  • Kết quả 1 đến 5 của 5
      Mặc định Cần bán biến tân ls giá mền
      iE5 Series - Single Phase 215, 220, 230V (V/F Control, ficel keypad)
      SV001IE5-1 0.1kW 1/8 0.1kW(1/8HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~200Hz 84.60
      SV002IE5-1 0.2kW 1/4 0.2kW(1/4HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~200Hz 89.30
      SV004IE5-1 0.4kW 1/2 0.4kW(1/2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~200Hz 92.40
      SV001IE5-1C 0.1kW 1/8 0.1kW(1/8HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~200Hz, 92.40
      Built-in RS485(Modbus RTU)
      SV002IE5-1C 0.2kW 1/4 0.2kW(1/4HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~200Hz, 95.60
      SV004IE5-1C 0.4kW 1/2 0.4kW(1/2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~200Hz, 100.30
      iE5 Series - Three Phase 220V
      SV001IE5-2 0.1kW 1/8 0.1kW(1/8HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~200Hz 93.80
      SV002IE5-2 0.2kW 1/4 0.2kW(1/4HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~200Hz 95.50
      SV004IE5-2 0.4kW 1/2 0.4kW(1/2HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~200Hz 98.90
      SV001IE5-2C 0.1kW 1/8 0.1kW(1/8HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~200Hz, 92.10
      SV002IE5-2C 0.2kW 1/4 0.2kW(1/4HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~200Hz, 95.50
      SV004IE5-2C 0.4kW 1/2 0.4kW(1/2HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~200Hz, 98.90
      iC5 Series - Single Phase 215, 220, 230V : V/f, sensorless vector control, fixed keypad
      SV004IC5-1 0.4 kW 1/2 0.4kW(1/2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 122.20
      SV008IC5-1 0.75kW 1 0.75kW(1HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 130.00
      SV015IC5-1 1.5kW 2 1.5kW(2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 153.50
      SV022IC5-1 2.2kW 3 2.2kW(3HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 167.60
      iC5 Series - Single Phase 215, 220, 230V ( built-in class A filter)
      SV004IC5-1F 0.4 kW 1/2 0.4kW(1/2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 134.70
      SV008IC5-1F 0.75kW 1 0.75kW(1HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 138.10
      SV015IC5-1F 1.5kW 2 1.5kW(2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 179.00
      SV022IC5-1F 2.2kW 3 2.2kW(3HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 192.70
      iG5A Series - Single Phase 215, 220, 230V ( fixed keypad)
      SV004IG5A-1 0.4 kW 1/2 0.4kW(1/2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 172.30
      SV008IG5A-1 0.75kW 1 0.75kW(1HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 184.90
      SV015IG5A-1 1.5kW 2 1.5kW(2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 208.40
      DESCRIPTION Price + VAT
      (USD)
      iG5A Series - Single Phase 215, 220, 230V (For Field Bus: DeviceNet, Modbus TCP, Ethernet/IP)
      SV004IG5A-1FB 0.4 kW 1/2 0.4kW(1/2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 159.80
      SV008IG5A-1FB 0.75kW 1 0.75kW(1HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 172.30
      SV015IG5A-1FB 1.5kW 2 1.5kW(2HP), 1 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 195.80
      iG5A Series - 3 Phase 220V
      SV004IG5A-2 0.4 kW 1/2 0.4kW(1/2HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 156.70
      SV008IG5A-2 0.75kW 1 0.75kW(1HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 169.20
      SV015IG5A-2 1.5kW 2 1.5kW(2HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 195.80
      SV022IG5A-2 2.2kW 3 2.2kW(3HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 225.60
      SV037IG5A-2 3.7kW 5 3.7kW(5HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 255.40
      SV040IG5A-2 4.0kW 5.5 4.0kW(5.4HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 255.40
      SV055IG5A-2 5.5kW 7.5 5.5kW(7.5HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 382.20
      SV075IG5A-2 7.5kW 10 7.5kW(10HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 427.70
      SV110IG5A-2 11kW 15 11kW(15HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 784.80
      SV150IG5A-2 15kW 20 15kW(20HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 905.50
      SV185IG5A-2 18.5kW 25 18.5kW(25HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 1,043.30
      SV220IG5A-2 22kW 30 22kW(30HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 1,237.60
      iG5A Series - 3 Phase 220V (For Field Bus: DeviceNet, Modbus TCP, Ethernet/IP)
      SV004IG5A-2FB 0.4 kW 1/2 0.4kW(1/2HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 144.10
      SV008IG5A-2FB 0.75kW 1 0.75kW(1HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 156.70
      SV015IG5A-2FB 1.5kW 2 1.5kW(2HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 183.30
      SV022IG5A-2FB 2.2kW 3 2.2kW(3HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 213.00
      SV037IG5A-2FB 3.7kW 5 3.7kW(5HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 242.80
      SV040IG5A-2FB 4.0kW 5.5 4.0kW(5.4HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 242.80
      SV055IG5A-2FB 5.5kW 7.5 5.5kW(7.5HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 369.70
      SV075IG5A-2FB 7.5kW 10 7.5kW(10HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 415.10
      SV110IG5A-2FB 11kW 15 11kW(15HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 770.80
      SV150IG5A-2FB 15kW 20 15kW(20HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 891.40
      SV185IG5A-2FB 18.5kW 25 18.5kW(25HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 1,029.20
      SV220IG5A-2FB 22kW 30 22kW(30HP), 3 phase, 200~230VAC, 50~60Hz, 0.1~400Hz 1,223.50
      iG5A Series - 3 Phase 380, 415, 440, 460V (EUROPE) fixed keypad
      SV004IG5A-4EN 0.4 kW 1/2 0.4kW(1/2HP),3phase,380~480VAC,50~60Hz,0.1~400Hz, 207.20
      SV008IG5A-4EN 0.75kW 1 0.75kW(1HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 219.40
      SV015IG5A-4EN 1.5kW 2 1.5kW(2HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 240.30
      SV022IG5A-4EN 2.2kW 3 2.2kW(3HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 273.40
      SV040IG5A-4EN 4.0kW 5.5 4.0kW(5.4HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 325.60
      (USD)
      iG5A Series - 3 Phase 380, 415, 440, 460V (fixed keypad)
      SV004IG5A-4 0.4 kW 1/2 0.4kW(1/2HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 167.80
      SV008IG5A-4 0.75kW 1 0.75kW(1HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 177.60
      SV015IG5A-4 1.5kW 2 1.5kW(2HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 194.60
      SV022IG5A-4 2.2kW 3 2.2kW(3HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 221.40
      SV037IG5A-4 3.7kW 5 3.7kW(5HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 263.60
      SV040IG5A-4 4.0kW 5.5 4.0kW(5.4HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 263.60
      SV055IG5A-4 5.5kW 7.5 5.5kW(7.5HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 370.80
      SV075IG5A-4 7.5kW 10 7.5kW(10HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 404.60
      SV110IG5A-4 11kW 15 11kW(15HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 703.50
      SV150IG5A-4 15kW 20 15kW(20HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 765.60
      SV185IG5A-4 18.5kW 25 18.5kW(25HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 908.40
      SV220IG5A-4 22kW 30 22kW(30HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz, 986.70
      iG5A Series - 3 Phase 380, 415, 440, 460V(For Field Bus: DeviceNet, Modbus TCP, Ethernet/IP)
      SV004IG5A-4FB 0.4 kW 1/2 0.4kW(1/2HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz 156.50
      SV008IG5A-4FB 0.75kW 1 0.75kW(1HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz 166.40
      SV015IG5A-4FB 1.5kW 2 1.5kW(2HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz 183.30
      SV022IG5A-4FB 2.2kW 3 2.2kW(3HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz 210.10
      SV037IG5A-4FB 3.7kW 5 3.7kW(5HP), 3 phase, 380~480VAC, 50~60Hz, 0.1~400Hz 252.40
      SV040IG5A-4FB 4.0kW 5.5 4.0kW(5.4HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 252.40
      SV055IG5A-4FB 5.5kW 7.5 5.5kW(7.5HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 359.50
      SV075IG5A-4FB 7.5kW 10 7.5kW(10HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 393.40
      SV110IG5A-4FB 11kW 15 11kW(15HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 690.90
      SV150IG5A-4FB 15kW 20 15kW(20HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 752.90
      SV185IG5A-4FB 18.5kW 25 18.5kW(25HP),3phase,380~480VAC,50~60Hz,0.1~400Hz 881.70
      bảng giá trên ai có nhu cầu alo cho e 0977213341
      Mặc định Ðề: Cần bán biến tân ls giá mền
      Giá vẫn cao lắm
      mình đang cần mua biến tần chuyển đổi điện áp từ 380 V về 220 V.có thể tư vấn cho mình càng tốt:hngocnguyen14@gmail.com.
      rất mong nhận được chia sẻ!
      thanks
      Trích dẫn Gửi bởi baochi14 Xem bài viết
      thanks
      alo cho mình theo sđt: 0936503386 nhé.
    5. Những thành viên đã cảm ơn aidinhls vì bài viết hữu ích:
      Mặc định Re: Cần bán biến tân ls giá mền
      có cái nào dùng cho tông đơ không bạn nó có 9w thôi 120v 60hz
