  • Kết quả 1 đến 4 của 4
      Được cảm ơn 12 lần, trong 9 bài
      when the input voltage signal of controller and current signal are in the synonymous end state user should adjust the parameter to. when they are not in the synonymous end state, user should adjust to. when the voltage signal and current signal sampling are correct and at the same time the controller hasn't input one set of capacitor group, the displayed power factor value is negative value. it can be judged that the voltage signal and current signal input to the controller are not in the synonymous end state. if the initial phase is 180, user should adjust it to 0. if it is 0, user should adjust it to 180. if one set of compensation device is finished installing, user should confirm whether the parameters are correct, otherwise it may cause the abnormal running for controller
      under power factor control mode, cutting threshold parameter should exceed 0.02 of input threshold parameter. if user amends the cutting threshold parameter to the value less than +0.02, the input threshold value by mistake, parameter amendment procedure will automatically set the cutting threshold parameter to 0.05 , the current input threshold parameter
      under reactive power control mode, transformation ratio preset value is the numerator of transformation ratio of signal current transformer. if the transformation ratio of signal current transformer is 500/5, the ct transformation ratio preset value is 500 other than 100
      under reactive power control mode, the capacity parameter of the output loop that not connected to capacitor groups should be preset to "0" . to the output loop with "0" preset capacity, the controller will not output signal control signal
      Sửa lần cuối bởi missyou42; 23-05-2011 lúc 19:49.
      thanh hóa_thanh hóa
      Được cảm ơn 115 lần, trong 68 bài
      Mặc định Ðề: chào các bác em có đoạn văn tiếng anh các bác dịch dùm em nha
      Trích dẫn Gửi bởi vucongchiem14081986 Xem bài viết
      khi tín hiệu điện áp đầu vào của bộ điều khiển và tín hiệu hiện tại đang ở trong trạng thái người dùng đồng nghĩa kết thúc nên điều chỉnh các tham số. khi họ không ở trạng thái kết thúc đồng nghĩa, người sử dụng cần điều chỉnh. khi tín hiệu điện áp và lấy mẫu tín hiệu hiện nay là chính xác và đồng thời điều khiển đã không nhập vào một tập hợp các nhóm tụ, sức mạnh yếu tố giá trị hiển thị là giá trị âm. nó có thể được đánh giá là tín hiệu điện áp và tín hiệu đầu vào hiện tại để điều khiển không ở trạng thái kết thúc đồng nghĩa. nếu giai đoạn đầu là 180, người sử dụng cần điều chỉnh nó về 0. nếu nó là 0, người sử dụng cần điều chỉnh nó đến 180. nếu một tập hợp các thiết bị bồi thường được hoàn tất cài đặt, người sử dụng cần xác nhận cho dù các thông số là chính xác, nếu không nó có thể gây ra các hoạt động bất thường để điều khiển
      Cái này theo tớ thì đại khái như là bạn sử dung cái CT500/5 A, nếu nó nằm trong khoảng từ 100-500 thì sẽ có nguồn ra làm cho cái công tơ điện nó quay, nếu nó nhỏ hơn 100 thì không thể làm cho cái công tơ quay được .
      Thông cảm nhé! tớ không thể dịch từng chữ chỉ hiểu nghĩa thoáng qua thôi.
      CHẢ ĐƯỢC GÌ
      CHỈ ĐƯỢC GIÀ!
      Theo e nó có thể hiểu là:
      Khi tín hiệu điện áp đầu vào của bộ điều khiển và tín hiệu hiện tại đang ở trong trạng thái sử dụng mà các thông số kết thúc nên điều chỉnh các tham số. khi những thông số không ở trạng thái kết thúc đồng nghĩa người sử dụng cần điều chỉnh. khi tín hiệu điện áp và lấy mẫu tín hiệu hiện nay là chính xác và đồng thời điều khiển đã không nhập vào các nhóm tụ, yếu tố giá trị hiển thị là giá trị âm. nó có thể được đánh giá là tín hiệu điện áp và tín hiệu đầu vào hiện tại để điều khiển không ở trạng thái kết thúc. nếu giai đoạn đầu là 180, người sử dụng cần điều chỉnh nó về 0. nếu nó là 0, người sử dụng cần điều chỉnh nó đến 180. nếu các thiết bị được hoàn tất cài đặt, người sử dụng cần xác nhận cho dù các thông số là chính xác, nếu không nó có thể gây ra các hoạt động bất thường khi điều khiển
    1. Trợ giúp - Mạng điện văn phòng bị chập chờn
      Bởi duonghuyhoang trong diễn đàn HỎI & ĐÁP VỀ ĐIỆN
      Bài cuối: 06-03-2022, 18:10
    2. KHO ĐỒ ÁN luận văn mẫu..thực tiễn
      Bởi mrhao.ceo trong diễn đàn ĐỒ ÁN - LUẬN VĂN TỐT NGHIỆP
      Trả lời: 17
      Bài cuối: 02-12-2016, 20:03
