  • Trang 1 của 4 1234 CuốiCuối
    Kết quả 1 đến 10 của 40
      Được cảm ơn 553 lần, trong 200 bài
      Mặc định [HOT] bộ IEC standards
      Trọn bộ bao gồm:
      60364-3 Electrical Installations of Buildings
      IEC 60044 Instrument Transformers
      IEC 60071 Insulation Co-Ordination
      IEC 60076 Power transformers
      IEC 60079 Electrical apparatus for explosive gas atmospheres
      IEC 60092_375 General Instrumentation, Control & Communication Cables
      IEC 60228 Conductors of Insluated Cables
      IEC 60245 Rubber Insulated Cables
      IEC 60255 Electrical relays
      IEC 60269 Low-voltage fuses
      IEC 60331 Fire Resisting Charecteristics of Electric Cables
      IEC 60332 Tests on electric cables under fire conditions
      IEC 60364 Electrical installations of buildings
      IEC 60439 Low-voltage switchgear and controlgear assemblies
      IEC 60529 Degrees of protection provided by enclosures (IP Code)
      IEC 60534 Industrial Process Control Valves - Terminology & General Considerations
      IEC 60584 Thermocouples
      IEC 60726 Dry Type Power Transmformers
      IEC 60694 Common specifications for high -voltage switchgear and controlgear standards
      IEC 60751 Industrial platinum resistance thermometer Sensors
      IEC 60793-1-44 Optical fibres - Measurement methods and test procedures - Cut-off wavelength
      IEC 60874-14-4 Connectors for optical fibres and cables - Detail specification for fibre optic adaptor (simplex) type SC for multimode fibre
      IEC 60909-0 Short-circuit currents in three-phase a.c. systems - Calculation of currents
      IEC 60947 Low-voltage switchgear and controlgear
      IEC 61131 Programmable controllers
      IEC 61158 Overview and guidance for the IEC 61158 series.
      IEC 61511 Part-1 Framework, definitions, system, hardware and software requirements.
      IEC 61831 On-line analyser systems - Guide to design and installation
      IEC 61832 Analyser systems - Guide to technical enquiry & Bid Evaluation
      IEC 61892-6 Mobile and fixed offshore units - Electrical installations
      IEC 62086 Electrical apparatus for explosive gas atmospheres
      IEC 62271 High-voltage switchgear and controlgear
      IEC PAS 62030 Real-Time Publish-Subscribe (RTPS) Wire Protocol Specification Version 1.0.pdf
      IEC TR 62095 Electric cables - Calculations for current ratings - Finite element method.pdf
      IEC TR 62271-310 High-voltage switchgear and controlgear - Electrical endurance testing for circu.pdf
      Copyright by the International Electrotechnical Commission
      Báo Link die + không down được liên hệ YM/Skype: hoangminh5690
      wd.support
      Link Mediafire
      Pass (nếu có): webdien.com
      Bonus:
      Bộ những tiêu chuẩn IEC đã được dịch sang tiếng Việt:
      link: http://webdien.com/d/showthread.php?p=193982
      Link Megaupload của bộ IEC Standards, link đảm bảo sống nhăn răng, Cần tiêu chuẩn nào down luôn cái đó, không có pass:
      Hướng dẫn: Click vào link nó hiện ra cái bản chọn no thanks, tới phần download bấm chọn agree, các bác cần cập nhật Flash Player mới để có thể down nhé (bây giờ máy nào cũng có Flash Player mới rồi ghi chú thêm thôi)
      Bản cập nhật Flashplayer mới nhất cho bác nào chưa có:tại đây
      IEC60364-3 Electrical Installations of Buildings.pdf (2.8 MB)
      https://mega.co.nz/#!NRk3XKID!UAxNuS...GyY2zK9ZKLIj2M
      IEC 60044-1 Instrument Transformers Part-1 Current Transformers.pdf (4.9 MB)
      https://mega.co.nz/#!wI8zTDrJ!MWbpFH...u8vb5Dxl4XSGJ0
      IEC 60071-1 Insulation Co-Ordination - Definitions, principles and rules.pdf (2.5 MB)
      https://mega.co.nz/#!UY8Q3ayQ!Zd3m1C...s7uLvuMesSiS5Q
      IEC 60071-2 Insulation Co-Ordination - Application guide.pdf (13.9 MB)
      https://mega.co.nz/#!QNliUDDC!cwgFQR...WSWlbr5TAIo6uQ
      IEC 60071-4 Insulation Co-Ordination - Computational guide to insulation co-ordination and modell.pdf (1.9 MB)
      https://mega.co.nz/#!Yd9WWDBK!f4Z7fU...-cKOSBE5gxVFoI
      IEC 60076-1 Power transformers - General.pdf (4.3 MB)
      https://mega.co.nz/#!lIt1QLYR!ehY7Ow...JJ6U9WA94ztB1c
      IEC 60076-10 Power transformers - Determination of sound levels.pdf (758 KB)
      https://mega.co.nz/#!BMElUBaI!KpsTVT...4ESGFrVdq8I6pE
      IEC 60076-2 Power transformers - Temperature rise.pdf (3.0 MB)
      https://mega.co.nz/#!REEnwYgC!Erwhs1...R7XAewjLfUum1Q
      IEC 60076-3 Power transformers - Insulation levels, dielectric tests and external clearances in a.pdf (5.7 MB)
      https://mega.co.nz/#!sIUClYiZ!Xev4n2...hpyzPuHP72mLSs
      IEC 60076-4 Power transformers - Guide to the lightning impulse and switching impulse testing.pdf (2.8 MB)
      https://mega.co.nz/#!dRdlXLJb!YGNbel...luk7VCvAeBF4AI
      IEC 60076-5 Power transformers - Ability to withstand short circuit.pdf (2.4 MB)
      https://mega.co.nz/#!kINjWIqR!RwGUsw...vBJ4xEfbYCz_xM
      IEC 60076-8 Power transformers - Application guide.pdf (1.0 MB)
      https://mega.co.nz/#!FcsimA4J!FBObnD...aoTz-SuZGDn-9M
      IEC 60079-1 Electrical apparatus for explosive gas atmospheres - Flameproof enclosures 'd'.pdf (1.4 MB)
      https://mega.co.nz/#!xUtCFQiB!EQRYeg...WJoibskCs-SYME
      IEC 60079-10 Electrical apparatus for explosive gas atmospheres - Classification of hazardous areas.pdf (1005 KB)
      https://mega.co.nz/#!FVFzEKhD!SaynJj...c5EQr7CUfw-DQ8
      IEC 60079-11 Electrical apparatus for explosive gas atmospheres - Intrinsic safety 'i'.pdf (1.1 MB)
      https://mega.co.nz/#!oRNDgBba!LKKh9l...4SghzIqH9tCW94
      IEC 60079-14 Electrical apparatus for explosive gas atmospheres - Electrical installations in hazardous areas.pdf (1008 KB)
      https://mega.co.nz/#!0El0nAqZ!FC7Az2...UNKDiaHDKXOvCw
      IEC 60079-15 Electrical apparatus for explosive gas atmospheres - Construction, test and marking of type of protection n electrical apparatus.pdf (1.6 MB)
      https://mega.co.nz/#!AIk3iYRC!XlKL_m...LbtG3oq5RCM__w
      IEC 60079-2 Electrical apparatus for explosive gas atmospheres - Pressurized enclosures 'p'P.pdf (508 KB)
      https://mega.co.nz/#!xQNRRBCa!BZO39x...lBbyblzuW2Wl6w
      IEC 60079-27 Fieldbus intrinsically safe concept (FISCO) and Fieldbus non-incendive concept (FNICO).pdf (491 KB)
      https://mega.co.nz/#!1AsBDAKI!SOKrjR...PxgKZnDhchfXkQ
      IEC 60079-4 Method of test for ignition temperature.pdf (1.0 MB)
      https://mega.co.nz/#!sUsxWJrK!Llz2Wy...jvlNj3lNEQTo2U
      IEC 60079-5 Electrical apparatus for explosive gas atmospheres - Powder Filling 'q'.pdf (1.7 MB)
      https://mega.co.nz/#!oZlEAQBS!e6Mgqn...hPSAzvNG5TJw_o
      IEC 60079-6 Electrical apparatus for explosive gas atmospheres - Oil-immersion 'o'.pdf (487 KB)
      https://mega.co.nz/#!AM9TzQrS!PtKpTm...bywSsHAcw4KUq8
      IEC 60079-7 Electrical apparatus for explosive gas atmospheres - Increased safety 'e'.pdf (6.6 MB)
      https://mega.co.nz/#!MU9ywADL!OikTrV...XHOFeOIwgeKf24
      IEC 60092-350 Elecetrical Installations in Ship.pdf (1.6 MB)
      https://mega.co.nz/#!xU8UCBiZ!ItHXfD...Kom5uRxzN6SSe0
      IEC 60092-352 Choice & Installation of Cables for Low Voltage Power Systems.pdf (2.9 MB)
      https://mega.co.nz/#!4YtxhLRJ!BAaglU...0y3n4zNz2Q25cc
      IEC 60092-375 Ship board telecommunication cables and radio-frequency cables - General instrumentation, control and communication cables.pdf (1.1 MB)
      https://mega.co.nz/#!EUF3mCLC!JB1auk...QdJF9PDdnIL1lA
      IEC 60092_375 General Instrumentation, Control & Communication Cables.pdf (960 KB)
      https://mega.co.nz/#!BId22Brb!ZDx-XR...UGl_CvfXsyAUKY
      IEC 60092_376 Cable for Control & Instrumentation Circuits.pdf (434 KB)
      https://mega.co.nz/#!kcV2lJZD!NQfF6W...sujoUSuA97R6Ds
      IEC 60228 Conductors of Insluated Cables.PDF (1.7 MB)
      https://mega.co.nz/#!0EVi1JSJ!F53JSH...tTHZgnKhPRrBUM
      IEC 60245-3 Rubber Insulated Cables.pdf (1.2 MB)
      https://mega.co.nz/#!5dd2xRLB!blMDIR...EkbM3JLdH5Vzmo
      IEC 60255-13 Electrical relays - Biased (percentage) differential relays.pdf (1.2 MB)
      https://mega.co.nz/#!NIcSSLLJ!H9cSbA...CfmfpjZlNlj-DA
      IEC 60255-22-5 Electrical relays - Electrical disturbance tests for measuring relays and protecti.pdf (577 KB)
      https://mega.co.nz/#!8ZlFTCSB!dBMcXm...It3pKEwW5ZymvE
      IEC 60255-23 Electrical Relays - Contact Performance.pdf (5 KB)
      https://mega.co.nz/#!5Yk32LwJ!c64B6V...jNrMl1GTrno86c
      IEC 60255-24 Electrical relays - Common format for transient data exchange (COMTRADE) for power s.pdf (5.5 MB)
      https://mega.co.nz/#!9ZtGiLaI!Ylk273...vPOPkdsx0861rA
      IEC 60255-3 Electrical relays - Single input energizing quantity measuring relays with dependent .pdf (1013 KB)
      https://mega.co.nz/#!cYMAyD5A!LPy7aR...390gTVCTWZm1iQ
      IEC 60255-5 Electrical relays - Insulation coordination for measuring relays and protection equip.pdf (3.0 MB)
      https://mega.co.nz/#!NVVSgRaS!VqJ3hh...iG2xHFuJ3Y-sn8
      IEC 60255-6 Electrical relays - Measuring relays and protection equipment.pdf (2.1 MB)
      https://mega.co.nz/#!5QM2wSJY!Yqnxw0...U-u7sH2BFjQVJE
      IEC 60255-8 Electrical relays - Thermal electrical relays.pdf (1.4 MB)
      https://mega.co.nz/#!MJFjCZ7C!MFLY11...WqlGtwcWREgqZo
      IEC 60269-1 Low-voltage fuses - General requirements.pdf (6.2 MB)
      https://mega.co.nz/#!FYMFDAQL!RU-Zrg...he-1PHnDz4WKcE
      IEC 60269-2 Low-voltage fuses - Supplementary requirements for fuses for use by authorized person.pdf (1.1 MB)
      https://mega.co.nz/#!sIdDRLaT!KEBSz1...gZMVYC7-7rGC48
      IEC 60269-2-1 Low-voltage fuses - Supplemetary Requirements for Fuses for use by authorized perso.pdf (6.2 MB)
      https://mega.co.nz/#!RJUznQZZ!c0hM8H...1Ks9JST50SqRek
      IEC 60269-4 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of s.pdf (4.3 MB)
      https://mega.co.nz/#!pNEQESCA!SEAUBQ...Ly6lIRqqAR1daQ
      IEC 60269-4-1 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of.pdf (577 KB)
      https://mega.co.nz/#!EBEGEAYS!XEOMQz...g9UEj3IsZ3bYgE
      IEC 60298 A.C. metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to .pdf (7.5 MB)
      https://mega.co.nz/#!FM9DRbzC!X6c3yx...hfABkdYzNxPX9I
      IEC 60331 Fire Resisting Charecteristics of Electric Cables.PDF (432 KB)
      https://mega.co.nz/#!0NsCVC7Z!E3UbAQ...bq9aMNsewhmDYc
      IEC 60331-11 Test on Electrical Cables Under Fire Condition.pdf (222 KB)
      https://mega.co.nz/#!hYFRwRLR!Tcul2g...heXNEi7KurqYqE
      IEC 60331-12 Test on Electrical Cables Under Fire Condition.pdf (591 KB)
      https://mega.co.nz/#!1MFSDDRT!VZQhgH...i1RStHjMk8v0kU
      IEC 60331-31 Test on Electrical Cables Under Fire Condition.pdf (936 KB)
      https://mega.co.nz/#!dZ8URK5Q!KMxxEw...8iblVCVevYhtnY
      IEC 60332-1 Tests on electric cables under fire conditions - Test on a single vertical insulated .pdf (1013 KB)
      https://mega.co.nz/#!hA0RHADa!PRk9bi...XIbgBR13kG1bjg
      IEC 60332-1_1 Tests on electric and optical fibre cables Under Fire Condition.pdf (399 KB)
      https://mega.co.nz/#!EM0nnCQK!cnKWDH...GHo3O9jZ_56aK8
      IEC 60332-1_2 Tests on electric and optical fibre cables Under Fire Condition.pdf (439 KB)
      https://mega.co.nz/#!lEFUBCZa!NvJDIX...EhiGsgITv6YIbk
      IEC 60332-1_3 Tests on electric and optical fibre cables Under Fire Condition.pdf (429 KB)
      https://mega.co.nz/#!9Z0xjLAT!e-Pz62...uoK0aAaAl0W0oQ
      IEC 60332-2 Tests on electric cables under fire conditions - Test on a single small vertical insu.pdf (683 KB)
      https://mega.co.nz/#!1NsGhCgK!UORVDi...Y8pr5MBV6SKqn4
      IEC 60332-2_1 Tests on electric and optical fibre cables Under Fire Condition.pdf (438 KB)
      https://mega.co.nz/#!xNsFRRoL!aLkiqk...2ULfDaZGkzdqp8
      IEC 60332-2_2 Tests on electric and optical fibre cables Under Fire Condition.pdf (464 KB)
      https://mega.co.nz/#!ZVVBXIAJ!EeMh_0...sYDU_jZDH_7jJQ
      IEC 60332-3-10 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf (1.4 MB)
      https://mega.co.nz/#!ccEWkATb!Gs2lDn...HWg9DPYGlwZYO4
      IEC 60332-3-21 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf (1.1 MB)
      https://mega.co.nz/#!8JkgjKxB!YPZw8m...S_fhFyuLSFNHtg
      IEC 60332-3-22 Test on Electrical Cables Under Fire Condition.pdf (1.0 MB)
      https://mega.co.nz/#!9Qt0AIAC!KwyFE1...EfzaiN-DQdC-K4
      IEC 60332-3-22 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf (1.2 MB)
      https://mega.co.nz/#!kJ8QFBJB!XhO7vR...THJmdWErnElnpY
      IEC 60332-3-23 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf (1.2 MB)
      https://mega.co.nz/#!dEkxibjB!M1NEQS...6DNQiuPCpkevv0
      IEC 60332-3-24 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf (1.2 MB)
      https://mega.co.nz/#!8JVFGYRB!YwNinX...DVyMnFRwoikFac
      IEC 60332-3-25 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf (1.1 MB)
      https://mega.co.nz/#!4YllXSJa!Qi3zeW...rqsVBt7IbLO-2A
      IEC 60364-1 Electrical installations of buildings - Fundamental principles, assessment of general.pdf (843 KB)
      https://mega.co.nz/#!5VN31Rgb!K982OB...ZW7oDAoXaofKvM
      IEC 60364-5-52 Electrical installations of buildings - Selection and erection of electrical equip.pdf (5.8 MB)
      https://mega.co.nz/#!9U9ERJzS!Up2JYH...YpdPuI3s7G7K_w
      IEC 60364-5-54 Electrical installations of buildings - Selection and erection of electrical equip.pdf (1.4 MB)
      https://mega.co.nz/#!AJEGjS4b!Cqi6xw...lHIshSAyFv2xiQ
      IEC 60364-5-548 Electrical installations of buildings - Selection and erection of electrical equi.pdf (1.7 MB)
      https://mega.co.nz/#!QFVS0CZL!Q4w_uU...0jtHGnBKIIMWB0
      IEC 60364-5-55 Electrical installations of buildings - Selection and erection of electrical equip.pdf (690 KB)
      https://mega.co.nz/#!BIUAlRJa!W0bOYF...cr6fgxvkbXLFj0
      IEC 60364-5-56 Electrical installations of buildings - Selection and erection of electrical equip.pdf (649 KB)
      https://mega.co.nz/#!xZlXnKSb!cMD81R...8zxZs05y9FwA_g
      IEC 60364-7-707 Electrical installations of buildings - Requirements for special installations or.pdf (982 KB)
      https://mega.co.nz/#!AcsiDb6a!FF936S..._J4EVJba4YaCEY
      IEC 60439-1 Low-voltage switchgear and controlgear assemblies - Type-tested and partially ty.pdf (1.7 MB)
      https://mega.co.nz/#!ZdMU1B5J!RbMJtS...U3wAdkxCYpMqEo
      IEC 60439-2 Low-voltage switchgear and controlgear assemblies - Particular requirements for busba.pdf (3.1 MB)
      https://mega.co.nz/#!cEdEjLoR!LcIbAC...Ee0wALIhP9eh5Y
      IEC 60439-3 Low-voltage switchgear and controlgear assemblies - Particular requirements for Iow-v.pdf (2.0 MB)
      https://mega.co.nz/#!oI0BEIBS!OorHQh...w-L9ud11Cmx92A
      IEC 60439-4 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf (2.1 MB)
      https://mega.co.nz/#!xEUhWRZJ!OiAOIw...FBP89JCgTqjUcM
      IEC 60439-5 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf (2.3 MB)
      https://mega.co.nz/#!QRcE3I4T!RN3VA0...p7OrMVhA2ThJ5k
      IEC 60502-1 Power cables with extruded insulation and their accessories for rated voltages.pdf (909 KB)
      https://mega.co.nz/#!9M0DVaZK!XR87wE...uZ6Me0QRpGidNk
      IEC 60502-2 Power cables with extruded insulation and their accessories for rated voltages.pdf (4.7 MB)
      https://mega.co.nz/#!NIMWlBDI!QK_yRR...zH-7DZPqeY1e9A
      IEC 60502-4 Power cables with extruded insulation and their accessories for rated voltages.pdf (572 KB)
      https://mega.co.nz/#!QUdmgZaD!KkfRzG...tndeDynGWa4YMw
      IEC 60529 Degrees of protection provided by enclosures (IP Code).pdf (1.6 MB)
      https://mega.co.nz/#!tRtGGSpI!J5RdO3...ckIse4f_ar4x8M
      IEC 60534-1 Industrial Process Control Valves - Terminology & General Considerations.pdf (987 KB)
      https://mega.co.nz/#!Jdd3nZAT!Zp9gaD...jYlkzMQTCLw8To
      IEC 60534-2_1 Industrial Process Control Valves - Flow capacity Equations.pdf (2.3 MB)
      https://mega.co.nz/#!RRk0SQ5I!LmI80g...b5i1q7usC9CR4A
      IEC 60534-2_3 Industrial Process Control Valves - Flow capacity Equations.pdf (293 KB)
      https://mega.co.nz/#!lId1AT4K!H7BjT2...AHspAEnV3veRZ8
      IEC 60534-2_4 Industrial Process Control Valves - Flow capacity Equations.pdf (692 KB)
      https://mega.co.nz/#!YRdHjYYD!TaVTwk...Ymzjl7NMMfvVx4
      IEC 60534-2_5 Industrial Process Control Valves - Flow capacity Equations.pdf (899 KB)
      https://mega.co.nz/#!UdMmxTbR!PLWmLX...WcuRMQkQuyRR-Q
      IEC 60534-3 Industrial Process Control Valves - Dimensions.pdf (348 KB)
      https://mega.co.nz/#!MAFSzSqR!RmdT6V...i_A5KUOb7BYuBQ
      IEC 60534-3_1 Industrial Process Control Valves - Dimensions.pdf (332 KB)
      https://mega.co.nz/#!hJs0CK6a!SmMhyk...6EvZ0lsb299vyU
      IEC 60534-3_2 Industrial Process Control Valves - Dimensions.pdf (112 KB)
      https://mega.co.nz/#!gI0FFYJC!XherGE...uVPBwpSIcfrlsc
      IEC 60534-3_3 Industrial Process Control Valves - Dimensions.pdf (82 KB)
      https://mega.co.nz/#!wYMGWC4S!VMxvOA...1DcpjCWweDecSs
      IEC 60534-4 Industrial Process Control Valves - Inspection & Routine Testing.pdf (191 KB)
      https://mega.co.nz/#!cYsAgKDC!LZxrk1...Xgf4ESADbaXJxD
      KsNkpU
      IEC 60534-5 Industrial Process Control Valves - Marking.pdf (545 KB)
      https://mega.co.nz/#!8Z1liCST!dB2v0k...yvC5z6GAo3mYv4
      IEC 60534-6 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf (580 KB)
      https://mega.co.nz/#!IBsWUazZ!Jygjwi...mrEywiNYBK92-Y
      IEC 60534-6_1 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf (530 KB)
      https://mega.co.nz/#!BN0gyLAa!HQaH40...o9jwXZiW8e2K24
      IEC 60534-6_2 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf (115 KB)
      https://mega.co.nz/#!QF1mUZQA!aMF3U2...X3LSGIWFvBbJtk
      IEC 60534-7 Industrial Process Control Valves - Data Sheet.pdf (1.2 MB)
      https://mega.co.nz/#!RM9T3aIC!ePAnSg...LztzPjWo5JWNsM
      IEC 60534-8_1 Industrial Process Control Valves - Noise Considerations.pdf (798 KB)
      https://mega.co.nz/#!0EUnHLgZ!QZsAhT...zd8zXA7chd0vMI
      IEC 60534-8_2 Industrial Process Control Valves - Noise Considerations.pdf (1.2 MB)
      https://mega.co.nz/#!8FtSHRhA!FP8EOF...Z6oY35JrZO3wlQ
      IEC 60534-8_3 Control valve aerodynamic noise prediction method.pdf (948 KB)
      https://mega.co.nz/#!9UcwXL6D!PbHvDn...l8FHb0-CTykEGI
      IEC 60534-8_4 Industrial Process Control Valves - Noise Considerations.pdf (1010 KB)
      https://mega.co.nz/#!IEtjXB5A!ekMoPg...MKGdO-pma5hFtQ
      IEC 60584-1 Thermocouples - Reference tables.pdf (7.8 MB)
      https://mega.co.nz/#!NA9CXaaY!f6ViHS...CuV2pKp6DZMNls
      IEC 60584-2 Thermocouples - Tolerances.pdf (556 KB)
      https://mega.co.nz/#!JA9BHJJb!LOPyvm...nfiF_DYlhtap6g
      IEC 60584-3 Thermocouples - Extension and compensating cables.pdf (490 KB)
      https://mega.co.nz/#!ZB9nFBiC!EO3QPA...OEwDvYKk93mIF4
      IEC 60694 Common specifications for high -voltage switchgear and controlgear standards.pdf (12.2 MB)
      https://mega.co.nz/#!dZMkhS5C!EQj3rW...5MeVJhsK-2tBWI
      IEC 60726 Dry Type Power Transmformers.PDF (1.6 MB)
      https://mega.co.nz/#!IJ9RTRCR!DWcm_Q...XZStDcAA71GW-Q
      IEC 60751 Industrial platinum resistance thermometer Sensors.pdf (2.5 MB)
      https://mega.co.nz/#!kN9HWRAB!HtPCUG...yWs2aTaiYbHOco
      IEC 60793-1-44 Optical fibres - Measurement methods and test procedures - Cut-off wavelength.pdf (469 KB)
      https://mega.co.nz/#!9Us0GQKQ!TUbPjS...ICkjikdwtprwEU
      IEC 60874-14-4 Connectors for optical fibres and cables - Detail specification for fibre optic adaptor (simplex) type SC for multimode fibre.pdf (144 KB)
      https://mega.co.nz/#!tF8FAZQb!dXF8KU...h9pb_FtTZEzC7c
      IEC 60909-0 Short-circuit currents in three-phase a.c. systems - Calculation of currents.pdf (6.2 MB)
      https://mega.co.nz/#!kBFxkR7J!Fj2lX3...KSOW01Cc6mY31k
      IEC 60909-1 Short-circuit currents in three-phase a.c. systems - Factors for the calculation of s.pdf (3.2 MB)
      https://mega.co.nz/#!4NsnSCia!EpDIGS...HL7XcBS1AHNdf4
      IEC 60909-2 Electrical equipment - Data for short-circuit current calculations.pdf (2.5 MB)
      https://mega.co.nz/#!8V80ASzI!C6Jf0l...tsQz3e6OAHy-PA
      IEC 60909-3 Short-circuit currents in three-phase a.c. systems - Currents during two separate sim.pdf (1.3 MB)
      https://mega.co.nz/#!lMtknBpL!GMJJvj...4KLfaJ67a5W4xA
      IEC 60909-4 Short-circuit currents in three-phase a.c. systems - Examples for the calculation of .pdf (1.0 MB)
      https://mega.co.nz/#!dNs1HR5b!IYa1uz...ye74ez7XMTDq9s
      IEC 60947-1 Low-voltage switchgear and controlgear - General rules.pdf (15.1 MB)
      https://mega.co.nz/#!cB1iWShT!c8C5bl...I4sJ01PwQBMtDk
      IEC 60947-1-2004 Low-voltage switchgear and controlgear - General rules.pdf (2.3 MB)
      https://mega.co.nz/#!wJ8kXajQ!OzWwuX...1nGTE4815toN2I
      IEC 60947-2 Low-voltage switchgear and controlgear - Circuit Breakers.pdf (12.3 MB)
      https://mega.co.nz/#!oBlF2CSZ!N8a66j...jKYz3FunaLUmLI
      IEC 60947-3 Low-voltage switchgear and controlgear - Switches, disconnectors, switch-disconnector.pdf (5.0 MB)
      https://mega.co.nz/#!4clmFabK!RPEIFz...tleQqg_JoJhSHQ
      IEC 60947-4-1 Low-voltage switchgear and controlgear - Contactors and Motor Starters - Electromec.pdf (7.8 MB)
      https://mega.co.nz/#!NFUAlZ7L!EfPCvw...QxW86l3Uc_0xAA
      IEC 60947-4-2 Low-voltage switchgear and controlgear - Contactors and Motor Starters - AC Semicon.pdf (6.5 MB)
      https://mega.co.nz/#!gQFhQC4b!cHlI_y...F4KHN9UIEAlLKg
      IEC 60947-4-3 Low-voltage switchgear and controlgear - Contactors and motor-starters - AC semicon.pdf (6.2 MB)
      https://mega.co.nz/#!EY0XyZhY!VPLglw...fXyMxBkmF-M-to
      IEC 60947-6-1 Low-voltage switchgear and controlgear - Multiple function equipment - Automatic tr.pdf (3.9 MB)
      https://mega.co.nz/#!lcUnRIhY!RVbMIj...zKF4WEw5aOZb9U
      IEC 60947-6-2 Low-voltage switchgear and controlgear - Multiple function equipment - Control and .pdf (1.6 MB)
      https://mega.co.nz/#!9YV3EBjA!cH66PV...C56c8nnCUGlUf8
      IEC 60947-7-1 Low-voltage switchgear and controlgear - Ancillary equipment - Terminal blocks for .pdf (742 KB)
      https://mega.co.nz/#!tYdXTahK!XAzpGQ...YTHGo_zWY0l-6s
      IEC 61131-1 Programmable controllers - General information.pdf (350 KB)
      https://mega.co.nz/#!8ccDBZra!JAXaOz...8i_5tTxbtiPAyM
      IEC 61131-2 Programmable controllers - Equipment Requirements and Tests.pdf (5.6 MB)
      https://mega.co.nz/#!lQESSAZJ!S4QMQU...hhKcfYOH_B_CtU
      IEC 61131-3 Programmable controllers - Programming languages.pdf (1.3 MB)
      https://mega.co.nz/#!YI1nTQZK!M6lE3z...OvCMJq6mtSF5tE
      IEC 61131-4 Programmable controllers - User guidelines.pdf (986 KB)
      https://mega.co.nz/#!Vd11xBhT!ILJnq0...6TEjjadPENnV10
      IEC 61131-5 Programmable controllers - Communications.pdf (418 KB)
      https://mega.co.nz/#!gUkBiBwT!eJ5p2G...PmtWW6DfDGcz38
      IEC 61131-7 Programmable controllers - Fuzzy control programming.pdf (784 KB)
      https://mega.co.nz/#!VNVXxBxC!IDy1KD...GitMI-yVM_dp5o
      IEC 61131-8 Programmable controllers - Guidelines for the application and implementation of programming languages.pdf (806 KB)
      https://mega.co.nz/#!xdlXQIgC!L8xnFU...T9kXlOC2qozo_0
      IEC 61158-1 Overview and guidance for the IEC 61158 series.pdf (398 KB)
      https://mega.co.nz/#!cIFmSRAZ!MBw0B1...i_QbDkdgXqh5ug
      IEC 61158-2 Physical layer specification and service definition.pdf (13.9 MB)
      https://mega.co.nz/#!8Q9HESAR!CwOvx0...i8Mt1cGpeEcYXc
      IEC 61158-3 Data link service definition.pdf (1.8 MB)
      https://mega.co.nz/#!4NsTjZTL!OSW5By...Lrvuyf3X16KL8c
      IEC 61508 Part 1 - General Requirements.pdf (4.7 MB)
      https://mega.co.nz/#!JZ1RGDCQ!XrT233...5hbh1V0g93WDqs
      IEC 61508 Part 1 Addenda.pdf (14 KB)
      https://mega.co.nz/#!IZFFnBbD!DjRjOX...pFPNwFvvFmDm6I
      IEC 61508 Part 2 - Requirements for Electrical - Electronic programmable electronic safety-related systems.pdf (737 KB)
      https://mega.co.nz/#!lBl0AQgK!LyCWsi...alnFfw7CfmlJRQ
      IEC 61508 Part 3 - Software Requirements.pdf (3.8 MB)
      https://mega.co.nz/#!ZNUV1SSL!cjBLZB...gl_dyeGRN_UkGc
      IEC 61508 Part 3 Addenda.pdf (7 KB)
      https://mega.co.nz/#!0U0WxbgJ!KLod7l...NPaDO4AGlIF9jc
      IEC 61508 Part 4 - Definitions and Abbreviations.pdf (2.3 MB)
      https://mega.co.nz/#!FZtyjCYT!FY48JT...q5hKfZBlhYYpvU
      IEC 61508 Part 4 Addenda.pdf (15 KB)
      https://mega.co.nz/#!xEcQhCDS!dm1o8w...7YDh_hE9I6OlmE
      IEC 61508 Part 5 - Examples of Methods for the determination of safety integrity levels.pdf (2.3 MB)
      https://mega.co.nz/#!0BMS0ADB!HAkiEW...UAIMiXGL5bfKQY
      IEC 61508 Part 5 Addenda.pdf (7 KB)
      https://mega.co.nz/#!IJVzEQLI!ZcQ4-U...mD_Xe2Q1dQ5feg
      IEC 61508 Part 6 - Guidelines on the application of parts 2 and 3.pdf (871 KB)
      https://mega.co.nz/#!tUNH1RTS!IMSE5w...kUaisxDffRxRCs
      IEC 61508 Part 7 Overview of Techniques & Measures.pdf (3.9 MB)
      https://mega.co.nz/#!JM9nXCbA!QjOT3V...HKAluO1XqEmn-M
      IEC 61511 Part-1 Framework, definitions, system, hardware and software requirements.pdf (1.6 MB)
      https://mega.co.nz/#!4EkVWIxD!bQnW4W...YD1oDrtdyITmOw
      IEC 61511 Part-2 Guidelines in the application of IEC 61511-1 - Informative.pdf (1.4 MB)
      https://mega.co.nz/#!4U9ASaDI!YLmMET...BZOPBIjgFduwWk
      IEC 61511 Part-3 Guidance for the determination of safety integrity levels - informative.pdf (888 KB)
      https://mega.co.nz/#!hR1zyBBb!dL__cH...4z1kVC5MpGdJ3I
      IEC 61537 Cable tray systems and cable ladder systems.pdf (847 KB)
      https://mega.co.nz/#!INdDRJBJ!OMdiNG...O9cUgVZrDdQJ6s
      IEC 61831 On-line analyser systems - Guide to design and installation.pdf (756 KB)
      https://mega.co.nz/#!5AMkjRiT!MNRN6X...G4qKVLyjjho8gE
      IEC 61832 Analyser systems - Guide to technical enquiry & Bid Evaluation.pdf (504 KB)
      https://mega.co.nz/#!lY9REZQL!AGOlpS...KDrUH-0A12PL4E
      IEC 61892-6 Mobile and fixed offshore units - Electrical installations.pdf (128 KB)
      https://mega.co.nz/#!EVsgxRYJ!BMYX22...iif-f2iJ8E3UoY
      IEC 62086-1 Electrical apparatus for explosive gas atmospheres - Electrical resistance trace he.pdf (385 KB)
      https://mega.co.nz/#!QZ8XjICI!GMSbQ1...7VyHmLKa_-1v84
      IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-.pdf (7.9 MB)
      https://mega.co.nz/#!BBtmTKTK!aLfMDw...1N-IO-2wvbA0jU
      IEC 62271-102 High-voltage switchgear and controlgear - High-voltage alternating-current Disconne.pdf (3.9 MB)
      https://mega.co.nz/#!VA0SFAAB!Dwx68A...LESp2xJE-btmD8
      IEC 62271-105 High-voltage switchgear and controlgear - Alternating-current Switch Fuse Combinati.pdf (3.6 MB)
      https://mega.co.nz/#!kEMlxISa!Ry4nTV...KYSvrZy-bQQwHc
      IEC 62271-200 High-voltage switchgear and controlgear - AC metal-enclosed switchgear and controlg.pdf (2.0 MB)
      https://mega.co.nz/#!5UUnzZYY!Z3juVz...umo-As14wSbC-w
      IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear.pdf (1.2 MB)
      https://mega.co.nz/#!JUMQCQoD!MLFv-i...iYvDL8S68MS9dA
      IEC 62271-308 High-voltage switchgear and controlgear - Guide to Asymetrical shoet circuit breaki.pdf (1.8 MB)
      https://mega.co.nz/#!JINlCRpZ!DYlOmT...4l9hGQR00P_nUM
      IEC PAS 62030 Real-Time Publish-Subscribe (RTPS) Wire Protocol Specification Version 1.0.pdf (1.8 MB)
      https://mega.co.nz/#!4EMWQb4K!UJZzJV...0fTou1bCqdGZps
      IEC TR 62095 Electric cables - Calculations for current ratings - Finite element method.pdf (1.4 MB)
      https://mega.co.nz/#!MAM3nCbS!aJqgyQ...X8Ieso_jUmJLdA
      IEC TR 62271-310 High-voltage switchgear and controlgear - Electrical endurance testing for circu.pdf (812 KB)
      https://mega.co.nz/#!JVUTCSoI!JayGXz...NchV7KrhB8-dWc
      IEC 60079-4 Method of test for ignition temperature (1.0 MB)
      https://mega.co.nz/#!NE0jQIDR!Llz2Wy...jvlNj3lNEQTo2U
      Sửa bài, xóa bài, thắc mắc khi sử dụng diễn đàn... liên hệ: hoangminhpham@webdien.com
      [Hãy đọc] Tại sao bạn bị xóa bài và ban nick
      Tổng hợp các bài viết quan trọng trên webdien.com
      Trọn bộ IEC tiếng Việt
      Bấm vào link để ủng hộ webdien: Đèn pha led, đèn túyp led t8, đèn led âm trần, đèn ốp nổi, đèn led trang trí … hàng Dragon Taiwan bảo hành 2 năm.
      Mặc định Ðề: [HOT] bộ IEC standards
      pass là gì thế bạn ơi.
    3. Những thành viên đã cảm ơn nautel vì bài viết hữu ích:
      Được cảm ơn 17 lần, trong 11 bài
      Trích dẫn Gửi bởi nautel Xem bài viết
      Đọc cho kỹ vào bạn à.
      Dòng cuối cùng đó.
    5. Những thành viên đã cảm ơn dolphin18102008 vì bài viết hữu ích:
      Ai pro cho mình hỏi ? Mình mới tham gia, mình đang cần tiêu chuẩn IEC 61190 và IEC 60383, mình có search mạng trong diễn đàn này có nhưng link bị die rồi. Bác nào có thì cho em xin được không ?
      Bị Block rùi
      Được cảm ơn 36 lần, trong 13 bài
      bạn có IEC61111 2002 up cho minh xin với
      Bác nào có IEC 61051-2 không? Cho em xin với.
      Thank các Bác nhiều lắm
    10. #8
      bạn cần xem IEC nào thì cứ vào google tìm trang doc88.com của china rồi ser nhé(nó chỉ cho view thôi bạn làm siêng thì chụp lại màn hình về dịch nhé) tiêu chuẩn gì cũng có. Up cho bạn lâu lắm mạng dạo này chán lắm.
    11. Những thành viên đã cảm ơn noncv25 vì bài viết hữu ích:
    12. #9
      Được cảm ơn 33 lần, trong 20 bài
      Không được bạn ơi!
    13. #10
      Trích dẫn Gửi bởi keisuke2804 Xem bài viết
      Bạn liện hệ mail noncv25@gmail.com tôi sent cho
      xin thì để mail người ta mới sent cho chứ?????
    14. Những thành viên đã cảm ơn noncv25 vì bài viết hữu ích:
    1. [hot]Standards MOSTWANTED
      Bởi tombmvv trong diễn đàn TIÊU CHUẨN NGÀNH ĐIỆN
      Bài cuối: 18-05-2017, 22:16
    2. Thảo luận - standards (IEC/NEC) for low voltage electrical installations
      Bởi hnguyenbk2002 trong diễn đàn Các vấn đề khác trong hệ thống điện
      Bài cuối: 29-12-2011, 16:31
