CÔNG TY CỔ PHẦN QUỐC TẾ HỢP PHÁT
VPC: H7 Quang Trung, P.10, Q.Gò Vấp.
VPGD: 4/3 Quang Trung, Phường 10, Q. Gò Vấp.
Tel: 08. 38942323 - Fax: 08. 38941124.
Mail: sale4.hpinter@gmai.com Web: www.quoctehopphat.com
Yahoo: sale4.hpinter
Ms Ngọc : 0916 792 091 -0979 097174
No. PRODUCT CODE BRAND
1 8.5868.1231.3112 KUEBLER
2 D8.4C1.0600.6324.G321 KUEBLER
1 "Motor ZD: ZV-750-5-S
ZV: standing type
750: 750W 1HP
Flange
5: Hop giam toc: 5 ~ 300rpm
S: 3phase, 380V" ZD Motor
2 "Motor ZD: ZV-750-5-S
ZV: laying type (confirm?)
750: 750W 1HP
Foot
1 LGB21.130A27 SIEMENS
1 TYPE: 8.9080.1831.3001 KUEBLER
1 "IN991070
sensor ind,hochtemp160° M80x1,5/66lg
10-35VDC, 150mA, Sn50/pnp, no, 2mSiliKab
SPECIAL DEVICE" IPF ELECTRONIC
1 "ENCODER; EN 600E-1024 PPR (GIVI)
Enkoder EN600:
PPR: 1024
Signal output: Line Driver
Power supply: 5-28V
Shaft diameter (to choose at order): 6mm; 8mm; 10mm; 9.52mm
Connection output: axial or radial (to choose at order)
Cable: 1meter without connector" GIVI
1 LXB-M08P2 JEELON
2 LB-05 12NA JEELON
3 LB-05 12NA JEELON
4 OEG15 24NA JEELON
5 LA-M04 24NA JEELON
1 "Pump brand: Allweiler (Germany)
ZAS1650 G8.3-F-W20
Pre-delivery: 0007036054 / 2007
Twin Unit complete with motors" ALLWEILER
2 "Special paint RAL 9005 black
according original supply" ALLWEILER
3 "Pressure gauge standard with bourdon tube and glycerine fillable
Model: P1454
Nominal diameter: 63 mm
Accuracy: class 1.6
Case: stainless steel s.s. 1.4301 (304)
Range: -1 .. 0 .. 9 bar
Connection: G ¼ B, bottom
Data sheet DE 205 " TECSIS
4 "Pressure gauge standard with bourdon tube and glycerine fillable
Model: P1453
Nominal diameter 63 mm
Accuracy class 1.6
Case stainless steel s.s. 1.4301 (304)
Connection: G ¼ B, back
5 "774500
PNOZ XV2 30s" PILZ
6 "Schmersal SafetySwitch
Type : AZ16-02ZVK
Code: 1154699" SCHMERSAL
7 "Gear pump BONDIOLI-PAVESI
Type: HPLPA131DDDG3G3B00POMPA INGRANAGGI 3,1CC" BONDIOLI-PAVESI
8 "Model: SILVER T/OTT 8061-A-4
Code: ST3.8061.A40000 with plastic covers" Fx
9 "FP 205 - 107 - 3 - NH
same as unit - no.: 588 662 / drawing - no.: 400 001 465 0" FUNKE
10 "Electric Vibrator MVE 100/3M
3000 rpm, 230 volt – 50 Hz, single Phase " OLI
11 "Electric Vibrator MVE 200/3
3000 rpm, 230/400 volt – 50 Hz, Three Phase" OLI
12 "Remote Thermometer ""Heavy Duty"" 2.0 according to DIN EN 13190
Thermometer 63 mm 0..100°C 140 mm x 8 mm 2 m
Model: T4700
Nominal Size: 63 mm
Panel mounting flange
Window: flat instrument glass
Capillary length: 2 m
Process connection: G3/4, compression fitting. Sliding on stem
Stem length l1: 140mm
Stem diameter: 8mm
Data sheet: AE 1020 on request" TECSIS
13 "Same as above but
Nominal size: 100 mm" TECSIS
14 "BODINE FILTERED SCR DC CONTROL 1/17HP
IN:115VAC 50/60HZ OUT:0-130VDC" BODINE
15 "DISPLAY CONTROL SWT DCS
TYPE:8864.79.2311.38.19.23
PRESSURE RANGE 0...16 BAR
SENSOR REL 05 G1/2M
PLUG 8-POL M12X1
4...20MA 11...32V DC - 2 RELAY " Trafag
16 "BODINE
Model: 0818" BODINE
17 "Price of standard configuration:
** Please choose and confirm the structure (configuration).
** Price depend on the chosen structure (configuration).
Vaisala DRYCAP® Hand-Held Dewpoint Meter DM70
DM70 measures dewpoint in air and non-corrosive gases.
DM70 - B5A1A1B1
This configuration code consists of
- MI70 Indicator with rechargeable NiMH battery
- MI70Link ( pc software + USB cable)
- DMP74A dewpoint probe
* Td = -40....+60°C
- sample cell DSC74
- carrying case
- english manual
- traceable calibration certificate" Vaisala
18 MCS 2000-ECA CONTROLLER WARNER
19 MCS605-E PIVOT POINT SENSOR WARNER
20 TPT4634-5CB-6/18 DYNISCO
21 "QRB1A.B
(QRB1A-B080B70A)" SIEMENS
22 "QRA10M.B
The right code should be QRA10M.C" SIEMENS
23 S100R-DC24V-R Q-Light
24 ST45BF-1-24VDC/AC-R Q-Light
25 Cable Cutter DC 700
26 "Emergency Cable-Pull Switch
Type : ZQ 900-22
Code: 1184329" Schmersal
27 "Analog Recorder
Model : KA-100-1-K08-A1
Recording Point : 1 point
Input Type : K Type
Range : 0 - 1200 ℃
Power Supply : 110/220VAC
Alarm : 1 alarm" Konics
28 "LHE-080-2000 is an old type, it's phased out.
Use ERN 1123 2000 01L70-FU K as a replacement (ERN1123200001L70-FUK)
Sumtak encoder" Sumtak
29 "Balluff sensors
BTL5-E50-M0305-J-DEXC-TA12 " Balluff
30 C50-L-1024ZCU110 LIKA
31 "Coil Parker Valve:
R/S 24V DC
P/N: 205790 code of coil
(not be the code of valve)
DN15
PN25
Ø ren coin
30mm (3)" Parker
32 12 x valve WRJ-1S G1/4” JOYNER
33 "Asco: G 55 A 017 MS the corrected code Asco: SCG 551 A 017 MS
(G551A017MS)
*** SCG551A017MS @ Standard voltage" ASCO
34 "Order Code: CE6120-A1058-K1010-T110-H1
COMPACT PRESSURE TRANSMITTER for general applications
design: flush mounted diaphragm
design: for process temperature up to +140 °C
measuring range 0...10 bar, overload limit 30 bar
measuring accuracy:
linearity error incl. hysteresis < + 0.2 % f.s.
accuracy of adjustment < +/- 0.2 % f.s.
process design: thread connection
G 1/2 B with O-Ring-seal
electrical connection: right angle plug acc. to DIN 43650, protection type IP 65
output signal: 4...20 mA, 2-wire circuitry" LABOM
35 "Order Code: CE6120-A1058-K1010-T110-H1
COMPACT PRESSURE TRANSMITTER for general applications" LABOM
36 "RESIMIC (IEC, A)
Model: RMNWFW-ML100SX01/60-350/200-(YKN-1-67)-15/(316/L)-JIS10K25ARF/(316/L)" YAMARI
37 "Pressure Switch
DCM 6 " FEMA
38 "Inductive Proximity Sensors
Type : IFL 15-30L-10/01P" Schmersal
39 "Inductive Proximity Sensors
Type : IFL 15-30L-10N " Schmersal
40 "VXZ2360-10-4GR1 replaced by
VXZ2360-10-4DLR1
SMC Pneumatics - VT Series Valves" SMC
41 "VHS30-10-R invalid Part Number, must be
1. VHS20-01-R (6-8 weeks)
2. VHS20-02 (1-4 weeks)
3. VHS30-02-R (6-8 weeks)
*** Please choose 1 of 3 with same price
SMC Pneumatics" SMC
42 "Microcylinders
Code: M 150 016 0025 13" Univer
43 "LFL 1.333
240V,w/o AGM socket base" Siemens
44 AGM socket base Siemens
45 "NORGREN
11-042-013
In let: 400 psi - max
Out let: 250 psi - max
Temp 175C degree F – max" NORGREN
46 Corinex HomeNet PowerPlug AV200 – Dual Pack Corinex
47 "MVSI 3/800-S90 is old version
replaced by MVSI 3/800-S02" Vibramotor
48 "P/N : VIPA 314-6CF02
CPU 314ST/DPM" VIPA
49 CXP-AV200-ETHe Corinex
50 "System Integrator
Version : US / EU / UK / AUS" Corinex
51 "POG 10 DN 1024 I
Baumer Incremental Encoder Optical
- Incremental Encoder with Marine air
protected/tropicalized
- B10 shaft 11k6 x 30 IP 66
- Logic level: HTL
- UB = +9... +30v
- square ware outputs: K1, K1', K2,
K2', K0, K0'
- Incr./turn: Z = 1024
- Compatible to serial no.: 2072784" Baumer
52 "HOG 10 DN 1024 I
- Hollow Shaft Incremental Encoder
- Dust protected version also as plugs
trained cover plate with insulated
bearing, marine air protected /
tropicalized
- A4KR, Bore size 17 cones 1:10 IP 66
- Logic level: HTL
- UB = +9...+30 VDC
- Output: K1, K1', K2, K2', K0, K0'
- Inc./turn: Z = 1024
- Compatible serial no.: 1985193" Baumer
53 "POG 10 DN 1024 I
- Logic level: HTL
- UB = +9... +30v
K2', K0, K0'
- Compatible to serial no.: 1990645" Baumer
54 "M10M-NBRP/C-PEAK -
CHANNEL PLATE GASKET " ALFA LAVAL
55 "TS20M-FKMT/C-RIB -
56 Order Code: AM5H-A-PP1-A-R2NN ALISH
57 Order Code: AT-PP1-B-1 ALISH
58 "MTN/2100
Hand Held Probe for VM Meter Kit without cable "
59 "MTN/CA418
Cable Assembly for use with VM Meters, TNC plug to 15 pin ""D"" type plug, half length coiley cable."
60 Unipulse Indicator
61 "Model: F805A
*** Please indicate the supply voltage of the indicators when place order."
62 Optional for F805A
63 Model : OP4 (485) RS-485
64 Model : OP5 (CCL) CC-Link
65 Model : OP6 (ODN) DeviceNet
66 Load Cell
67 Model: RSCM-500N
68 Summing Box
69 Model: B412
70 Pendulum switch EL 101 D
71 K1S50GTF Hedi
72 "7914001-001,
Pt-100 for hygienic requirements.
Suitable for weld-in boss or thermowell.
10 m cable, 3-wire, Free terminal ends." Pentronic
73 "Accessories:
9025001-019
Weld-in boss suitable for 7914 model.
R=19mm. Thickness 1,25mm." Pentronic
74 "SUNTEC SOLENOID COIL 05
220~240V, 50~60Hz, 9W, IP54
Code: 3713798SAV" SUNTEC
75 MSQ-40 150/5A CL1 10VA CT Nitech
76 "Schmersal Solenoid Interlocks – Straight Actuators
Type : AZM 161-B1" Schmersal
77 "MCT5-005E2
Single Phase AC Current Transducer, Input:
0~5A AC, Output: 4~20mA DC, Auxiliary
Power: Loop Powered (Requires 15~40V DC
Instrument Power)"
78 "Type: SA47/TDRS71M4
Số serial: 30.0149312901.0001.08
Gear motor, 0.55 Kw, 230/400V, rmp 1380/25" SEW
79 "Type: SA47/TDRS71M4
Số serial: 30.01493428010003.08.004.08.0001
Gear motor, 0.55 Kw, 230/400V, rmp 1380/25 " SEW
80 "Type: SA57/TDRS80K6
Số serial: 30.0149314001.0001.08
Gear motor, 0.37 Kw, 230/400V, rmp 900/5.7" SEW
81 "Type: SA47/TDRS71M4
Số serial: 30.0149313501.0001.08
Gear motor, 0.55 Kw, 230/400V, rmp 1380/48 " SEW
82 "Type: SA47/TRS80S4
Số serial: 30.0157849001.0001.09
Gear motor, 0.75 Kw, 230/400V, rmp 1400/85 " SEW
83 HF320-SB1XC Rotronic
84 "RTD sensor
TYPE : SI1127/3F/DGIF/LU=30/TDT=5M/ET
Thermowell drilled from solid bar stock AISI 316 L
Thread M10x150
Resistance sensor : 1 x Pt100 : at 0°C class B
3 wires
Output with 5 Meter cable isolated cable
Code 961857" Thermo Est
85 "Tag No.: TV-303; Type: 241-7; Inch [""] 1""
Class [Lbs] 150; Body Material: Cast Steel A216WCC
Flange form/connection: RF
Plug / Seat material: SS 410; Leakage Class: IV
Characteristic: =%; Cv-value: 12; Flow Direction: FTO
Bonnet: Std; Actuator Type: 3277; Size [cm2] 120
Stroke [mm] 15; Spring Range [Bar] 1,4 ... 2,3
Fail safe position: FC; P/P Positioner 0.2-1 bar: 3760
I/P Converter: 6116; Airset: yes" SAMSON
86 "Tag No.: TV-304.1; Type: 241-7; Inch [""] 1½""
Characteristic: =%; Cv-value: 30; Flow Direction: FTO
87 "Tag No.: TV-304.1; Type: 3522-7; Inch [""] 1½""
Class [Lbs] 300; Body Material: Stainless Steel A351CF8M
Flange form/connection: Female thread
Plug / Seat material: SS 316Ti; Leakage Class: IV
88 "Tag No.: LV-307.1; Type: 3522-7; Inch [""] 2""
Characteristic: =%; Cv-value: 40; Flow Direction: FTO
89 "Tag No.: LV-313.1; Type: 3522-7; Inch [""] 1""
90 AC-8120…00/AH648 Univer
91 AC-8120…00/AH648 Univer
92 Order No. : SCLTSD-370-10-07 PARKER
93 Order No. : 16SLC2-B-25 - Code chưa đúng PARKER
94 Order No. : FPC.F25.BM-F6-PNP - Code chưa đúng PARKER
95 "Current: PSB250AF1A
TYPE : PSB250AF1A4" PARKER
96 Order No. : SCPSD-400-14-15 PARKER
97 "EN 837-1
Order No. : PGB.0631.250
NPT 1/2"" MALE" PARKER
98 Order No. : D1SE30BNJW PARKER
99 TYPE : 73218BN4UNLVOC111C2 PARKER
100 "EMU32.53, 5(6)A, 10 Imp./kWh / 120msec
Three phase energy meter
for current transformer
3x230V, class 1
one tariff,
S0 impulse output: 10 imp/kWh, 120 msec
factor of current transformer
singular adjustable from 5/5-1275/5A
For fixation on DIN rail 35 mm" EMU
101 C.T. ASK 31.3, 80/5A, cl.1 EMU
102 C.T. ASK 31.3, 100/5A, cl.1 EMU
103 "EMU32.53, 5(6)A, 10 Imp./kWh / 120msec
3x230V, class 1
one tariff,
104 C.T. ASK 31.3, 80/5A, cl.1 EMU
105 C.T. ASK 31.3, 100/5A, cl.1 EMU
106 "IR thermometer
Model: BG42
Range: -20 to 500 Deg.c" Blue Gizmo
107 "Schmersal Safety Switches
Type : AZ 15 ZVRK-M16" Schmersal
108 "PCS 095
Operator Panel topline mini, LCD display,
softkeys, 4x40 character" LAUER
109 "HMI-TOOL
HMI Tool, Master-Software for project programming
for LCA Text Displays and PCS Operator Panels,
version 2.2" LAUER
110 "733
Programming cable LCA, PCS, VPC 095" LAUER
111 "Magnehelic Differential Pressure Gages
Model : 2000-300MM" DWYER
112 "Valve body: Type: PHS520S-8
Pressure: 1.5 – 9 kgf/cm2
Coil: PEC5
24VDC, 2.6 W
Max. 10bar" PARKER
113 "RK 85/7-1
EDV-NR: 50019140
24 - 48V AC/DC
Replaced by: PRK 96M/R-3420-25
(Please note mounting is different.)" LEUZE
114 "RGS Solenoid Valve Part No: R2518PKS0B
** confirm before order" RGS
115 "CODICE 626600
FLU25
DN 1"" 1""
Flussostato per tubazioni da 1"" a 8"".240V.Pmax d'esercizio: 10bar temp: -30-120°C.
(Code No. 626600 Flow Switch for heating and air conditioning systems. Suitable for 1"" to 8"" pipe.)" CALEFFI
116 "TNT32
DC24
Replaced by: TNT 35 " LEUZE
117 "AC axial fan
4656EZ" Ebm Papst
118 "Schmersal Solenoid Interlocks Only
Type: AZM 161SK-12/12rk-024
Code : 1164207" Schmersal
119 "Handheld Digital Manometer
Code: 477-1-FM
- Range : 0-20 in w.c." DWYER
120 "Novotechnik Position Transducers
Type: TLH 300 (TLH300)" Novotechnik
121 "UMV4301
Type: SP 3.5T – 2.2Kw – 3Ph/400V
In the current range, we would propose the SP 3.5T for high overload (for heavy duty for conveyor, mixer application)" Leroy Somer
122 "Trimod Besta Level Switch A01041
Part No: A01 041" Trimod Besta
123 "Trimod Besta Level Switch C/w 1.5m Rod Extension A01140
Part No: A01 140" Trimod Besta
124 "K1P2R11A
NIHON SPEED/NIHON SPINDLE " Nihon
125 "K1P4R11A
126 "Schmersal Safety Switches
Type : AZ 15zvk-M16 (Old Model)
Type : AZ 15zvk-M20 (Changed Model)
Code: 1157375" Schmersal
127 "Schmersal Position Switches
Type : Z1R 236-11Z-M20" Schmersal
128 ER36 Sealmaster Bearing
129 "Solenoi Valve
Model: G631-3600A.
Type: H10FDFM4VBRM
Pp 3000psi
S/N 5059" MOOG
130 FLUKE 177
131 SR3-6V-1W Shimaden
132 "FA-Coder
TS5300N252 compatable with SN. A5023
Tamagwa FA CODER
Model :TS 5300
Series : OIS 38
100 C/T, C2-12V
N252, S/N A5023" TAMAGAWA
133 "Zisen RSO fuse
IEN : RSO-800A
H :500V
I : 50Kv" Huyu
134 "Model : KP series 800A
Code KP800A" Huyu
135 "Hydraulic filter
Current: 92616910
926169 10C" Parker
136 "Van solenoid
SY7220-5DZ-02 " SMC
137 "Digital Thermo-Anemometer
Model: 471-3 " DWYER
138 "Schmersal Safety Switches
Type : AZ16-12ZVRK-M20 " Schmersal
139 "Incremental Encoder
I58-L-4096ZCU48" LIKA
140 "Absolute Encoder
ASC5811/GY-10" LIKA
141 "Incremental Encoder
IT65-Y-1000ZCP4C" LIKA
142 "Absolute Encoder
ASC5810/GY-10" LIKA
143 "INDICATION F. LKLA Ø85 WITH PROX.SWITCH HALL PNP 20-30 VDC GREY
P/N: 9612510613" ALFA LAVAL
144 Motor 4RK25GN-C Oriental Motor
145 "Gear 4GN25K
(4GN-25K) " Oriental Motor
146 "5GN90KA OrientalMotor
Gearhead Frame Size 90mm, GN Pinion, Gear Ratio 1:90. " Oriental Motor
147 "5GU10XK OrientalMotor
Gearhead Frame Size 90mm, GU Pinion, Decimal Gearhead, Ball Bearing Type." Oriental Motor
148 "Model : RH 25CFF (RH25CFF)
Pulse Unit : 5 CC/P
Max Pres : 1 Mpa
Temp. : 80 deg C
Flow range: 80- 800 l/h
Gross weight: 15kg" NITTO SEIKO
149 "KOSO E/P POSITIONER
MODEL: EPC-814"
150 "COMPLETE ACTUATOR ASSEMBLY FOR SERIAL NO.: VBKY023
MODEL: 361RSD-100
C/W HANDWHEEL"
151 Order Code: ATM-A-PPO-C-O ALISH
152 Flow switch # V8 DWYER
153 Corinex HomeNet Power – Dual Pack Corinex
154 "Hearing capsule
PN: 519670083" FHF
155 "Schmersal Safety Position Switches
Type : MV6H 330-11y
Code: 1149664 " Schmersal
156 "Item no. 10123731
Description: IHRM 12P1501" BAUMER
157 "Item no. 10132023
Description: IHRM 12P1501/KS34P" BAUMER
158 GDML 2016 GB 1 schwarz Hirschmann
159 GDM 3-16 Hirschmann
160 "Burner Control Box
LAL1.25 230VAC" SIEMENS
161 Bracket user for LAL1.25 230VAC SIEMENS
162 CT ASK 31.3, 50/5A Kl.1 EMU
163 "Model: SGDM-1AADA
O/N: 9P4140-10B-6
S/N: D0102F53510006
AC-input 3Pha 200-230V 50/60Hz 60A
AC-Output 3Pha 0-230V 0-300Hz 58.6A 11KW" Yaskawa
164 "Model: MT4403T.
S/N: MT440340000010030178
COMO PLC ( RS232/4852/4W )
COM1 PLC ( RS232/4852/4W )
COM2 PLC ( RS232 )/PLC ( RS232 )" HMI
165 80-3002.003 EAO
166 80-3003.000 EAO
167 80-2002.000 EAO
168 "EMU32.53, 5(6)A, 10 Imp./kWh / 120msec
3x230V, class 1
one tariff,
169 "Current Transformer EMU6A315.3 50/5A
1.25VA
Primary conductor: 30x15mm / 20x20mm
Round conductor: Ø 28 mm" EMU
170 "Pressure Gauge
Model: 213.53 (Dry version)
Dial size: 63mm {please confirm upon ordering}
Measuring system: copper alloy
Window: Acrylic
Accuracy: +/-1.6%fsd
Connection: 1/4”NPT bottom {instead of19G, please
Range: 0 to 250 bar" WIKA
171 "Capsule pressure gauge, process industry
series (Dry version)
Model: 632.50
Dial: 63mm (2 ½“)
Measuring system: stainless steel
Range: 0 bar...100 mbar
Process connection: G 1/4 B
Connector position: lower mount (bottom)
Window: laminated safety glass" WIKA
172 "Capsule pressure gauge, industrial series (dry
version)
Model: 612.20
Dial: 63mm (2 ½“)
Window: flat instrument glass" WIKA
173 Type: AK45 Gestra
174 "Schmersal Safety Switches
Code: 1157375
Type : AZ 15zvk-M16 (Old Model)" Schmersal
175 "Temperature Controller
1600 DDR0-00-00-0-1" Gefran
176 "Servo Driver
Code: RS1A05AA
Series No.: 06101702166RA" SANYO DENKI
177 "Cable from PC to driver servo
Model No.: AL-00490833-01" SANYO DENKI
178 Connector 00608713 SANYO DENKI
179 "R1.188.0630.0
SNV4063KL_30S_DC_24V_(A)" Wieland
180 "K302698
Kit for 8345H003 @ 240/60,220/50" ASCO
181 "I/P CONVERTER TYPE PC150A
IN:4÷20 mA, OUT:3÷15 PSI
SUPPLY:25 PSI" OMC
182 "Stainless steel pressure gauge with liquid filled
Model: 233.50
Dial: 100mm (4“)
Case: 304SS
Measuring element: 316SS
Acc: +/- 1.0% fsd
Connection: ½“ NPTM, bottom
Range: 0 to 1 bar" Wika
183 "Stainless steel pressure gauge with liquid
filled
Model: 233.50
Dial: 100mm (4“)
Case: 304SS
Acc: +/- 1.0% fsd
Connection: ½“ BSPM, bottom
connected with diaphragm seal Model: 990.22
Design: Tri-Clamp
Process connection: DN 1 ½“
Rating: PN40
Material of wetted parts: stainless steel 1.4435
Fill fluid: DI Water
Range: 0 to 10bar only
NOTE: Clamp Ring, Sealing Ring & Welding
Socket } Not included in delivery." Wika
184 "Cable resistance thermometers with
bayonet coupling, shipbuilding industry,
TR195
Design of process connection: bajonet coupling with
G1/4 connector
Probe material: stainless steel 1.4571
Cable: PTFE, with plastic laminated aluminium foil,
application range -200 °C...+200 °C
Ingress protection: IP 67
Certificates: GL- and LR approval (details please see
data sheet)
Type and number of sensors: 1 x Pt100 application
range -50 °C ... +200 °C
Sensor method of connection: 3 wire
Sensor limiting error: class B per DIN EN 60751
Probe diameter: 8 mm
Probe length: 47 mm
Cable length: 1000 mm
TR195-Z-Y3B-431000ZZZ-Z" Wika
185 "Differential pressure gauge Process
industry series
All wellded construction
Typ: 732.51 Dial: 100mm (4“)
Measuring system: stainless steel; 0...400 mbar and
up diaphragm from NiCrCo-alloy (Duratherm)
Case: stainless steel with pressure blowout disk
Range: -1...+5 bar
Process connection: 2 x 1/2 NPT male
Temperature range of medium: -20 ... +100 °C (-4 ...
+212 °F)
Mounting device: mounting kit for wall or pipework,
steel
Accuracy class: class 1.0
Max. static pressure: 25 bar
Overpressure safety: 25 bar" Wika
186 "Minihelic DP gage
#2-5000-100 MM" DWYER
187 "Spestrophotometer
CM-2500d" Konica Minolta
188 "Servo Pack 200V
Model: SGDM-30ADA.
O/N: S09Z1-Z24-260
S/N: 1L09ZAPZ1240260
AC-INPUT 3PH 200-230V 50/60HZ
AC-OUTPUT 3PH 0-230V 0-300HZ 24A 3 KW" Yaskawa
189 "Servo Pack 200V
Model: SGDM-75ADA
O/N: 9P4140-10B-6
S/N: D0103G846710006
AC-INPUT: 3PH 200-230V 50/60Hz 17A
AC-OUTPUT: 3PH 0-230V 0-300Hz 54.7A 7.5KW" Yaskawa
190 "Servo Pack 200V
Model: SGDM-1AADA
O/N: 9P4140-10B-6
S/N: D0102F53510006
191 "BCL 8 S M 550 (BCL8SM550)
PN. 500 40230 (50040230)" LEUZE
192 "CONTROL BOX[WAS LANDIS+GYR LOA21]
Model: LOA24.171B2B
The code can completely replaced
LOA24.171B27 (LOA24.171B.27) " Siemens
193 "BMI2.02
EMG Electronic Board
Part-number: 237275
Typ. BMI 2.02
Nr. 1042792 75VA
230V 50-60Hz" EMG
194 "Motor servo panasonic: MUMA042P1S
2 input 3phase/AC114V
output: 0.4kw, 200hz, 3000rpm" Panasonic
195 "Motor servo panasonic: MUMA042P1S
Hàng cũ 80%, không bảo hành" Panasonic
196 "POSITION TRANSMITTER
Code NT7211/S1-CE05 " METSO
197 "SICK STEGMANN encoder
SRS 50 C3 (SRS50C3)
MAT 6CR002 00003 (MAT6CR00200003)
VDC 7-12 V." STEGMANN-Sick
198 "Wika Pressure Gauge
Model: 233.50
Dial: 100mm
Connection: 1/2""NPT, bottom
Range: 0 to 400 bar" Wika
199 "Temperature Controller
600-R-R-R-R-1" Gefran
200 "Model 5000-IS Intrinsically Safe Gas Check Leak Detector
Includes readout in ml/sec and ppm, Data transfer software/IR link,
carry case, long probe, power adapter, manual, and certificate of calibration" TM
