuẩn iec
- [HOT] Quy phạm trang bị điện đầy đủ 4 phần
- Cần tìm bộ tiêu chuẩn IEC-61970 và IEC-61968
- Quanh đi quẩn lại, vẫn là TCVN 7447
- [HOT] bộ TCVN 7447
- [hot]Tieu chuan thí nghiệm - nghiệm thu thiết bị điện
- Phân biệt Type test report và Inspection Report
"Có thực mới vực đựơc đạo"
Skype: combui_viahe
The Following 14 Users Say Thank You to combui_viahe For This Useful Post:
17-03-2010, 14:12 #2
IEC 60364-3 Electrical Installations of Buildings.pdf
IEC 60044-1 Instrument Transformers Part-1 Current Transformers.pdf
IEC 60071-1 Insulation Co-Ordination - Definitions, principles and rules.pdf
IEC 60071-2 Insulation Co-Ordination - Application guide.pdf
IEC 60071-4 Insulation Co-Ordination - Computational guide to insulation co-ordination and modell.pdf
IEC 60076-1 Power transformers - General.pdf
IEC 60076-10 Power transformers - Determination of sound levels.pdf
IEC 60076-2 Power transformers - Temperature rise.pdf
IEC 60076-3 Power transformers - Insulation levels, dielectric tests and external clearances in a.pdf
IEC 60076-4 Power transformers - Guide to the lightning impulse and switching impulse testing.pdf
IEC 60076-5 Power transformers - Ability to withstand short circuit.pdf
IEC 60076-8 Power transformers - Application guide.pdf
IEC 60079-1 Electrical apparatus for explosive gas atmospheres - Flameproof enclosures 'd'.pdf
IEC 60079-10 Electrical apparatus for explosive gas atmospheres - Classification of hazardous areas.pdf
IEC 60079-11 Electrical apparatus for explosive gas atmospheres - Intrinsic safety 'i'.pdf
IEC 60079-14 Electrical apparatus for explosive gas atmospheres - Electrical installations in hazardous areas.pdf
IEC 60079-15 Electrical apparatus for explosive gas atmospheres - Construction, test and marking of type of protection n electrical apparatus.pdf
IEC 60079-2 Electrical apparatus for explosive gas atmospheres - Pressurized enclosures 'p'P.pdf
IEC 60079-27 Fieldbus intrinsically safe concept (FISCO) and Fieldbus non-incendive concept (FNICO).pdf
IEC 60079-4 Method of test for ignition temperature.pdf
IEC 60079-5 Electrical apparatus for explosive gas atmospheres - Powder Filling 'q'.pdf
IEC 60079-6 Electrical apparatus for explosive gas atmospheres - Oil-immersion 'o'.pdf
IEC 60079-7 Electrical apparatus for explosive gas atmospheres - Increased safety 'e'.pdf
IEC 60092-350 Elecetrical Installations in Ship.pdf
IEC 60092-352 Choice & Installation of Cables for Low Voltage Power Systems.pdf
IEC 60092-375 Ship board telecommunication cables and radio-frequency cables - General instrumentation, control and communication cables.pdf
IEC 60092_375 General Instrumentation, Control & Communication Cables.pdf
IEC 60092_376 Cable for Control & Instrumentation Circuits.pdf
IEC 60228 Conductors of Insluated Cables.PDF
IEC 60245-3 Rubber Insulated Cables.pdf
IEC 60255-13 Electrical relays - Biased (percentage) differential relays.pdf
IEC 60255-22-5 Electrical relays - Electrical disturbance tests for measuring relays and protecti.pdf
IEC 60255-23 Electrical Relays - Contact Performance.pdf
IEC 60255-24 Electrical relays - Common format for transient data exchange (COMTRADE) for power s.pdf
IEC 60255-3 Electrical relays - Single input energizing quantity measuring relays with dependent .pdf
IEC 60255-5 Electrical relays - Insulation coordination for measuring relays and protection equip.pdf
IEC 60255-6 Electrical relays - Measuring relays and protection equipment.pdf
IEC 60255-8 Electrical relays - Thermal electrical relays.pdf
IEC 60269-1 Low-voltage fuses - General requirements.pdf
IEC 60269-2 Low-voltage fuses - Supplementary requirements for fuses for use by authorized person.pdf
IEC 60269-2-1 Low-voltage fuses - Supplemetary Requirements for Fuses for use by authorized perso.pdf
IEC 60269-4 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of s.pdf
IEC 60269-4-1 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of.pdf
IEC 60298 A.C. metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to .pdf
IEC 60331 Fire Resisting Charecteristics of Electric Cables.PDF
IEC 60331-11 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331-12 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331-31 Test on Electrical Cables Under Fire Condition.pdf
IEC 60332-1 Tests on electric cables under fire conditions - Test on a single vertical insulated .pdf
IEC 60332-1_1 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1_2 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1_3 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-2 Tests on electric cables under fire conditions - Test on a single small vertical insu.pdf
IEC 60332-2_1 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-2_2 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-3-10 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-21 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-22 Test on Electrical Cables Under Fire Condition.pdf
IEC 60332-3-22 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-23 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-24 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-25 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60364-1 Electrical installations of buildings - Fundamental principles, assessment of general.pdf
IEC 60364-5-52 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-5-54 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-5-548 Electrical installations of buildings - Selection and erection of electrical equi.pdf
IEC 60364-5-55 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-5-56 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-7-707 Electrical installations of buildings - Requirements for special installations or.pdf
IEC 60439-1 Low-voltage switchgear and controlgear assemblies - Type-tested and partially ty.pdf
IEC 60439-2 Low-voltage switchgear and controlgear assemblies - Particular requirements for busba.pdf
IEC 60439-3 Low-voltage switchgear and controlgear assemblies - Particular requirements for Iow-v.pdf
IEC 60439-4 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf
IEC 60439-5 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf
IEC 60502-1 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60502-2 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60502-4 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60529 Degrees of protection provided by enclosures (IP Code).pdf
IEC 60534-1 Industrial Process Control Valves - Terminology & General Considerations.pdf
IEC 60534-2_1 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_3 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_4 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_5 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-3 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_1 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_2 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_3 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-4 Industrial Process Control Valves - Inspection & Routine Testing.pdf
IEC 60534-5 Industrial Process Control Valves - Marking.pdf
IEC 60534-6 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-6_1 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-6_2 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-7 Industrial Process Control Valves - Data Sheet.pdf
IEC 60534-8_1 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-8_2 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-8_3 Control valve aerodynamic noise prediction method.pdf
IEC 60534-8_4 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60584-1 Thermocouples - Reference tables.pdf
IEC 60584-2 Thermocouples - Tolerances.pdf
IEC 60584-3 Thermocouples - Extension and compensating cables.pdf
IEC 60694 Common specifications for high -voltage switchgear and controlgear standards.pdf
IEC 60726 Dry Type Power Transmformers.PDF
IEC 60751 Industrial platinum resistance thermometer Sensors.pdf
IEC 60793-1-44 Optical fibres - Measurement methods and test procedures - Cut-off wavelength.pdf
IEC 60874-14-4 Connectors for optical fibres and cables - Detail specification for fibre optic adaptor (simplex) type SC for multimode fibre.pdf
IEC 60909-0 Short-circuit currents in three-phase a.c. systems - Calculation of currents.pdf
IEC 60909-1 Short-circuit currents in three-phase a.c. systems - Factors for the calculation of s.pdf
IEC 60909-2 Electrical equipment - Data for short-circuit current calculations.pdf
IEC 60909-3 Short-circuit currents in three-phase a.c. systems - Currents during two separate sim.pdf
IEC 60909-4 Short-circuit currents in three-phase a.c. systems - Examples for the calculation of .pdf
IEC 60947-1 Low-voltage switchgear and controlgear - General rules.pdf
IEC 60947-1-2004 Low-voltage switchgear and controlgear - General rules.pdf
IEC 60947-2 Low-voltage switchgear and controlgear - Circuit Breakers.pdf
IEC 60947-3 Low-voltage switchgear and controlgear - Switches, disconnectors, switch-disconnector.pdf
IEC 60947-4-1 Low-voltage switchgear and controlgear - Contactors and Motor Starters - Electromec.pdf
IEC 60947-4-2 Low-voltage switchgear and controlgear - Contactors and Motor Starters - AC Semicon.pdf
IEC 60947-4-3 Low-voltage switchgear and controlgear - Contactors and motor-starters - AC semicon.pdf
IEC 60947-6-1 Low-voltage switchgear and controlgear - Multiple function equipment - Automatic tr.pdf
IEC 60947-6-2 Low-voltage switchgear and controlgear - Multiple function equipment - Control and .pdf
IEC 60947-7-1 Low-voltage switchgear and controlgear - Ancillary equipment - Terminal blocks for .pdf
IEC 61131-1 Programmable controllers - General information.pdf
IEC 61131-2 Programmable controllers - Equipment Requirements and Tests.pdf
IEC 61131-3 Programmable controllers - Programming languages.pdf
IEC 61131-4 Programmable controllers - User guidelines.pdf
IEC 61131-5 Programmable controllers - Communications.pdf
IEC 61131-7 Programmable controllers - Fuzzy control programming.pdf
IEC 61131-8 Programmable controllers - Guidelines for the application and implementation of programming languages.pdf
IEC 61158-1 Overview and guidance for the IEC 61158 series.pdf
IEC 61158-3 Data link service definition.pdf
IEC 61508 Part 1 - General Requirements.pdf
IEC 61508 Part 1 Addenda.pdf
IEC 61508 Part 2 - Requirements for Electrical - Electronic programmable electronic safety-related systems.pdf
IEC 61508 Part 3 - Software Requirements.pdf
IEC 61508 Part 5 - Examples of Methods for the determination of safety integrity levels.pdf
IEC 61511 Part-2 Guidelines in the application of IEC 61511-1 - Informative.pdf
IEC 61537 Cable tray systems and cable ladder systems.pdf 73d4eed8
IEC 61892-6 Mobile and fixed offshore units - Electrical installations.pdf
IEC 62271-200 High-voltage switchgear and controlgear - AC metal-enclosed switchgear and controlg.pdf
IEC PAS 62030 Real-Time Publish-Subscribe (RTPS) Wire Protocol Specification Version 1.0.pdf
IEC TR 62095 Electric cables - Calculations for current ratings - Finite element method.pdf
IEC TR 62271-310 High-voltage switchgear and controlgear - Electrical endurance testing for circu.pdf"Có thực mới vực đựơc đạo"
Skype: combui_viahe
The Following 11 Users Say Thank You to combui_viahe For This Useful Post:
26-03-2010, 13:24 #3
gửi bác tiêu chuẩn IEC 62271-203
http://www.mediafire.com/file/mwmiqyloghd/IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear.pdf
link webdien:
http://www.data.webdien.com/free/dow...24c21a78501309"Có thực mới vực đựơc đạo"
Skype: combui_viahe
The Following 5 Users Say Thank You to combui_viahe For This Useful Post:
10-04-2010, 15:27 #4
Những thành viên đã cảm ơn gacon vì bài viết hữu ích:
11-05-2010, 16:38 #5
Mà mấy anh chị cho em hỏi tiêu chuẩn ice là gì vậy sau em thấy wa trùi vậy
11-05-2010, 16:49 #6
IEC chứ không phải ice bạn ah. IEC (International Electrotechnical Commission), tiếng Việt gọi là Uỷ ban Kỹ thuật Điện Quốc tế được thành lập năm 1906. Mục tiêu của IEC là thúc đẩy sự hợp tác quốc tế về tiêu chuẩn hoá trong lĩnh vực điện - điện tử và các vấn đề có liên quan như: chứng nhận sự phù hợp tiêu chuẩn điện và hỗ trợ cho thông hiểu quốc tế
Đêm qua tôi mơ thấy nàng
Nàng cười nàng nói: Mày lì như trâu
Cung cấp giá rẻ: Đèn pha led, đèn túyp led t8, đèn led âm trần, đèn ốp nổi, đèn led trang trí… hàng Dragon Taiwan bảo hành 2 năm. hahaha
The Following 4 Users Say Thank You to minhwilliam For This Useful Post:
16-05-2010, 12:59 #7
22-05-2010, 11:18 #8
http://rapidshare.com/files/21516191...ge_alternating
http://rapidshare.com/files/21516328...definition.pdf
http://rapidshare.com/files/21516365..._and_Tests.pdf
http://rapidshare.com/files/21516416...and_motor-star
http://rapidshare.com/files/21516463...and_Motor_Star
http://rapidshare.com/files/21516528...and_Motor_Star
http://rapidshare.com/files/21516565...connectors__sw
http://rapidshare.com/files/21516645...t_Breakers.pdf
http://rapidshare.com/files/21516767...eral_rules.pdf
http://rapidshare.com/files/21516874...alculation_of_
http://rapidshare.com/files/21517030...ontrolgear_sta
http://rapidshare.com/files/21517158...nce_tables.pdf
http://rapidshare.com/files/21517236...nd_erection_of
http://rapidshare.com/files/21517289..._voltages_abov
http://rapidshare.com/files/21517327...ses_for_use_by
http://rapidshare.com/files/21517362...quirements.pdf
http://rapidshare.com/files/21517405...exchange__COMT
http://rapidshare.com/files/21517451...ncreased_safet
http://rapidshare.com/files/21517494...ts_and_externa
http://rapidshare.com/files/21517577...tion_guide.pdf
NGHỊ ĐỊNH 16/2005: http://www.my.opera.com/khonggianson...s/16ND2005.rtf
By khonggiansong, # 23. August 2006, 07:55:12
NGHỊ ĐỊNH 209/2004 : http://www.my.opera.com/khonggianson.../209ND2004.rtf
By khonggiansong, # 23. August 2006, 07:57:03
QUY ĐỊNH AN TOÀN ĐIỆN NÔNG THÔN, DÒNG ĐIỆN ĐỊNH MỨC CỦA DÂY DẪN:
http://www.my.opera.com/khonggianson...ennongthon.doc
By khonggiansong, # 23. August 2006, 08:43:59
TUYỂN TẬP TIÊU CHUẨN XÂY DỰNG TRANG BỊ ĐIỆN VN 14: http://www.my.opera.com/tazzan/homes...XDVN%20C14.pdf
By khonggiansong, # 23. August 2006, 16:42:10
TCXDVN 333 :2005 Chiếu sáng nhân tạo bên ngoài công trình công cộng và kỹ thuật hạ tầng đô thị - Tiêu chuẩn thiết kế :
http://www.my.opera.com/tazzan/homes.../QD_082005.doc
By khonggiansong, # 23. August 2006, 16:48:16
THANG MÁY TCVN 5866-1995
http://www.my.opera.com/tazzan/homes...05866-1995.doc
By khonggiansong, # 23. August 2006, 16:57:26
TCXDVN 319:2004 Lắp đặt hệ thống nối đất cho các công trình công nghiệp - Yêu cầu chung.
http://www.my.opera.com/tazzan/homes...319%202004.doc
By khonggiansong, # 23. August 2006, 17:00:35
TCXDVN 319 :2004 Lắp đặt hệ thống nối đất cho các công trình công nghiệp - Yêu cầu chung.
By khonggiansong, # 23. August 2006, 17:02:40
TCVN 27 :1991 Đặt thiết bị điện trong nhà ở và công trình công cộng. Tiêu chuẩn thiết kế.
http://www.my.opera.com/tazzan/homes...1991%20moi.doc
By khonggiansong, # 23. August 2006, 17:04:00
TCVN 16 :1996 Chiếu sáng nhân tạo trong công trình dân dụng
http://www.my.opera.com/tazzan/homes...27-16-1986.doc
By khonggiansong, # 23. August 2006, 17:09:08
TCVN 5176 :1990 Chiếu sáng nhân tạo - Phương pháp đo độ rọi
http://www.my.opera.com/tazzan/homes...176%201990.doc
By khonggiansong, # 23. August 2006, 17:12:00
TCVN 5681 :1992 Hệ thống tài liệu thiết kế xây dựng.Chiếu sáng điện công trình phần ngoài nhà - Hồ sơ bản vẽ thi công.
http://www.my.opera.com/tazzan/homes...goai%20nha.doc
TCVN 5687 :1992 Thông gió,điều tiết không khí,sưởi ấm - Tiêu chuẩn thiết kế
http://www.my.opera.com/tazzan/homes...0suoi%20am.doc
TCVN 5828 :1994 Đèn điện chiếu sáng đường phố - Yêu cầu kĩ thuật chung.
http://my.opera.com/khonggiansong/ho...uong%20pho.doc
TCXDVN 25 :1991 Đặt đường dẫn điện trong nhà ở và công trình công cộng - Tiêu chuẩn thiết kế
http://www.my.opera.com/tazzan/homes...ONG%20CONG.doc
TCXDVN 27 :1991 Đặt thiết bị điện trong nhà ở và công trình công cộng.Tiêu chuẩn thiết kế
http://www.my.opera.com/tazzan/homes...027%201991.doc
TCVN 29 :1991 Chiếu sáng tự nhiên trong công trình dân dụng.Tiêu chuẩn thiết kế ( file nặng lắm )
http://my.opera.com/khonggiansong/ho...dan%20dung.doc
TCVN 95 :1983 Tiêu chuẩn thiết kế chiếu sáng nhân tạo bên ngoài công trình xây dựng dân dụng
http://www.my.opera.com/tazzan/homes...en%20ngoai.doc
TCVN 185 :1986 Hệ thống tài liệu thiết kế - Ký hiệu bằng hình vẽ trên sơ đồ điện,thiết bị điện và dây dẫn trên mặt bằng.
http://tcxdvn.xaydung.gov.vn/tcxdvn/...ElemFormat=gif
TCVN 3743 :1983 Chiếu sáng nhân tạo các nhà công nghiệp và công trình công nghiệp
http://my.opera.com/khonggiansong/ho...nhan%20tao.doc
TCXDVN 183:1996 Máy bơm.Sai số lắp đặt
http://www.my.opera.com/tazzan/homes...0MAY%20BOM.doc
International standards for Electrical Installation
IEC 60038 Standard voltages
IEC 60076-3 Power transformers - Insulation levels, dielectric tests and external clearances in air
IEC 60076-5 Power transformers - Ability to withstand short-circuit
IEC 60146 Semiconductor convertors - General requirements and line commutated convertors
IEC 60255 Electrical relays
IEC 60265-1 High-voltage switches - High-voltage switches for rated voltages above 1 kV and less than 52 kV
IEC 60269-2 Low-voltage fuses - Supplementary requirements for fuses for use by unskilled persons (fuses mainly for household
and similar applications)
IEC 60282-1 High-voltage fuses - Current-limiting fuses
IEC 60287-1-1 Electric cables - Calculation of the current rating - Current rating equations (100% load factor) and calculation of
losses - General
IEC 60364 Electrical installations of buildings
IEC 60364-4-41 Electrical installations of buildings - Protection for safety - Protection against electric shock
IEC 60364-4-42 Electrical installations of buildings - Protection for safety - Protection against thermal effects
IEC 60364-4-43 Electrical installations of buildings - Protection for safety - Protection against overcurrent
IEC 60364-4-44 Electrical installations of buildings - Protection for safety - Protection against electromagnetic and voltage
disrurbance
IEC 60364-5-51 Electrical installations of buildings - Selection and erection of electrical equipment - Common rules
IEC 60364-5-52 Electrical installations of buildings - Selection and erection of electrical equipment - Wiring systems
IEC 60364-5-53 Electrical installations of buildings - Selection and erection of electrical equipment - Isolation, switching and
control
IEC 60364-5-54 Electrical installations of buildings - Selection and erection of electrical equipment - Earthing arrangements
IEC 60364-5-55 Electrical installations of buildings - Selection and erection of electrical equipment - Other equipments
IEC 60364-6-61 Electrical installations of buildings - Verification and testing - Initial verification
IEC 60364-7-701 Electrical installations of buildings - Requirements for special installations or locations - Locations containing a
bath tub or shower basin
IEC 60364-7-702 Electrical installations of buildings - Requirements for special installations or locations - Swimming pools and
other basins
IEC 60364-7-703 Electrical installations of buildings - Requirements for special installations or locations - Locations containing
sauna heaters
IEC 60364-7-704 Electrical installations of buildings - Requirements for special installations or locations - Construction and
demolition site installations
IEC 60364-7-705 Electrical installations of buildings - Requirements for special installations or locations - Electrical installations of
agricultural and horticultural
premises
IEC 60364-7-706 Electrical installations of buildings - Requirements for special installations or locations - Restrictive conducting
locations
IEC 60364-7-707 Electrical installations of buildings - Requirements for special installations or locations - Earthing requirements
for the installation of data
processing equipment
IEC 60364-7-708 Electrical installations of buildings - Requirements for special installations or locations - Electrical installations in
caravan parks and caravans
IEC 60364-7-709 Electrical installations of buildings - Requirements for special installations or locations - Marinas and pleasure
craft
IEC 60364-7-710 Electrical installations of buildings - Requirements for special installations or locations - Medical locations
IEC 60364-7-711 Electrical installations of buildings - Requirements for special installations or locations - Exhibitions, shows and
stands
IEC 60364-7-712 Electrical installations of buildings - Requirements for special installations or locations - Solar photovoltaic (PV)
power supply systems
IEC 60364-7-713 Electrical installations of buildings - Requirements for special installations or locations - Furniture
IEC 60364-7-714 Electrical installations of buildings - Requirements for special installations or locations - External lighting
installations
IEC 60364-7-715 Electrical installations of buildings - Requirements for special installations or locations - Extra-low-voltage
lighting installations
IEC 60364-7-717 Electrical installations of buildings - Requirements for special installations or locations - Mobile or transportable
units
IEC 60364-7-740 Electrical installations of buildings - Requirements for special installations or locations - Temporary electrical
installations for structures,
Electrical installation guide 2009- Schneider Electric- Rules and statutory regulations: standards
- 2 -
amusement devices and booths at fairgrounds, amusement parks and circuses
IEC 60427 High-voltage alternating current circuit-breakers
IEC 60439-1 Low-voltage switchgear and controlgear assemblies - Type-tested and partially type-tested assemblies
IEC 60439-2 Low-voltage switchgear and controlgear assemblies - Particular requirements for busbar trunking systems (busways)
IEC 60439-3 Low-voltage switchgear and controlgear assemblies - Particular requirements for low-voltage switchgear and
controlgear assemblies intended to
be installed in places where unskilled persons have access for their use - Distribution boards
IEC 60439-4 Low-voltage switchgear and controlgear assemblies - Particular requirements for assemblies for construction sites
(ACS)
IEC 60446 Basic and safety principles for man-machine interface, marking and identification - Identification of conductors by
colours or numerals
IEC 60439-5 Low-voltage switchgear and controlgear assemblies - Particular requirements for assemblies intended to be installed
outdoors in public places
- Cable distribution cabinets (CDCs)
IEC 60479-1 Effects of current on human beings and livestock - General aspects
IEC 60479-2 Effects of current on human beings and livestock - Special aspects
IEC 60479-3 Effects of current on human beings and livestock - Effects of currents passing through the body of livestock
IEC 60529 Degrees of protection provided by enclosures (IP code)
IEC 60644 Spécification for high-voltage fuse-links for motor circuit applications
IEC 60664 Insulation coordination for equipment within low-voltage systems
IEC 60715 Dimensions of low-voltage switchgear and controlgear. Standardized mounting on rails for mechanical support of
electrical devices in switchgear
and controlgear installations.
IEC 60724 Short-circuit temperature limits of electric cables with rated voltages of 1 kV (Um = 1.2 kV) and 3 kV (Um = 3.6 kV)
IEC 60755 General requirements for residual current operated protective devices
IEC 60787 Application guide for the selection of fuse-links of high-voltage fuses for transformer circuit application
IEC 60831 Shunt power capacitors of the self-healing type for AC systems having a rated voltage up to and including 1000 V -
General - Performance, testing
and rating - Safety requirements - Guide for installation and operation
IEC 60947-2 Low-voltage switchgear and controlgear - Circuit-breakers
IEC 60947-3 Low-voltage switchgear and controlgear - Switches, disconnectors, switch-disconnectors and fuse-combination units
IEC 60947-4-1 Low-voltage switchgear and controlgear - Contactors and motor-starters - Electromechanical contactors and
motor-starters
IEC 60947-6-1 Low-voltage switchgear and controlgear - Multiple function equipment - Automatic transfer switching equipment
IEC 61000 Electromagnetic compatibility (EMC)
IEC 61140 Protection against electric shocks - common aspects for installation and equipment
IEC 61557-1 Electrical safety in low-voltage distribution systems up to 1000 V AC and 1500 V DC - Equipment for testing,
measuring or monitoring of protective
measures - General requirements
IEC 61557-8 Electrical safety in low-voltage distribution systems up to 1000 V AC and 1500 V DC - Equipment for testing,
measures
IEC 61557-9 Electrical safety in low-voltage distribution systems up to 1000 V AC and 1500 V DC - Equipment for insulation fault
location in IT systems
IEC 61557-12 Electrical safety in low-voltage distribution systems up to 1000 V AC and 1500 V DC - Equipment for testing,
measures. Performance measuring and monitoring devices (PMD)
IEC 61558-2-6 Safety of power transformers, power supply units and similar - Particular requirements for safety isolating
transformers for general use
IEC 62271-1 Common specifications for high-voltage switchgear and controlgear standards
IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-breakers
IEC 62271-102 High-voltage switchgear and controlgear - Alternating current disconnectors and earthing switches
IEC 62271-105 High-voltage switchgear and controlgear - Alternating current switch-fuse combinations
IEC 62271-200 High-voltage switchgear and controlgear - Alternating current metal-enclosed switchgear and controlgear for rated
and including 52 kV
IEC 62271-202 High-voltage/low voltage prefabricated substations
The Following 11 Users Say Thank You to realcuong For This Useful Post:
22-06-2010, 20:36 #9
Ðề: Tổng hợp các tiêu chuẩn IEC
tiêu chuẩn IEC 60060
http://www.data.webdien.com/free/dow...58d4de44dba97aChuyên dịch vụ thi công - sửa chữa - bảo trì:
dienlanhtainha.net
19-09-2010, 17:18 #10
Ðề: Một số tiêu chuẩn IEC cần biết
IEEE khác hoàn toàn so với IEC. Đống tiêu chuẩn này chính là mình đã post rất lâu rồi. Mọi ng có thể down gộp các tiêu chuẩn
Code:http://ifile.it/z6sjmuk/iecstandards.part1.rar http://ifile.it/9ozptkr/iecstandards.part2.rar http://ifile.it/9nj17rl/iecstandards.part3.rar http://ifile.it/w82g4ud/iecstandards.part4.rar
The Following 2 Users Say Thank You to tvdhp For This Useful Post:
Trợ giúp - chuông báo hiệu: bạn hãy vẽ 1 mạch gồm 1 công tắc điều khiển cho 6 chuông
Bởi xuanhoc trong diễn đàn Thiết bị điện gia dụngTrả lời: 16Bài cuối: 12-08-2013, 22:37 -
Thảo luận - So sánh ưu và nhược điểm giữa chuẩn rs232 và chuẩn usb 2.0
Bởi quockhanhvt1991 trong diễn đàn Vi xử lý - Vi điều khiểnTrả lời: 0Bài cuối: 03-12-2012, 17:14
