  • Kết quả 1 đến 9 của 9
      Question [Cần Trợ Giúp]- Tập hợp các THUẬT NGỮ CHUYÊN NGHÀNH cần giải đáp?
      Được cảm ơn 14 lần, trong 10 bài
      hok biết bạn hỏi lâu chưa, theo mình bạn lên http://www.wikipedia.org mà search nó sẽ giải thích tất cả các trường hợp có ký hiệu như thế, lúc này bạn biết nên chọn nghĩa nào rùi, chúc bạn thành công
      Mặc định Cho hoi "SWER transformer" la gi
      Lam on cho toi hoi SWER transformer la loai MBA gi?
      SWER = Single Wire Earth Return !
      Giup toi cai nhe, thanks!
      vui lòng post bài tiếng việt có dấu dùm bạn
      admin
      do bận rộn quá không dịch sang tiếng việt cho bạn được nên mình tạm trích :
      Single wire earth return (SWER) or single wire ground return is a single-wire transmission line for supplying single-phase electrical power from an electrical grid to remote areas at low cost. It is principally used for rural electrification, but also finds use for larger isolated loads such as water pumps, and light rail. Single wire earth return is also used for HVDC over submarine power cables.
      Canadian SWER line
      SWER is a choice for a distribution system when conventional return current wiring would cost more than SWER’s isolation transformers and small power losses. Power engineers experienced with both SWER and conventional power lines rate SWER as equally safe, more reliable, less costly, but with slightly lower efficiency than conventional lines.[1] Some single wire transmission proposals have used radio-frequency AC. SWER uses conventional 50Hz or 60Hz AC power, and is therefore much less expensive.
      Conventional low frequency 50Hz or 60Hz power is supplied to the SWER line by an isolating transformer of up to 300 kVA. This transformer isolates the grid from ground or earth, and changes the grid voltage (typically 22 kilovolts line to line) to the SWER voltage (typically 12.7 or 19.1 kilovolts line to earth).
      The SWER line is a single conductor that may stretch for tens or even hundreds of kilometres, visiting a number of termination points. At each termination point, such as a customer's premises, current flows from the line, through the primary coil of a step-down transformer, to earth through an earth stake. From the earth stake, the current eventually finds its way back to the main step-down transformer at the head of the line, completing the circuit.[2] SWER is therefore a practical example of a phantom loop.
      SWER burns up grounding poles or may fail to reset breakers in areas with high resistance soil. In Australia, locations with very dry soils need the grounding poles to be extra deep.[3] Experience in Alaska shows that SWER needs to be grounded below permafrost, which is high-resistance.[4]
      The secondary winding of the local transformer will supply the customer with either single ended single phase (N-0) or split phase (N-0-N) power in the region’s standard appliance voltages, with the 0 volt line connected to a safety earth that does not normally carry an operating current.
      A large SWER line may feed as many as 80 distribution transformers. The transformers are usually rated at 5 kVA, 10 kVA and 25 kVA. The load densities are usually below 0.5 kVA per kilometer (0.8 kVA per mile) of line. Any single customer’s maximum demand will typically be less than 3.5 kVA, but larger loads up to the capacity of the distribution transformer can also be supplied.
      Some SWER systems in the USA are conventional distribution feeders that were built without a continuous neutral (some of which were obsoleted transmission lines that were refitted for rural distribution service). The substation feeding such lines has a grounding rod on each pole within the substation; then on each branch from the line, the span between the pole next to and the pole carrying the transformer would have a grounded conductor (giving each transformer two grounding points for safety reasons).
      nguồn trích từ wiki : http://en.wikipedia.org/wiki/Single-wire_earth_return
      Được cảm ơn 67 lần, trong 3 bài
      Post xin hỏi 1 số thuật ngữ
      các bác am hiểu giảng giải cho em 1 số kiến thức về nghề tư vấn thiết kế,làm dự toán công trình (nói vắn tắt thôi ah?).trong thiết kế thì có lập báo cáo đầu tư,thiết kế cơ sở,thiết kế kỹ thuật,..các phần này khác nhau như thế nào ah?
      để có thêm kiến thức về phần này,em tìm tai liệu nào ah?
      (thông cảm em mới đi làm)
    6. Những thành viên đã cảm ơn letienlam.tdh vì bài viết hữu ích:
      Được cảm ơn 844 lần, trong 392 bài
      1: hổng biết.
      2: Phớp: collier, Anh: Collar.
      3: Low voltage static condenser schematic diagram.
      4: Earthing shield.
      5: earthing channel installation.
      6: U bolt
      7, 8, 9, 10: hỏng biết
      Thích đy chơy, ăn quả bơ, độy mũ phớt
    8. The Following 2 Users Say Thank You to Tiểu Thư Kiêu Kỳ For This Useful Post:
      GÓC CHÉM GIÓ
      Được cảm ơn 836 lần, trong 393 bài
      Mặc định Cho hỏi từ Inching control system nghĩa là gì thế anh em?
      Miềng đang xem catalog tiếng anh của một máy tiện 2 trục đứng. Trong đó có 2 từ rất khó hỉu đó là
      1. Inching control system
      2. Table inching
      Mọi người ai biết vào giúp mình cái nha :D
    10. #8
      Nơi tình yêu bắt đầu ♥
      Được cảm ơn 525 lần, trong 129 bài
      theo mình nghĩ Inching control system là hệ thống kiểm soát từng mức tính bằng đơn vị inch) còn cái table inching chắc là cái bảng chi mức (cũng tính bằng inch), hok biết đúng hok ta
      Đêm qua tôi mơ thấy nàng
      Nàng cười nàng nói: Mày lì như trâu
      Cung cấp giá rẻ: Đèn pha led, đèn túyp led t8, đèn led âm trần, đèn ốp nổi, đèn led trang trí… hàng Dragon Taiwan bảo hành 2 năm. hahaha
    11. Những thành viên đã cảm ơn minhwilliam vì bài viết hữu ích:
    12. #9
      Biết chi? Đến đánh ghen à!
      Được cảm ơn 129 lần, trong 50 bài
      Inching trong máy điện được hiểu là Chế độ chạy chậm
      Bạn vào http://tratu.vn xem qua
      Đồ xí xọn
      Đồ phá phách
      Đồ... Đồ con nít
      he he he...
    13. Những thành viên đã cảm ơn hamdsome-zombie vì bài viết hữu ích:
    1. Nghệ thuật là đây.
      Bởi wd.support trong diễn đàn THƯ GIÃN
      Bài cuối: 28-02-2013, 12:20
    2. Trợ giúp - đồ nghề dân kỹ thuật
      Bởi hoavien trong diễn đàn HỎI & ĐÁP VỀ ĐIỆN
      Bài cuối: 12-09-2012, 21:13
    3. Trợ giúp - thứ tự thuận, thứ tự nghịch, thứ tự không
      Bởi myduyen trong diễn đàn Điều khiển hệ thống điện
      Bài cuối: 06-09-2012, 15:57
