dịch cho em đoạn này với.em dịch ra thấy khó hiểu quá
Speed: Speed rating, at the upper limit, is determined by the speed at which mechanical damage is done to the machine. The lower speed rating is based on the limit for field current (as speed increases, a higher field current is necessary to produce the same voltage).
There are four internal losses that contribute to lower efficiency of a DC generator :
Copper losses
Eddy-current losses
Hysteresis losses
Mechanical losses
