  • Kết quả 1 đến 5 của 5
      31/1 đường 53,KP8.P HIỆPBINH2 CHÁNH ,QP.HCM THỦ ĐỨC,T
      Mặc định Ðề: Cần mua 6gk 1543-1aa01 của cpu s5
      Cám ơn bác.
      Có thông tin minh bao bác ngay.
      Mr:LÂM
      DĐ:0907724375
      Email:mailinhelectric@gmail.com
      chào ban !bên công ty minh có bạn thiết bị bạn cần nếu ban co nhu câu thi alo minh 09772133341
      cho gia di bác.
      Bên bacco1 hàng củ kg?
      Mr:LÂM
      DĐ:0907724375
      CÔNG TY CỔ PHẦN QUỐC TẾ HỢP PHÁT
      VPC: H7 Quang Trung, P.10, Q.Gò Vấp.
      VPGD: 4/3 Quang Trung, Phường 10, Q. Gò Vấp.
      Tel: 08. 38942323 - Fax: 08. 38941124.
      Ms Ngọc : 0916 792 091 -0979 097174
      No. PRODUCT CODE BRAND
      1 "IR4000S (Aluminum IR Sensor + Transmitter) for measuring Methane Gas
      (There is no more IR2100 must be replaced by the latest model IRFMD)" GMI
      2 DC130 Controller (Require to confirm the Power whether 220Vac/24Vdc or 110Vac/24Vdc before order placement) GMI
      3 "Alkaline battery
      Model NO.: LR14
      Voltage: 1.5V" Energizer
      4 "MODEL DSP-Ex AUTOMATIC DEWPOINT METER
      1. Range : to be specified with order (please select from attached data sheet****)
      2. Certified safe for use in hazardous areas and with explosive gases.
      3. Portable digital hygrometer with selectable Multi range units - ppm, oC, oF, g/m3, lb/MSCF, etc.,
      4. Accuracy :±2°C
      5. Dewpoint Complete with all accessories including:
      1. carrying case,
      2. 2m stainless steel braided PTFE sampling hose,
      3. pressure calculator,
      4. instruction manual and NPL Traceable calibration Certificate.
      6. Ready to use with batteries installed."
      5 "Optional transit case Model DSP-TC
      (refer to specification sheet for details) "
      6 "Temperature Controller
      600RRR01" Gefran
      7 "4IK25RGK-A2 is no longer in production.
      Replaced by 4IK25RGN-AW2J" Oriental
      8 4GN60S Oriental
      9 "MODULE
      LD431650 " SCR
      10 "Thames-side loadcell
      T66-200kg stainless steel cantilever beam load cells" Thames-side sensor Ltd
      11 "4WE-6J53/1; W220; 50NZ4; 461627-2
      Base 4WEH16G61/6-1; W220-50N74
      Note: confirm the code, or give me the nameplate" Rexroth
      12 "Replaced by: 18048300 GF2 S10 20 5 22/24 §
      (Type: GF3 TV20s TS5S
      220-240V; 50/60 Hz; 18 VA)" BRAHMA
      13 SKKH 57/16E Semikron
      14 SKKH 72/16E Semikron
      15 SKKH 106/16E Semikron
      16 Motor 4TK10CGN-A Oriental
      17 Gear 4GN5K Oriental
      18 P/N : 0273.050H LITTELFUSE
      19 P/N : 0273.500V LITTELFUSE
      20 P/N : 0273.600V LITTELFUSE
      21 P/N : 0273.062V LITTELFUSE
      22 2RK6GN-CM Oriental
      23 "Air Caulking Gun
      GP-853A " GISON
      24 "Schmersal Solenoid Interlock Switches
      Type : AZM 161ST-12/12 rkT-024-2507
      Code: 1209451" Schmersal
      25 "Wika PG, liquid filled
      Model: 233.50
      Dial: 63mm
      Material: stainless steel
      Connection: 1/4"" NPT,bottom {instead of G 1/2""}
      Range: 0 to 60kg/cm2 & psi {instead of 50bar}" WIKA
      26 "Wika PG, liquid filled
      Model: 233.50
      Dial: 63mm
      Connection: 1/4"" NPT,bottom {instead of G 3/8""}
      Range: 0 to 21kg/cm2 & psi {instead of 20bar}" WIKA
      27 Tungsten Halogen Bulb 12V 55W Part No. A-1130 WolfLamp
      28 HF-15AC/BD-12 Clinton
      29 HF-15AC/BD-12 Clinton
      30 X3A Horn/Light Tower Clinton
      31 "IRH310-2000-601 is an old type
      Replaced by P/No : ERN 1123 2000 01L-FU K
      (IRH310 – 2000 - 022 )" SUMTAK
      32 Mục 1 (Q110213CU_21/2/11) WIKA
      33 Mục 2 (Q110213CU_21/2/11) WIKA
      34 Mục 3 (Q110213CU_21/2/11) WIKA
      35 Mục 1.1 WIKA
      36 Mục 1.2 WIKA
      37 Mục 2.1 WIKA
      38 Mục 2.2 WIKA
      39 Mục 3 WIKA
      40 Mục 4.1 WIKA
      41 Mục 4.2 WIKA
      42 "SUB-MINI CONN W/WINDOW,YELLOW
      P/N: SMPW-K-M" OMEGA
      43 "STD T/C CONN W/WINDOW,YELLOW
      P/N: OSTW-K-M" OMEGA
      44 AM1-225L 125A 35KV Andeli
      45 DZ47-63 2P 10A 400V Andeli
      46 DZ47-63 3P 63A 400V Andeli
      47 CJX1-63 Andeli
      48 "DIFFERENTIAL PRESSURE SWITCH
      CAT. NO 1910-5" DWYER
      49 "2IK6GN-SW
      Frame size: 60mm, Induction Motor
      Output ppower: 6W, GN Pinion Shaft
      3 Phase 220/230VAC" Oriental
      50 "2GN3K
      Frame size: 60mm, GN Pinion Shaft
      Gear Ratio: 3, GN-K Gear head" Oriental
      51 "RK566ACE-P10
      RK Series, 5 Phase motor, Frame size: 60mm
      Single shaft, Single phase 200/230VAC
      PL Geared type, Gear ratio: 10" Oriental
      52 "0RK1GN-C
      Frame size: 42mm, Reversible motor, Output power: 1, GN Pinion shaft, Single phase 200VAC
      0GN15K
      Frame size: 42mm, GN Pinion Shaft, Gear Ratio: 15" Oriental
      53 "5TK20CGN-A
      5GN50S" Oriental
      54 Dynamic 420 battery charge
      55 GHM0150MD601V0 MTS
      56 Straight connector female D6-pin MODEL 370623 MTS
      57 GHM0130MD601V0 MTS
      58 Straight connector female D6-pin MODEL 370623 MTS
      59 Part No.: 774540 PILZ
      60 NI14-M18-AP6X-H1141 TURCK
      61 FCS-G1/4A4P-AP8X-H1141 TURCK
      62 AZM161SK-12/12RKN-024 SCHMERSAL
      63 BETAETIGER AZM 161-B6 SCHMERSAL
      64 "Type : Z4VH 335-11Z-M20-RMS
      Code: 1154520" SCHMERSAL
      65 800-DR00-00501-000 GEFRAN
      66 40T-48-4-00-RR-0-0-0-1 GEFRAN
      67 "Dual Hi-Lo Pressure Switch 44V1-K4-N4-B1A-TTC4
      RANGE 2-25 PSI
      OVERRANGE 750 PSI
      PROOF 1000 PSI
      ELECTRICAL RATING:
      15 AMPS 250 VAC, 5 AMPS 30 VDC
      44 = NO. 44 PISTON
      V1 = NEMA 4X (IP65) ALUMINUM HOUSING
      TERMINAL BLOCK, 3/4 INCH NPT (F)
      CONDUIT CONNECTION, 2 INDEPENDENT
      SWITCHES (CSA ENCLOSURE 4 IF 'CS'
      OPTION SELECTED).
      K = SPDT, DEAD BAND FIXED
      4 = NO. 4 SPRING
      N4 = TCP DIAPHRAGM/BUNA-N O-RING
      B = ALUMINUM PROCESS CONNECTION
      1A = 1/4 INCH NPT (F)
      TT = STAINLESS TAG PERMANENTLY
      ATTACHED TO HOUSING
      C4 = CERTIFICATE OF COMPLIANCE/
      CONFORMANCE" SOR
      68 "Spare parts suitable for VITACHROM 050-125/302 C31
      as per S/N: 9-971-002152 00080001
      Circular Casing - P/N: 103
      Material: 1.4571" KSB
      69 "Transmitter Sensor Leuze LS 92/4 E-L
      Pn: 50022704 (included connector)" Leuze
      70 "Receiver Sensor Leuze LS 92/2.8 SE-L
      Pn: 50022703 (included connector)" Leuze
      71 DE-3003 Deree
      72 "FY900-101-000-02AN
      (input type thermocouple)" Taie
      73 RKD514H-C Oriental
      74 "Rotary encoder Koyo
      TRD-2E-100B-3M (TRD-2E100B-3M)" KOYO
      75 "Electro-Magnetic Clutch and Brake Unit
      Model 122-10-20" Mikipulley
      76 MU925S-41 Oriental
      77 ZR 335-11Z-M20 (101154447) SCHMERSAL
      78 "Coil, Fluid control solenoid valve
      Type: 495915C2
      Voltage: 24 V DC
      Power: 14W" PARKER
      79 "Coil, Fluid control solenoid valve
      Type: 495880C2
      Voltage: 24 V DC
      Power: 14W" PARKER
      80 "590 Power board 4 Quad
      AH385851U002" PARKER
      81 "Converter 37KW Parker
      SSD-591+0110" PARKER
      82 "DC/DC Transducer – Multitek
      Type M100-DV2I
      Ser-No : 30840-001
      Aux UH : DC 120V +/- 25%
      Class : 0.2% at DC
      Input : 0-200V DC
      Output : 4-20mA <600 Ohm" Multitek
      83 "32-CH ISOLATED ANALOG INPUT BD
      P/N: OME-PISO-813" OMEGA
      84 "ST BD W/SC CIRCUITRY W/2 M CB
      P/N: OME-DB-8325/2" OMEGA
      85 "SUMITOMO CYCLODRIVE WITH MOTOR
      Model: CNHM1-6095-AV-6
      Specification:
      Motor: 0.75 KW, 380V/3phase/60Hz, AF Motor
      IP 55, CLASS F, 4 poles,
      Reduction Ratio: 6
      Output Speed: 242 rpm
      Output Torque: 28.2 Nm
      Service Factor : 2.03
      Direction : Universal
      Mounting Foot" SUMITOMO
      86 0820055051 (0 820 055 051) Bosch
      87 SH-D12/12 SUMTAK
      88 "PAT model GM01/6.3kN
      A portable robust manual hydraulic adhesion tester for lab, site and factory use.
      Includes:
      - 5 test dollies 20mm dia. (F.S. 20 MPa)
      - 1 HSS cutting tool for 20mm test dollies
      - calibration certificate
      - Solid aluminium carry case"
      89 "5IK40GN-SW2T
      Frame size: 90mm, Induction motor,
      Output power: 40W, GN Pinion shaft,
      3phase 200/220/230VAC, Terminal box." Oriental
      90 81506025 (81506025TKST)/ PNE Crouzet RELAY ELEMENT N.O. Crouzet
      91 81506025 (81506025TKST)/ PNE Crouzet RELAY ELEMENT N.O. Crouzet
      92 1 off model DSP-Ex-PL-TC, complete with transit case, manuals and certificates of calibration and intrinsic safety
      93 "Replaced by: DIFC-FSB2
      (PLC cable DIFC-FSB1) " Mitsibishi
      94 "Air damper motor
      Model: SQN70464A20" Siemens
      95 AH3D-3D HITACHI
      96 PF 085A HITACHI
      97 "Thermocouples
      Mod. ZTC29/FC" ASCON
      98 7HF Black Magnaflux
      99 "Replaced by: LQ121S1LG55 is also 12.1 inch
      Sharp panel 12.1 inch, code LQ121S1LGF1" Sharp
      100 L180V48 G 1 ¼-ZA30A 24-230 AC / 24DC SIRAI
      101 L180V48-ZA30A 1,1/4 V24/50Hz SIRAI
      102 "Oriental Motor
      ORK1GN-C
      Gear OGN15K " Oriental
      103 "OrientalMotor 2IK6GN-SW
      Oriental Gear 2GN3K" Oriental
      104 "Absolutely Replaced by: TRD-KL360-YC2
      (TRD-K360-1774)
      Koyo encoder" KOYO
      105 "DSEI 2X61-12B
      (DSEI2X61-12B)" IXYS
      106 "IXFN 38N100Q2
      (IXFN38N100Q2)" IXYS
      107 Model No. : SEHN25-WM-110VAC or 220VAC Q-Light
      108 "Pressure Transducer Type A-10 (replaced for ECO-1)
      for general applications
      Material of wetted parts: 316L
      Case: stainless steel with aluminium head, plastic
      cablegland
      Non-linearity: 0.5% BFSL
      Pressure range: 0...1 bar gauge
      Process connection: G 1/4 A DIN 3852-E
      Signal output: 4 ... 20 mA, 2-wire
      Power supply: 8...30 V DC
      Electrical connection: valve connector, size A
      Approvals: UL / CSA / GOST
      pin assignment el. connection: UB=1, 0V=2
      P/N: 12719049" WIKA
      109 Model: DW20S BIRCHER
      110 LMT200S GEFRAN
      111 "LQ9D168K
      Sharp LCD" Sharp
      112 "LQ9D168K
      Sharp LCD" Sharp
      113 "Position Transducers
      Code: LWH 150 " Novotechnik
      114 "Item1. WIKA Differential pressure gauge,
      Process industry series" WIKA
      115 "Item2. WIKA Differential pressure gauge,
      116 "Item3. WIKA Bourdon Tube Pressure Gauges,
      Stainless Steel Series" WIKA
      117 "Item4. WIKA Diaphragm Pressure Gauges,
      Process Industry
      0 to 100kPa only" WIKA
      118 0 to 100mmHg only WIKA
      119 0 to 1000kPa only WIKA
      120 0 to 160kPa only WIKA
      121 0 to 250kPa only WIKA
      122 0 to 400kPa only WIKA
      123 0 to 600kPa only WIKA
      124 0 to 700kPa only WIKA
      125 "Item5. WIKA Bimetal thermometer, Heavy-
      Duty-Series" WIKA
      126 "High Precision Test Gauge Series
      Model: 332.54
      Dial: 100mm (4“)
      Measuring system: SS316
      Process Connection: ¼“ NPTM, bottom
      Window: Laminated Safety glass
      Pointer: knife-edge pointer, black
      Accuracy class: +/- 0.25% fsd"
      127 Range: 0 to 400psi WIKA
      128 Range: 0 to 3000psi WIKA
      129 AH3D-3D HITACHI
      130 PF 085A HITACHI
      131 Contactor 3TF40 + tiếp điểm phụ SIEMENS
      132 Contactor 3TF44 + tiếp điểm phụ SIEMENS
      133 Contactor 3TF46 + tiếp điểm phụ SIEMENS
      134 Contactor 3TF48 + tiếp điểm phụ SIEMENS
      135 Contactor 3TF50 + tiếp điểm phụ SIEMENS
      136 Contactor 3TF52 + tiếp điểm phụ SIEMENS
      137 Rơle nhiệt 3VU 1600-1MN-00 (10÷16A) SIEMENS
      138 Rơle nhiệt 3VU 1300-1MJ-00 (2,5÷4A) SIEMENS
      139 Rơle nhiệt 3VU 1300-1MK-00 (4÷6A) SIEMENS
      140 Rơle 4 tiếp cặp điểm, 3RH 1131-1APOO; (3NO + 1NC) SIEMENS
      141 Tiếp điểm phụ 3RH 1122-1APOO; (2NO + 2NC) SIEMENS
      142 RA/132040/N4/50
      143 SDA 63-40-B
      144 DNC 50-25PPV-A FOSCO
      145 ID 5046
      146 OL 5003
      147 "Cảm biến độ cứng gallet,
      49011 - 242
      Θ 0…40 bar
      Θ DC 13 - 30V 4…20mA
      F.Nr 0089765501005140003
      " INNOVATHERM
      148 T4YI - N4NKCC AUTONICS
      149 WL-24-2B430 SICK
      150 WS/WE 24-2B430 SICK
      151 WS 24-2B430 SICK
      152 WE 24-2B430 SICK
      153 IGS 205 IFM
      154 6EP1 334-3BA01 SIEMENS
      155 6EP1 336-3BA00 SIEMENS
      156 58 S08/GY-10R LIKA
      157 AM-8000K ANRITSU
      158 AM-8050K ANRITSU
      159 AM-8051K ANRITSU
      160 AM-8010K ANRITSU
      161 AM-8011K ANRITSU
      162 AM-8060K ANRITSU
      163 AM-8061K ANRITSU
      164 AM-8100K ANRITSU
      165 AM-8101K ANRITSU
      166 AM-8150K ANRITSU
      167 AM-8151K ANRITSU
      168 AM-8110K ANRITSU
      169 AM-8111K ANRITSU
      170 AM-8160K ANRITSU
      171 AM-8161K ANRITSU
      172 AM-8000E ANRITSU
      173 AM-8001E ANRITSU
      174 AM-8050E ANRITSU
      175 AM-8051E ANRITSU
      176 AM-8010E ANRITSU
      177 AM-8011E ANRITSU
      178 AM-8060E ANRITSU
      179 AM-8061E ANRITSU
      180 AM-8100E ANRITSU
      181 AM-8101E ANRITSU
      182 AM-8150E ANRITSU
      183 AM-8151E ANRITSU
      184 AM-8110E ANRITSU
      185 AM-8111E ANRITSU
      186 AM-8160E ANRITSU
      187 AM-8161E ANRITSU
      188 LC1D65008 Schneider
      189 PKZM 1-2.4 MOELLER
      190 DILEM-10 MOELLER
      191 DILER-22 MOELLER
      192 DIL1M MOELLER
      193 DIL2M MOELLER
      194 DIL0AM MOELLER
      195 11SIDLM MOELLER
      196 CP5611 SIEMENS
      197 Modutrol - M7284Q1009/U Honeywell
      198 4IK25RGK-A2 Oriental
      199 4GN3K Oriental
      200 LME18-2.3-0,5-K2 Pepper Fuchs
