Kết quả 1 đến 3 của 3
Chủ đề: Wincc v.6 và v.7
11-10-2010, 14:40 #1
Wincc v.6 và v.7
Bo cai wincc 7 day:
http://www.mediafire.com/?kc4yzwjx2aj
http://www.mediafire.com/?1ntylizvbqn
http://www.mediafire.com/?mj5pjowazix
http://www.mediafire.com/?mxztikg7tnu
http://www.mediafire.com/?40igjanzlmg
http://www.mediafire.com/?tdsezmdtjeg
http://www.mediafire.com/?wma9gzzejmx
http://www.mediafire.com/?egj5e1jumxd
http://www.mediafire.com/?iztpj0tgxyy
http://www.mediafire.com/?o3mex1e2yyb
http://www.mediafire.com/?yhxa7wqmzxg
http://www.mediafire.com/?mxjlbmm5xzz
http://www.mediafire.com/?yvxemfhmgix
http://www.mediafire.com/?tnawhgifnju
http://www.mediafire.com/?jqyi0z3yk7k
http://www.mediafire.com/?pyumznq1mmy
http://www.mediafire.com/?dsm7mhz2wdt
http://www.mediafire.com/?sbgmf04z9gy
http://www.mediafire.com/?qwxbdtdm1xt
http://www.mediafire.com/?jmi0mcm0hau
http://www.mediafire.com/?jmjdlacxiys
http://www.mediafire.com/?wny9iiwshrj
http://www.mediafire.com/?bvmiuy4mtq6
http://www.mediafire.com/?kndmc1zkgdm
http://www.mediafire.com/?y41yan5jxh1
http://www.mediafire.com/?wxglbxy3yc4
http://www.mediafire.com/?jjn2iiztmzp
http://www.mediafire.com/?3ywnyjpyxxt
http://www.mediafire.com/?gkagw2nxzg1
http://www.mediafire.com/?z01ngxcmvmp
http://www.mediafire.com/?tvxuwzy2t9x
http://www.mediafire.com/?9ppjj4bj0tz
http://www.mediafire.com/?ltb9zszmbdd
http://www.mediafire.com/?nnlmminkmma
http://www.mediafire.com/?ytjwnqwx7qz
http://www.mediafire.com/?igl1myillzt
http://www.mediafire.com/?nlai1mbwo2m
http://www.mediafire.com/?nx3nuvllyyh
---------- Bài viết đã được nhập tự động bởi hệ thống ----------
còn đây là bản 6.0 sp2:
http://www.mediafire.com/?dmrn3yr2gjm
http://uploaded.to/?id=tafpk1
http://www.mediafire.com/?wmmhw3fz23l
http://www.mediafire.com/?mhididtjgey
http://www.mediafire.com/?yhfumww12dz
http://www.mediafire.com/?tthskyyknd2
http://www.mediafire.com/?c1hdzx3dsce
http://www.mediafire.com/?oy5x202b5gy
http://www.mediafire.com/?4gghybn2mgm
http://www.mediafire.com/?ixgniy2blay
http://uploaded.to/?id=jqea5o
http://www.mediafire.com/?3wezwy9hds9
http://www.mediafire.com/?d0x2xx5yh63
http://www.mediafire.com/?n4zyz9gj4xl
http://www.mediafire.com/?w22yjhwghcw
Pass: www.updatesofts.com
Fix lỗi:
SỬA LỖI KHI CÀI ĐẶT WINCC
TRƯỜNG HỢP 1:
Khi cài đặt Wincc flexible 2008 nếu có trường hợp báo là "please insert CD2".
Nguyên nhân là do trong quá trình copy có thể bị chương trình quét virus quét đi một sô file trong Runtime rồi.
Do đó dưới đây mình upload lại file Runtime cho các bạn nè.
Hướng dẫn:
1. Download file "Runtime_1.rar" và "Runtime_2.rar"bên dưới
2. Giải nén ra (cẩn thận trùng tên nha)
3. copy folder vào đường dẫn: ....... \Tai lieu PLC- Thay Phuong\WinCC flexible 2008\CD_1\WinCCflexible\setup (đối với Runtime_1) và ...... \Tai lieu PLC- Thay Phuong\WinCC flexible 2008\CD_2\WinCCflexible\setup (đối với Runtime_2)
4. Cài đặt lại wincc (NOTE: đừng sợ cài đặt lâu nha vì nó chỉ cài thêm runtime thôi, phần nào cài rồi nó ko cài lại đâu).
5. Vậy là xong rồi đó.
TRƯỜNG HỢP 2: Báo lỗi chưa cài đặt MICROSOFT SQL 2005
Hướng dẫn: Click here
TRƯỜNG HỢP 3: Khi cài wincc 7.0 thì xảy ra tình trạng không vào windows được (có hiện bảng thông báo lỗi file Alxmgina.dll)
Hướng dẫn:
1. Khởi động lại máy (bấm F8 hoặc insert ) để vào safemode
2. mở System32/ xóa file almxgina.dll
3. Start/ run/ gõ chữ Regedit vào /hkey-local-machine/software/microsoft/windownNT/CurrentVersion/winlogon/ xóa Ginadll
4. Khởi động lại máy bình thường là ok
5. Tiến hành crack là xong
TRƯỜNG HỢP 4: Khi cài wincc 7.0 thì xảy ra tình trạng không vào windows được (ko có bảng báo lỗi)
Hướng dẫn:
1. Khởi động lại máy đưa đĩa windows vào chọn chế độ boot from CD
2. Để cho máy tự động copy file
3. Copy xong máy sẽ hỏi setup, repair hoặc Exit thì chọn exit nha
4. Giờ vô lại bình thường rồi đó
TRƯỜNG HỢP 5: Khi cài wincc 7.0 xong rồi, chạy ok rồi nhưng khi vào phần Graphic Designer , lúc thao tác cứ hiện ra bảng thông báo hoài (khắc phục được rồi nên hổng có hình cho xem hihi)
Hướng dẫn:
Cách 1: bác nào lười thì tải file Graphic designer về chạy lên cái
Cách 2: bác nào siêng thì dùng cách dưới này nha
1. vào Start > run > regedit
2. vào HKey_Local_Machine > Software > Siemens > WinCC > Graphics Designer > DynamicWizard
3. Giờ bạn phải thao tác sao cho giống bảng bên dưới. Đừng lo, hướng dẫn ngay thôi
Nếu thiếu cái nào thì tạo thêm cho đủ: right click > new > string value > đặt tên và giá tri cho giống như trên hình
Mình copy value sẵn cho bạn nè:
- Database = "<WinCC_Installation_path>\WinCC\WSCRIPTS\Dynwiz.d wd"
- DefaultWNF = "<WinCC_Installation_path>\WinCC\WSCRIPTS\"
TRƯỜNG HỢP 6: Khi cài wincc 7.0 xong rồi, chạy ok rồi nhưng khi đăng nhập vào windows rồi thì hiện ra bảng thông báo với nội dung sơ bộ là "không tìm thấy Alxmgina.dll hãy cài đặt lại để sửa lỗi này" Nếu chúng ta bấm ok thì vẫn xài bình thường thôi, nhưng chẳng lẽ mỗi lần vô cứ bấm ok mãi thế sao. Có cách khắc phục đây
Hướng dẫn:
1. Start/ run/ gõ chữ Regedit vào /hkey-local-machine/software/microsoft/windownNT/CurrentVersion/winlogon/
2. Tìm registry như hình bên dưới
3. Sau đó double click vào Userinit, hiện ra bảng như bên dưới, các bạn xóa đi ",,ALMXPMGR" được bôi đen trong hình. Rồi ok thế là xong rồi đó
TRƯỜNG HỢP 6: Khi cài wincc xong lúc logon vào windows thì hiện ra bảng thông báo, phải bấm ok hoặc enter thì vào. Thật phiền phức. Sau đây là cách tắt bảng thông báo khi logon nè
Hướng dẫn:
2. Tạo 1 String value (bằng cách nhấp chuột phải chọn new) đặt tên là AutoAdminLogon và đặt giá trị là 1
3. Restart máy lại để kiểm tra xem nào
- Phần mềm EPLAN P8 và hướng dẫn sử dụng
- [Tổng hợp] Ecodial
- phần mềm Proteus - mô phỏng mạch điên!
- Đã có STEP 7 V5.5 cài cho win 7 rùi nhé!!!!!!!!!!!!!!!!
- Xin phan mem PSS/ADEPT cua hang PTI
- Phần mềm Mô phỏng mạch điện Multisim full (chạy trực tiếp)
- Tổng hợp các phần mềm chuyên ngành-[update]
- [Tổng Hợp] Tài liệu đầy đủ về matlab ( cả tiếng ANh và Việt)
- phần mềm mô phỏng mạch điện công nghiệp
- [TỔNG HỢP] Về Autocad:
- Download Orcad 16.5 full win7 [MF] + hướng dẫn chi tiết !!!
- [Tổng hợp] DIALUX
- Hỏi về phần mềm powerworld
- Phần mềm Phần mềm PSIM 6.0
- Step 7 Micro/Win v4.0.5.08
Hãy nhấn Thank nếu bài viết này có ích cho bạn.
The Following 5 Users Say Thank You to itvn For This Useful Post:
15-01-2014, 13:54 #2
Ðề: Wincc v.6 và v.7
Mình đang cần wincc 6 mà down không được
25-09-2014, 11:10 #3
mình đang cần bản 6.0 mà ko down đc vào nó cứ báo lỗi .Giúp mình với
Trợ giúp - kết nối winCC với PLC s7-200
Bởi levandinh89 trong diễn đàn SCADA - HMITrả lời: 8Bài cuối: 18-05-2014, 16:40 -
Thảo luận - em bị lỗi wincc nhờ các anh giúp
Bởi star_dream trong diễn đàn SCADA - HMITrả lời: 4Bài cuối: 07-08-2013, 16:07 -
Trợ giúp - Cần pro winCC chỉ giáo
Bởi Rock32 trong diễn đàn SCADA - HMITrả lời: 4Bài cuối: 28-04-2013, 00:28 -
[WINCC] Lỗi khi cài đặt!
Bởi Rock32 trong diễn đàn PHẦN MỀM NGÀNH ĐIỆNTrả lời: 1Bài cuối: 21-04-2013, 11:00 -
Thảo luận - Convert từ Intouch 7 sang Intouch 10 và từ Wincc 5 sang Wincc 7
Bởi khongbaogio trong diễn đàn SCADA - HMITrả lời: 0Bài cuối: 13-07-2011, 22:50
