  • Kết quả 1 đến 2 của 2
      Mặc định Chuyên cung cấp bơm chân không BUSCH
      Dear Quý khách hàng,
      Chúng tôi, Công ty Cổ Phần Kỹ Thuật Cơ Điện 27 (27MEE CORP) vinh dự là đơn vị phân phối sản phẩm bơm chân không nhãn hiệu BUSCH tại Việt Nam.
      Các dòng sản phẩm chúng tôi cung cấp như sau:
      R 5 - oli- recirculating Rotary Vane Vacuum pump
      3-1600 m3/h (50 Hz)
      3,6-1920 m3/h (60 Hz)
      0,1-20 mbar
      Successfully approved in many applications in industry.
      reliable with oil lubrication
      air-cooled, no cooling water needed
      excellent water vapour tolerance (R 5 Aqua)
      easy maintenance
      COBRA - Dry Screw Vacuum Pumps
      70-800 m3/h (50 Hz)
      84-960 m3/h (60 Hz)
      0,05 mbar
      Ideal for many processes in the chemical, pharmaceutical and semiconductor industry.
      non-contacting operation
      Atex certified, temperature control
      frequency, volume flow and differential presure can be regulated
      modular construction system that allows for optimizsed adaptation
      Mink, Merlin - Dry Rotary Claw Vacuum Pumps and Blowers
      50-500 m3/h (50 Hz)
      60-600 m3/h (60 Hz)
      20 mbar-2 bar(g)
      For vacuum and overpressure with reduced running costs.
      no maintenance
      high efficiency
      Huckepack - once-through lubricated Rotary Vane Vacuum Pumps
      100-1000 m3/h (50 Hz)
      100-1000 m3/h (60 Hz)
      0,5 mbar
      For tough applications in the chemical and plastics industry.
      low ultimate pressure achieved by two stages
      proven reliability and low maintenance
      adjustable oil metering pump
      suited for acid, aggressive gases
      Seco - Dry Running Rotary Vane Vacuum Pumps
      3-250 m3/h (50 Hz)
      3,6-300 m3/h (60 Hz)
      100,2500 mbar
      For many applications in various industries.
      long running times through special vanes
      compact, simple construction
      also available as pressure vacuum pump for suction and blast air (Seco Print)
      Samos - Side Channel Blowers
      40-1100 m3/h (50 Hz)
      48-1320 m3/h (60 Hz)
      Pmax 390 mbar
      Dolphin - Liquid-Ring Vacuum Pumps
      30-435 m3/h (50 Hz)
      35-543 m3/h (60 Hz)
      33 mbar
      One- and two-stages designs for evacuation of humid gases or vapor.
      rubust and proven design
      reliable
      many pump sizes and models
      Fossa - Scroll Vacuum Pumps
      5-30 m3/h (50 Hz)
      6-36 m3/h (60 Hz)
      0,01-0,075 mbar
      For clean and dry high vacuum.
      non-contacting and oil-free compression
      no maintenance, no wearing parts
      silent operation
      Panda, Puma - Roots Pumps
      250-8000 m3/h (50 Hz)
      300-9600 m3/h (60 Hz)
      Pmax 80 mbar
      Vacuum pumps with high displacement at low inlet pressure.
      integrated bypass valve allows continuous suction against atmosphere (Panda)
      reliable
      economical
      Pather, Dingo, Cat - Rotary Lobe Pumps
      6-1000 m3/h
      P max 500 mbar vacuum
      P max 1000 mbar overpressure
      Dry rotary lobe pumps for pneumatic converting, environmental, textile and paper industry.
      oil - free, non-contacting
      high differential pressure
      low maintenance requirements
      high efficiency
      Merlin series combination pumps deliver blast air and vacuum simultaneously for applications in the print market.vacuum and pressure simultaneously
      100% oil-less compression
      independent compression stages
      minimal maintenance
      Vacuum to 18" Hgv
      Pressure to 15 PSIG
      Để được hỗ trợ tư vấn về kỹ thuật, tài liệu cũng như báo giá sản phẩm Quý khách hàng vui lòng liên hệ ngay cho chúng tôi theo địa chỉ bên dưới.
      Thanks & best regards,
      Bùi Xuân An (Mr.)
      Sales Department | 27MEE CORP
      Phone: 0909 04 58 59
      Mail: an@27mec.com.vn
      Website: www.27mee.com.vn
      Mặc định Ðề: Chuyên cung cấp bơm chân không BUSCH
      Dear all,
      Anh chị em nào có nhu cầu về bơm chân không mà cần bên mình hỗ trợ kỹ thuật hay báo giá sản phẩm xin vui lòng liên hệ cho mình nhé.
      Chúc cả nhà cuối tuần vui vẻ.
      Bùi Xuân An (Mr.)
      Sales Department | 27MEE CORP.
      Mobile: 0909 04 58 59
      Email: an@27mec.com.vn
    1. Cần bán - Bơm hút chân không Busch,Becker,Vacutronic cung cấp cho các KCN SX toàn quốc
      Bởi hctechco trong diễn đàn Thiết bị điện khác - Chưa phân loại
      Bài cuối: 06-09-2014, 11:50
    2. Cần mua - Tìm kiếm các đơn vị thương mại chuyên cung cấp sản phẩm dây và cáp điện
      Bởi cadisun trong diễn đàn Cáp điện, Tủ bảng, thang máng cáp
      Trả lời: 8
      Bài cuối: 14-11-2013, 14:28
    3. Cần bán - Chuyên Cung cấp Phân phối Hộp Số Giảm Tốc HW-LW-VW-UW-HMW
      Bởi racy trong diễn đàn Động cơ điện, máy bơm, quạt thông gió
      Bài cuối: 06-07-2013, 08:27
    4. Cần bán - Chuyên sản xuất và cung cấp dây cáp điện Ngọc Khánh, giá tốt nhất thị trường
      Bởi gioi_ngockhanh trong diễn đàn Thiết bị điện khác - Chưa phân loại
      Bài cuối: 01-07-2013, 19:07
    5. Cần bán - Chuyên cung cấp sản phẩm ứng dụng led
      Bởi sunlighting trong diễn đàn Chiếu sáng, đèn trang trí, led quảng cáo
      Bài cuối: 09-05-2013, 14:07
