Kết quả 1 đến 2 của 2
16-05-2010, 11:41 #1
Máy cắt 123kV - Song ngữ Anh-Việt
ItemMôcDescriptionM« t¶RequirementYªu cÇuOfferedChµo hµng1234Manufacturer/Country of Origin1
XuÊt xø H·ng chÕ t¹o/Quèc gia
Ordering number of Circuit breaker2
Sè lo¹i cña m¸y c¾t
- Type
- KiÓu
Outdoor, 3-pole, live-tank
Insulating medium3
M«i trêng c¸ch ®iÖn
SF6
Rated voltage5
§iÖn ¸p ®iÖnh møc
123 kV
Rated current6
Dßng ®iÖn ®Þnh møc
2000 A
Frequency7
TÇn sè
50 HzRated three phase symmetrical short-circuit breaking current8
Dßng c¾t ®Þnh møc ®èi víi dßng ®iÖn ng¾n m¹ch 3 pha ®èi xøng
40 kA rms.Rated three phase symmetrical short circuit making current9
Dßng chÞu lùc ®iÖn ®éng víi ng¾n m¹ch 3 pha ®èi xøng
80 kA peakRated duration of short-circuits10
Kho¶ng thêi gian ®Þnh møc sÈy ra ng¾n m¹ch
3 sec
Rated Operating Sequence11
Chuçi vËn hµnh ®Þnh møc
O-0.3sec.-CO-3 min -COResistance of main contact (new contact)12
§iÖn tr¬e tiÕp ®iÓm chÝnh
mWLighting impulse withstand voltage (1.2/50ms) to earth13
§iÖn ¸p chÞu ®ùng xung sÐt (1.2/50ms) víi ®Êt
550 kV peakOne minute power frequency withstand voltage to earth 50 Hz14
§iÖn ¸p chÞu ®ùng tÇn sè c«ng nghiÖp trong 1 phót
230 kV rms.First-pole-to-clear factor15
HÖ sè kho¶ng c¸ch
1,5
Minimum creepage distance16
ChiÒu dµi ®êng rß
25 mm/kVRated out-of phase breaking current17
Dßng c¾t lÖch pha ®Þnh møc
kARated line charging breaking current18
Dßng c¾t n¹p ®êng d©y ®Þnh møc
kARated cable change breaking current19
Dßng c¾t n¹p c¸p ®Þnh møc
kARated small inductive breaking current20
Dßng c¾t c¶m øng nhá ®Þnh møc
kA
Rated capacitive breaking current21
Dßng c¾t ®iÖn dung ®Þnh møc
kARated transient recovery voltage for terminal faults22
§iÖn ¸p kh«i phôc tho¸ng qua ®Þnh møc khi h háng tiÕp ®iÓm
kVOperating mechanism - 3-pole or 3 single pole23
C¬ cÊu vËn hµnh – 3 cùc hoÆc 3 cùc ®¬n
3-poleOperating mechanism drive type24
KiÓu t¸c ®éng c¬ khÝ
Spring/ HydraulicCircuit breaker opening time25
Thêi gian t¸c ®éng cña m¸y c¾t më
< 70 msCircuit breaker closing time26
Thêi gian t¸c ®éng cña m¸y c¾t ®ãng
< 100 msClearance between poles27
Kho¶ng c¸ch gi÷a c¸c cùc
mmMinimum clearance from isulated base to earth28
Kho¶ng c¸ch nhá nhÊt tõ b¶n ®Õ c¸ch ®iÖn tíi ®Êt
2500mmTotal weight of complete circuit breaker29
Tæng khèi lîng toµn bé m¸y c¾t
kgMax. impact load due to circuit breaker operation30
T¶i träng t¸c ®éng cho phÐp khi vËn hµnh m¸y c¾t
kgRated mechanical terminal load kN (Bending load)31
T¶it träng c¬ häc cña tiÕp ®iÓm ®Þnh møc kN (t¶i träng uèn cong)
> 6000NNumber of spare auxiliary contact32
Sè tiÕp ®iÓm phô trî dù phßng
Normally opened
Më th«ng thêng
12
Normally closed
§ãng th«ng thêng
12Auxiliary power supply33
C«ng suÊt phô trî
- Motor driver
- Cho ®iÒu khiÓn ®éng c¬
220V AC
- Heating voltage
- §iÖn ¸p ®èt nãng
220V AC
- Control, closing & tripping voltage
- §iÖn ¸p cuén ®iÒu khiÓn, cuén ®ãng vµ cuén nh¶
220V DCNumber of tripping coil34
Sè cuén nh¶
TwoSF6 gas35
KhÝ SF6
- SF6 mass for one three-pole circuit breaker
- Khèi lîng SF6 cho mçi cùc m¸y c¾t
- Rated SF6 densitykg
- MËt ®é khÝ SF6 ®Þnh møc
- First threshold of SF6 densitykg/m3
- Giíi h¹n ®Çu cña mËt ®é khÝ SF6
- Second threshold of SF6 densitykg/m3
- Giíi h¹n thø hai cña mËt ®é khÝ SF6
kg/m3
- SF6 gas pressure density gauss
- MËt ®é ¸p lùc khÝ SF6
Yes
Insulator creepage distance36
ChiÒu dµi ®êng rß cña c¸ch ®iÖn
HV terminal37
TiÕp ®iÓm cao thÕ
Materials
VËt liÖu
Dimensions.
KÝch thíc
according to volume 3
- Help ABB A1700 ???
- Cách đấu cầu dao đảo chiều giữa máy phát điện 1 và máy phát điện 3 pha
- Chọn aptomat như thế nào
- Tụ bù công suất
Hãy nhấn Thank nếu bài viết này có ích cho bạn.
16-05-2010, 11:44 #2
Chia sẻ tài liệu về Máy cắt 123kV - Song ngữ Anh-Việt
Woh, dd ko hổ trợ Table, post lên nó ra tầm bậy, Mod xóa rồi úp file này lên dùm nha:
http://www.ziddu.com/download/9879882/maycat123.doc.htmlSửa lần cuối bởi longVN; 24-07-2011 lúc 11:52. Lý do: theo yêu cầu của chủ toppic, định xoá #1, nhưng đã đổi ý, hehe
Những thành viên đã cảm ơn itvn vì bài viết hữu ích:
Trợ giúp - thiết kế nút nhấn cáo áp chuyển sang mắc song song , nút nhấn thấp áp qua mắc nối tiếp?
Bởi Nhan NaNo trong diễn đàn HỎI & ĐÁP VỀ ĐIỆNTrả lời: 0Bài cuối: 27-10-2013, 12:07 -
Trợ giúp - khi mắc 1000 bóng song song thì dòng chạy trong dây là bao nhiêu?
Bởi weddien_13 trong diễn đàn Thiết bị điện gia dụngTrả lời: 11Bài cuối: 22-05-2012, 16:59 -
Trợ giúp - giúp đấu hai nguôn ba pha song song với nhau
Bởi Linhxuyen trong diễn đàn Các vấn đề khác trong hệ thống điệnTrả lời: 4Bài cuối: 09-12-2011, 14:56 -
Trợ giúp - mạch rotor nối tiếp chuyển thành song song, có ảnh hưởng đến điện áp và dòng điện trên vành trượt không?
Bởi hahanh trong diễn đàn Động cơ điệnTrả lời: 1Bài cuối: 18-11-2010, 15:41 -
Trợ giúp - Tại sao khi máy biến áp làm việc song song tỉ lệ dung lượng máy vào khoảng 3:1.Tỉ số này thiết lập ntn?
Bởi kami90 trong diễn đàn Máy biến áp, máy biến dòngTrả lời: 3Bài cuối: 28-09-2010, 11:56
